Is it that simple?
Is it that simple?
Old 03-24-24, 09:49 AM
Midlifecyclist
Midlifecyclist
Midlifecyclist's Avatar
Bikes: Far, far too many
Quoted: 23 Post(s)
Liked 13 Times in 3 Posts
Is it that simple?
3x9 to 1x8 conversion on vintage Italian
originally a 115mm ita BB.
Should I be moving the chain line 5mm inboard by using a 105mm cartridge square taper ITA BB?
Is the axle protrusion equidistant? I don’t really know how else to say it without sounding like a dick.
Midlifecyclist is offline
Old 03-24-24, 10:08 AM
Iride01
Iride01's Avatar
Quoted: 6196 Post(s)
Liked 4,811 Times in 3,319 Posts
The stack of gears on the rear axle determine where your chain line should be. So if you want good shifting to them all with equal chain angles to the high and low sprocket, then shoot for a chain line that hits the middle within a few mm. If you know you ride more on one half of the cassette, then lean your chain line a little more toward that if shifting is satisfactory enough all the way to the other extreme.
It's more a try it and see thing than a absolute, IMO. If you are shifting well enough without and wear is okay, then how much more perfection do you need?
Iride01 is offline
Likes For Iride01:
Old 03-24-24, 11:48 AM
wheelreason
Quoted: 504 Post(s)
Liked 634 Times in 374 Posts
More perfection? Like bestest?...
wheelreason is offline
Likes For wheelreason:
Old 03-24-24, 01:55 PM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
Why not 1X9 instead of 1X8?
Bill Kapaun is offline
Likes For Bill Kapaun:
Old 03-24-24, 04:14 PM
veganbikes
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,000 Times in 2,669 Posts
+1 on that. 1X9 is much better. As someone with a 1x9 that used to be a 1x7 I can say I wouldn't want to go lower than 1x9
veganbikes is offline
Likes For veganbikes:
Old 03-24-24, 05:32 PM
70sSanO
70sSanO's Avatar
Quoted: 1944 Post(s)
Liked 2,164 Times in 1,323 Posts
Are you using your existing triple crank?
If so, which chainring position?
John
70sSanO is offline
Likes For 70sSanO:
Old 03-25-24, 12:23 PM
Midlifecyclist
Midlifecyclist
Quoted: 23 Post(s)
John
existing triple crank on the outer position
Midlifecyclist
Midlifecyclist
Quoted: 23 Post(s)
My buddy has a Shimano Claris RD and shifter that he wants to use.
Old 03-25-24, 12:40 PM
Iride01
Iride01's Avatar
Why not just simplify everything and leave the FD on it and just keep it in the big ring? Obviously there is enough leeway in chain lines to let bikes use the big/big and small/small combo's. Though sometimes the manufacturer will caution against running the small/smalls.
But if you want the bestest more perfect <grin> chain line, then do what you can to move that ring where the center ring is now on that 3x crank. I think some 3x spiders, the outer ring can be put in the center position. Others you might can adjust spacers on the crank spindle or in other ways. Or just get a 1x crank with the correct chain line.
If the 3x crank is original to the bike, then the measurement of the center ring to the center plane of the seat tube should be the correct chain line. Or at least as correct as it needs to be.
Iride01 is offline
Old 03-25-24, 01:36 PM
70sSanO
70sSanO's Avatar
Then going from 115mm to 105mm will essentially put the outer ring in the middle ring chainline with the 115mm BB.
Only word of caution would be going from an asymmetrical 115mm to symmetrical 105mm spindle. But if they are both symmetrical, you should be fine.
John
70sSanO is offline
Old 03-25-24, 02:15 PM
grumpus
grumpus's Avatar
Quoted: 503 Post(s)
Liked 436 Times in 335 Posts
Why not just put the ring in the triple middle position? Then, if the chainline was right before, it will still be good. And as someone else said, why go to an eight speed cassette when your current setup is nine speed? If you're changing shifters, wouldn't it be better to go ten speed?
I stuck with 2x7 and 3x7 for a decade or two, 8 or 9 speed didn't really offer sufficient advantage to switch, but a couple of years ago I supplemented the collection with a 1x10 and the simplicity of use, and range that it provides are appreciable, even without using a huge bottom gear.
grumpus is offline
Likes For grumpus:
Old 03-26-24, 07:07 PM
veganbikes
Clark W. Griswold
Claris would likely be a downgrade it is rare Claris would be an upgrade and when it is it is usually coming from Tourney which is basically as low as you can go maybe a light upgrade to some Altus stuff which is basically Tourney in some cases or a minor notch above it. If you have 9 speed keep that all you don't need to change anything aside from deleting the front shifter and derailleur or locking the front derailleur so it stays in one place and doesn't move so it turns into a chain guide.
