#9426
Quoted: 3241 Post(s)
Liked 2,512 Times
On a unrelated note, the black Turbo frame did not come with a seat binder bolt/nut. The Miyata and the Lotuses have hexagon bolts. Looking around, I found out that the metal nuts on a tube will work. If you need to McGuyver something, put 3 or 4 on there and go for it. I took the bolt and nut from the blue Turbo and headed for Lowes. The screw and bolt are M6 x 1.0. The bolt is 8mm in length. Lowes had the screws in similar sizes and In stainless steel. I found some coupling nuts that would work, but only in hexagon shape. They were 20mm and I would have to cut them to length. I got back home and checked the Zon. The Zon actually had stainless steel round coupling nuts in various lengths. One happened to be 8mm. I ordered a pack. All I have to do now is cut the notches for the tightening tool. Sweet!
It turned out to be a blessing in disguise. Now there's a source for a fairly common part that can't be found anymore. The 8mm length comes in a 25 pack. I have 20 something that I can send out to people that need them. I'm going to put up a thread on it.
#9427
Quoted: 378 Post(s)
Liked 1,409 Times
#9428
Liked 2,512 Times
Like I said, I ended up finding a source for a part thought to be extinct. Do you need any? I got a Christmas card heading your way and can throw some in. I'm still working on the copy of your letter to the Richmond Times Dispatch. They've been closed to the public since the Rona 19er hit.
#9429
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
#9430
Liked 2,512 Times
Well I've learned something today. It's a strop, not a strap. I've heard the generation above me talking about getting disciplined with one. Yikes.
#9431
Quoted: 378 Post(s)
Liked 1,409 Times
Where I grew up it was expected. There was honor involved. At school, social activities, etc, if a disagreement broke out it had to get settled. Males, females, it didn't matter. If a fight broke out, it would be broken up .....until the band went on break. Then the two would have to go outside and get to it. They couldn't get out of it. The crowd would form a big circle to prevent the fighters from getting into something really dangerous. Then they would go until it was finished. Just like Philo Beddoe and Tank Murdock. At school, the fight would be broken up and the offenders would get sent to the principal and get paddled. But as soon as school ended, it was down to the first dirt road south of the school. It had thick sandy soil so a fall would not cause injury. Then they had to settle it. Some days there would be multiple "matches" on the docket. Sometimes multiple fighters on each side. As long as the sides were even, it was a go. Friday night fights and WWE all in one! It was some good entertainment and kept the violence down. A person kept their honor by towing the line even if they lost. And, they found out it wasn't any fun, even if they were the winner.
The female fights were always the best. Much more drama and flair. Lots of hair pulling.
I’m short.
Punching up into an open mouth may hurt him, but you are gonna hurt your hand.
Count on it.
Elbows, man, elbows.
Good boots help.
My younger brother was better, and faster.
He went for eyes, ears, vitals, right from the get go.
Fight him and you were going to pay.
He’d have been a great cyclist, a real fighter.
He could outrun me and had to, more than once.
My other brother is the hockey puncher.
Grabbed a collar, hair, whatever, but he grabbed and hammered until he could not.
Like fighting a mule’s butt. He took whatever came until you were out, or he was.
#9433
Liked 2,512 Times
Edit: I reread your indoor thread. I might have to take a closer look.
#9434
Quoted: 378 Post(s)
Liked 1,409 Times
How do you mount and get started in an open space? Just like you would a regular bike? Can you connect it to a training program and control the resistance? I could see it working at my house. The wife and I are close enough in height that we could use the same bike. Something in the middle with adjustable/QR stem and seatpost. Get me one of those Major Taylor sliding stems. Heck, the coolness factor alone would make me a better cyclist.
Not like a regular bike, since it doesn’t roll, but you get used to it with a bit of practice. Before I start, I have to get Zwift to pair the HR, cadence and speed sensors, so I’ve already got it in big/big so I can spin up right away.
There are a couple of resistance units available for it, but as add-ones, they require you to also have a power meter, which I do not and will not have. I doubt they are reliable, but most are relative to themselves; I.e. they are consistent with themselves but not other power meters. For example, an FTP session on Zwift is 20 points below the same session on CompuTrainer’s program. The most accurate power is read from the crankset, and almost all trainers read from either the rear axle or rear wheel (pressure) cylinder. They are all different, but most are pretty consistent in their own system.
Where rollers succeed beyond trainers is in technique. They will make you a better rider. They are not yet there on resistance matched to a course. The market is small, and advances may not be worth the investment to achieve them. If advances can cross over from the red hot smart trainer market, they will, in time. At present, you are on your bike, using your gears, with a rough measurement of your stats and a roughly simulated course. Incline/decline are not currently available. Resistance requires a power meter and an add-on to the rollers.
Where trainers succeed beyond rollers is data that’s useful. They will make you more fit and more aware of your fitness parameters, and you can specialize the training. The market is focused on the software side of smart trainers. You can literally go for a ride and record the video, map the route, send it off, and get back a pixeled course that you can ride indoors, matched to mapping, elevation, and with video based on the real video you shot. Ride it several times, send it off each time, and the software course gets closer and closer to the real thing. You are on a real bike, simulating a real route, but the choices of gearing are unknown.
Where spin bikes will succeed, possibly, is in software plus real-time tech. My TdF ProForm 5.0 has 2/3x10 Di2. It knows what gear you are in, once you program in your bike’s actual gearing. It can measure power, cadence, speed automatically. It has +/- 20% incline. It uses drop bars and your saddle and pedals. Once it can talk to Zwift, it can increase/decrease resistance and incline/decline per the route, and even coast, based on the terrain. It can analyze your power per gear selection. You are basically duplicating your bike’s gearing and fit on real simulated courses.
Advances are out there and coming. Inside Ride has a cradle for a smart trainer, which makes the bike act a lot more like a real ride. They also have a fork mount that swivels and rocks, for their rollers. It does take away some of the real bike feel, but you don’t fall off. Kickr Axis are feet that allow the trainer to tilt like a bike, but only for wheel-off (direct drive) trainers. Kickr also has an automatic incline/decline fork mount, in case you want that. Put the Kickr Trainer model on Axis feet, an Inside Ride cradle, get the incline/decline fork mount, put it on a swivel base, and you are as close as currently available to a realistic ride, on your bike, on simulated routes.
I can’t see rollers going to incline/decline, but you never know. That might require dual rollers up front. Resistance, currently matched to a power meter, will eventually come via the route software. That would probably eliminate any pressing need for incline. Your gearing is irrelevant unless some coach dictates it (they do).
Spin studios have too much invested to give up the market to in-home, so they’ve already expanded to those (Peloton, for example is both in-home and in studios). We’ll see where the money goes on the advances.
At present, nothing beats my rollers for what they improve for me. I want to be a better rider, and develop a better “stroke.” Any spin bike, studio bike, trainer, or roller can get your legs in shape, your lungs in shape, and you can tailor any session to get you more fit in a specific way. If you have good technique already, rollers aren’t necessary. Only rollers can improve your technique, IMO. I can outclimb my current group, for the most part. I can’t outrun them. That’s going to take better technique.
If I had technique like Doc, or nomadmax , ldmataya , or Chrome Molly , I could just work on climbing and maybe speed. But I don’t, so getting the most out of my power is more or less getting better at riding.
Likes For RobbieTunes:
#9435
Liked 2,512 Times
Doc has the technique.
Isn't there(for the people with lots of coin) a treadmill made for you to ride a bike on? I thought I saw something on professional riders using one. Suddenly, this image popped into mind my of a set of rollers/trainer shaped like a hamster/pet wheel. It would take up too much space. I still like the idea I posted in your Indoor thread about the fake setup I was going to make with commercial rollers. That would be a really cool setup for the day I was going to film the video/pics to troll with.
I just thought of another stocking stuffer. It's pricey, but will fit into the stocking. Your pic made me think of it. Better go post it.
Notice I didn't mention it. I have to build up the suspense and drive people to your other thread.
#9436
Liked 2,512 Times
#9437
aka: Dr. Cannondale
Liked 3,404 Times
Interesting side point: but
The TACX Training App has a workout option that basically sets up your trainer in ERG mode but provides a graphic readout of stroke by stroke output.
Which sounds kinda dirty, but actually helps the rider smooth their output left/right and up/down if I understand correctly.
Keep the line on the screen level and straight and output is smooth.
Hills and valleys? Not smooth.
It ain’t exciting but it helps if you listen to JJ Cale.
Loud.
Loud.
#9438
Quoted: 1561 Post(s)
Liked 1,734 Times
Sun race 13-28t freewheel:
it just fits! No need for any washers or dishing or anything else. Time to put my STI shifters on!
I just noticed I forgot to take that clear plastic spoke protector thingie (does it have a name?) off. Oh well.
Likes For icemilkcoffee:
#9439
Liked 2,512 Times
#9440
Just s reminder, and it may apply to you, I have a 13-28 7 speed Dura Ace freewheel on my MV and I had turn the B screw all the way and pull my wheel way back into the drop outs to make it shift properly.
#9441
Quoted: 378 Post(s)
Liked 1,409 Times
We don’t discuss such things in the Ironman Empire.
Every day is a holiday. Every meal a feast.
Every woman lovely, and every dog a beast.
Ironman.
#9442
Quoted: 4559 Post(s)
Liked 2,802 Times
I call it the cool kids disc. When conditions are just right and I'm flying down the road I can hear it playing the Queen of the Night aria from The Magic Flute.
Likes For canklecat:
#9443
My '85 Ironman is the only bike I have with the spoke saver disc, it has all the components from a '94 trek 2200. So it's all campagnola even the hubs. However the rims are matrix (made by trek?) And the.. umhuh ...disc is Shimano. I accidentally left it on because it was so small and didn't notice it.
#9444
Death fork? Naaaah!!
Top
#9445
Liked 2,512 Times
#9446
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,832 Times
You guys need to search Seattle CL for 60cm Ironmans. Pink & Yellow complete bike and claimed 60cm. (and now I see one in Portland, as well). Purple & White frame+fork+bits, also 60cm.
Get 'em for theWinter/Holiday Project,
#9448
minimalist cyclist
Bikes: yes please
Quoted: 1119 Post(s)
Liked 1,641 Times
#9449
Liked 2,802 Times
Are those the type of grip shifters that are intended to be mounted on the ends of aero bars? I've never seen any that were transparent or translucent like that.
