Remove Small Amount of Chrome to Check Crack
Bikes: '87 Centurion Ironman Expert, '88 Basso Loto, '89 Panasonic MC-5500, '92 Vitus 992
Quoted: 60 Post(s)
Liked 10 Times
I bought a frame, but unfortunately it got damaged during shipping. The seller forgot to add dropout protection on the rear, so there were several alignment issues that I've hopefully fixed, and I'm satisfied with the compensation he gave me.
Anyway, the worst issue is a crack in what I'm thinking (hoping!) is only the chrome, but I would like to remove the chrome there to make sure the steel isn't cracked. How would you do that? An amateur framebuilder said sandblasting, but I don't have access to a sandblaster. I have a Dremel, sandpaper, files, etc... I'm beyond aesthetics at this point. By the way, the crack doesn't go all the way around, it wraps maybe half or two-thirds of the seat stay.
Bikes: a few that I can't recall
Quoted: 346 Post(s)
Liked 302 Times
My guess is that the chrome "shell" is cracked, but not the underlying steel. I am not sure how to check further. Dye penetrant or magnaflux will not work.
Quoted: 60 Post(s)
Liked 10 Times
That's what I'm hoping. I'm going to build it up anyway and ride it to see how it goes, but it would ease my mind a little to have a look at the underlying steel. Hopefully I'll get a thread going soon when the bike's complete.
Quoted: 2588 Post(s)
Liked 4,824 Times
I have a frame that was media-blasted and it was very, very difficult to get a good "edge" when we tried to blast the chrome on the rear triangle. The best we got was a dull finish; we didn't even get through to the zinc or nickel plating. You might see if you can get an X-Acto blade underneath and try to peel a bit back - maybe you can get a visual that way.
When it comes to cracks I don't assume. If you really want to know, find a place that can strip the chrome chemically. Then you'll know. Were it me, I wouldn't ride it until I could trust it.
DD
DD
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 226 Post(s)
Liked 309 Times
An alternative to chemically stripping (hydrochloric acid typically) is to utilize a reverse electro plating method that may be easier to control.....read that to mean less risk of removing the base metal. Details abound on the web. If you are not up to doing this yourself, a chrome plating shop could.
Like DD, I wouldn't ride this until I knew for sure......I'm an old guy that takes a long time to heal up!
Dean
Dean
Roll Me Up and Smoke Me When I Die
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
OP,
Just a thought, could you build a well with artist clay and fill the void with rubbing alcohol/acetone to see if it flows into the crack? I am not sure but it would seem that the liquid would flow freely/rapidly into the crack before evaporating.
As others have said I would not ride it until I was sure that the frame was safe, a crack in that area of the frame could be dangerous.
Best, Ben
Best, Ben
Voltaire
Voltaire
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
Gentle flexing, especially when paired with liquid penetration, should tell you the story. Stress on seat stays is slight so I would not be too concerned about riding. If it is indeed a crack, riding should pretty much verify it.
Too bad it's not on the drive side - you could cut the stay and install a belt drive coupler.
Quoted: 60 Post(s)
Liked 10 Times
So, I don't know if there's a crack in the steel under the chrome, but there is definitely a hole there... Not sure what this means in terms of cause, but I guess I would need to get rid of the rest of the chrome to see the whole problem.
When I recieved the frame I noticed that I could flip the frame over slowly and it'd sound like a rain stick. I thought this was brazing material in the frame, but maybe it has to do with this? Anyway, I don't know what my options are at this point to make the frame usable.
Quoted: 1639 Post(s)
Liked 829 Times
Seems like you might have a big rust problem inside that stay and maybe other tubes on that frame.,,,
That seatstay is shot......
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Muriatic acid will remove chrome. I have used it on cable stops, but it can be uneven. I would go with plater doing a reverse process. When I have see chrome crack (shell only) it is almost always smooth, not ragged like that.
Grinder will work also, the Dremel might be too precise and grid another hole.
Shawn
Shawn
Bikes: Too many, but sometimes not enough.
Quoted: 225 Post(s)
Liked 18 Times
Bummer - that seatstay is a goner. Did you make / enlarge that hole, or was it received like that? (The crack very well could have been initiated at the edge of that hole if the seatstay was under tension.) Bad internal rusting would just exacerbate the situation.
Unless this is a very special frame, It's probably done. You are looking at probably north of $1000 to have that seatstay replaced, and the rear triangle re-chromed. (To do it right. Probably still $200-300 just to get it fixed to where you can rattle-can it and ride.)
Even worse, that kind of rust usually doesn't happen in a vacuum. I doubt the other seatstay is any better.
Quoted: 1372 Post(s)
Liked 1,751 Times
Unless the frame is exceptional or really really wanted, it would be considered toast, in my book. Yes, it can be repaired, but at considerably cost, particularly if you want to re-chrome anything.
As for riding the bike - not a snow ball's chance in, well you know where. The bike is unsafe, in my opinion. Sorry to bear this news. I have been there, more than once and it is disappointing, to say the least. If the sale was through Ebay, you will be able to recoup your cash. If not Ebay, I don't know what to suggest.
Quoted: 60 Post(s)
Liked 10 Times
Well it's a pretty nice frame, but I guess not worth fixing if it ain't easy. I'll have to find another one since the build was basically complete. Does anything from the pre-shipping pics suggest problems? If the frame hadn't of gotten messed up in shipping, I would have already been riding it, how would I have known it had damage inside?
I have more pictures, but the uploader is acting weird... Let me know if you want to see any other details.
Liked 4,824 Times
Well, the plot thickens...
It appears to me that someone drilled the hole to prevent propagation of the crack. It's not an original vent hole because one can be seen about an inch above the crack.
It's obvious now that the crack didn't occur during shipment. Are we getting the whole story?
DD
DD
Quoted: 60 Post(s)
Liked 10 Times
And then it was chromed over? Here's a picture of the same area before shipping:
Liked 4,824 Times
The first post tells us about the crack. Nine posts later we are presented with another view of the crack with a hole - this was never mentioned previously. Now a photo that doesn't appear to show an additional hole on the NDS seatstay. Was the hole there when you received the frame? I ask because you made no note of it at all in your initial post, and that is somewhat surprising given you're looking to find out if the frame is structurally sound or not.
The only reason to drill a hole at either end of a crack is to stop the crack from getting bigger. If that hole/crack combo was there when you received it and he didn't disclose, you should get your money back.
DD
DD
Quoted: 60 Post(s)
Liked 10 Times
I used an exacto knife as you suggested to probe the crack, and the hole is what I found. It wasn't there in the pictures before shipping. I didn't notice the crack until I was realigning the dropouts due to shipping damage (the axle slot was closed up a little, the adjustment screws were bent, and the dropouts were not parallel). So, basically, most of that hole was under the chrome.
I am potato.
Quoted: 1789 Post(s)
Liked 1,629 Times
If you poked at the chrome with the X-acto knife and got a hole out of it, then the metal has rusted away to nothingness from the inside. My thoughts are rough handling in transit was the straw that broke the camels back exposing the invisible. I am hesitant to lay blame with the seller in this case.
Had the seller taken proper precautions with shipping you would be riding a ticking time bomb and never known it. Given the seller compensated for shipping damage already, I take that as a good faith effort. It sucks that it turned out to be a bad egg.
Liked 4,824 Times
I haven't a clue now what's going on here. I'm unsure of the timeline and who's done what. I am skeptical that chrome's properties would allow it to mask over a pre-existing hole. The manufacturer's vent holes aren't closed by the chrome and they appear of smaller diameter than the crack-stopping hole.
DD
DD
I am potato.
Liked 1,629 Times
It wouldn't have masked over a pre-existing hole. The hole didn't exist until just now. The hole would have began on the back side and progressivly developed over a long time. The chrome was the last few .0001 inch before the rust/corrosion pitted all the way through from the inside. Messing with the drop out only exposed a problem a long time in the making.
Basically, there was water in there at some point, an electrolyte formed by some minerals and oxygen then bonded with the iron atoms until...well, no more bike. It was never visible from the shiny side because outside the tube is a different environment than inside. Short of an ultrasonic inspection or a borescope the eroding wall would never be discovered until a service failure.
I consider the OP lucky he dodged a bullet.
Quoted: 225 Post(s)
Liked 18 Times
It sounds like the inside of the stay was rusted almost all the way through. The shipping damage, or re-alignment efforts caused the remaining steel + chrome layer to crack leading to the initial photo by the OP. The OP then dug out and formed the hole at the end with an x-acto blade top.
It doesn't sound the the seller really did anything wrong, other than poorly packing the frame. If you look at where the vent holes are located, there appears to be a good 1.5" below them for water to sit. Every time it was ridden in the rain, or washed, you could have a large slug of water that might take weeks to evaporate. Even worse, plating acids and salts if not washed out really well will cause rapid corrosion, often to the point of tube failure. That large cavity under the vent hole may have lead to poor inital cleanup, and a good dose of hygroscopic salts sitting there waiting to go to town.
Quoted: 60 Post(s)
Liked 10 Times
So, is the rain stick effect an indicator of this or could that indeed be brazing material inside the frame?
I guess I could still try to remove more chrome to see what the rest of the stay looks like. Having a frame rusted on the inside when the outside looks pretty good must be fairly rare, right?
Quoted: 225 Post(s)
Liked 18 Times
