Thrift store find - pista? Bike with head badge: Seventeenth performance vintage bike
I found this at a local thrift store today but I've never seen anything like it before. The top tube says PISTA & the head badge says: SEVENTEENTH PERFORMANCE VINTAGE BIKE - what do I have here?
Thanks
Thanks
Quoted: 71 Post(s)
Liked 5 Times
Looks like a modern tig weld single speeder probably a few years older back when the ss craze was bigger. You can find similar bikes new for 200 or less, used is probably a 40-80 bike in most areas as ss riders are not that common.
A bianchi pista would be worth something grabbing esp older lugged ones or any older lugged track bike for that matter but modern cheapie chinese tig welded are not worth much to most.
"SURE!"
Quoted: 65 Post(s)
Liked 56 Times
Headbadge says seventeenteeth, not seventeenth. https://www.17teeth.com/pista
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Tip of the day, anything with the word "vintage" in its name, ain't.
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Performance vintage bike? I love their silly marketing, it looks to be another low end fixed gear with some light "vintage-esque" styling that is sold via the internets. Hope you didn't spend a ton for it. These bikes are a dime a dozen under different names.
Friendship is Magic
Bikes: old ones
Quoted: 26419 Post(s)
Liked 10,380 Times
Originally Posted by BikeSnobNYC
This is a welcome sign. Butchered bars, questionable home paint job on the fork, crap-tastic extras of dubious value, and an asking price well over what a new one would cost. Praise the Mono-Cog Lord!
Quoted: 1627 Post(s)
Liked 630 Times
Snobbie has written plenty of funny stuff, but some of his commenting on fixie culture is some of his best. I started reading his blog about the same time I bought my first fixie, too.
Anyhoo, even a cheap fixie can be a bit of fun. And the OP got his at a thrift store, so it had to be cheap, right?
Quoted: 1221 Post(s)
Liked 629 Times
Is it the angle of the photo or does the front brake cable really just loop up and then connect to the back with no actual brake levers?
Quoted: 2588 Post(s)
Liked 4,824 Times
DD
Liked 629 Times
I thought it was maybe for measuring housing for levers but there's not enough length, unless they're adding cx style levers? The calipers look nice
Liked 630 Times
Oh, wait, couple of zip ties there. It would still 'work' though, you might just break the zip ties if you pull hard enough.
Liked 4,824 Times
And since the cable housing isn't anchored to anything on the frame, just tug up far enough on the housing and you're applying both brakes simultaneously. Stupid? Genius? A little of both!
DD
52psi
Quoted: 790 Post(s)
Liked 802 Times
I read the OP's description and totally saw "Seventeenth" until I scrolled back up to find "Seventeenteeth" after your correction. Oh, what a funny place our brains can be.
After the linked blog post and this, I'm definitely gonna check out more from this guy.
To the OP: By now you probably figured out it's a nothing special bike built not too long ago. But if it's fun to ride then hell, that's just less to worry about when you lock it up somewhere.
52psi
Quoted: 790 Post(s)
Liked 802 Times
Bikes: too many
Quoted: 411 Post(s)
Liked 234 Times
Thru the 90's and 2000's, I never bought (or converted a vintage bike) to a fixed gear for myself. Nor did I get a tattoo. Procrastination Rules!!!!
With that absurdly exaggerated ergonomic set up, no tape on the slippery bars and that brake cable thing, no wonder it was sold off. Honestly, it looks dangerous!
spost
10
04-03-19 03:56 PM
