What size seatpost is in your Raleigh Technium?
So I have this Raleigh Technium I am tuning up for a friend. It has a 25.4 suspension seatpost which seams awful small. What size seatpost is this frame supposed to have? Thank you.
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 77 Post(s)
Liked 196 Times
If you pull the suspension receiver out, it is probably marked for it's size.
mines a different kind of technium, but it's a 26.6
Quoted: 2331 Post(s)
Liked 5,047 Times
Mine has what was the original (if I remember correctly) Sakae 25.8 seatpost.
Here's the build thread on it in case any of that helps you.
https://www.bikeforums.net/classic-v...decisions.html
And one pic of it as I've got it set up. I think it's a beautful frame and the few rides on it have been quite good.
Steel is real...and comfy.
Likes For jamesdak:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1301 Post(s)
Liked 942 Times
All of the Techniums that I have seen, in-person, were 26.8. All of them were road models.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Liked 5,047 Times
I'd get an actual measurement done before spending good money on a 26.8 seatpost. We have the same model and I tried 3 different 26.8 seatpost and none would even think about going in. That's the only reason I stuck to the heavy Sakae it came with. I saw a lot of references to various Techniums taking a 26.8 seatpost while googling things on mine. But just not the case with mine. Remember, the various Techniums used different lugs/tubes per model so I wouldn't expect them to be the same across all models.
But if you do get a 26.8 to go in I want to hear about it.
Standard Member
Liked 942 Times
You two have a later model than I do. My stays are "fastback", but they are not "shot-in" like yours. I'm a little surprised, hearing that they reduced the diameter of the seat-post, but you never know. Is yours the Easton E9 tube-set?
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Quoted: 87 Post(s)
Liked 776 Times
My 1988 Technium Tri-Lite with 6061-T8 tubing has a 26.8 seat post, not sure this helps as your seat cluster and seat stays are similar but not the same.
Liked 5,047 Times
Likes For jamesdak:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,297 Times
I have a 1990 "753" Technium frame, parted from their highest model (which also happened to be the lowest-priced bike having a full Dura-Ace STI gruppo that year at only $1995.00).
The seatpost is 25.8mm and the frame's seatpost clamp bolt was the non-metric 10-32 size (since chased out to M5x.8).
Likes For dddd:
Señor Member
Quoted: 1497 Post(s)
Liked 1,099 Times
There are at least two "flavors" of Technium. One variety has aluminum tubes attached with steel lugs. The 26.8 seat post fits this sort. A second variety has steel tubing attached to aluminum lugs. The aluminum lugs have thicker walls. My wife's 91 Team has a seatpost size of either 24.4 or 24.6.
The Author's picture seems to show an aluminum tubed model with a sleeve for the seat post. That's a new one for me.
Death fork? Naaaah!!
I have the same bike, 25.8 seatpost.
Top
Top
Likes For top506:
I have a steel tubed, aluminum lugged Competition from 1990 and it takes a 25.8 mm seatpost. I just pulled out the original seatpost and looked at its stamp to confirm.
All the people who have pointed you with their direct experience with Techniums to 25.8 mm are right, which is why the 25.4 post you discovered sort of fit after the lug was deformed and over tightened.
