Share those “Oh crap!” Moments Working on Bike
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2634 Post(s)
Liked 5,776 Times
This morning I removed the old Garmin bar mount for one that attaches to the stem. Had the mount positioned correctly was alternately torquing the bolts when the left one (6 nm) just started slipping and wouldn’t grab. Oh crap! No purchase what so ever, and it wasn’t cross threaded. Thought today’s ride was doomed.
Removed the bolt and didn’t look bad, but tossed it anyway. Had a spare and used that, and no problemo it went in and torqued right down. Didn’t want to have to buy a new stem or rethread it and put in one over size - what a pain.
Then there was the barrel adjuster on the rear mech that I over tightened using a pair of pliers that now only spins and does nothing, unless I use said pliers to grab and squeeze it. Don’t know if Shimano even sells a barrel adjuster assembly. Probably should take a look - and stay away from pliers in the future.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For ScottCommutes:
Bikes: Lemond Zurich/Trek ALR/Giant TCX/Sette CX1
Quoted: 597 Post(s)
Liked 833 Times
Hand dcrewed the bolt that holds my disc brake into the fork - went in smooth, no issues. First turn of the torque wrench and the threaded adapter inside of the fork just started spinning.
Klaatu..Verata..Necktie?
Quoted: 10507 Post(s)
Liked 12,047 Times
Putting the stem and bars on, then the levers, measuring carefully to get them in the right place. Carefully cutting the housing to just the right length, an running the cables. Then discovering you installed the stem too low, and you need to raise the bars about an inch and angle them up slightly so that my perfectly sized housing is now somewhat strained.
Spending 5 minutes working a beautiful Cinelli 1A stem onto a pair of Highway One bars, only to discover it won't clamp because the bars are 26.0 and the stem is 26.4, which I knew when I bought it and subsequently forgot..
Spending 20 minutes working a beautiful SR stem onto a pair of Highway One bars, only to discover they won't go onto the swelled center of the bar, because the bar is 26.0 and the stem is 25.4, which I knew when I bought it and subsequently forgot.
Carefully removing some lightly-used brake cables after dabbing some glue on the cut end so that you can reinstall them when you put everything back together, and then when you go to put everything back together discovering that there's a blob of the glue on the end of the cable that makes it too big to go back into the cable housing.
Pulling the above blob of glue off the cut end of the cable and trying to put it back through the housing, and ONE STRAND of the cable gets caught on the housing and bends so you can never, ever get it to lie flat and fit down the housing again.
Getting a flat on a ride, pulling the wheel, working the bead off the rim, pulling the old tube and carefully replacing it with the spare in the saddlebag only to discover the valve is too short for the pump head to grip it well enough to pump the tire up. Pulling that back out, getting the old tube and finding a "snake bite", insta-patching that, putting the tube back in and finding the tire won't hold pressure. Then repeating that two more times.
That last wasn't so much an "Oh, crap!" moment as it was a series of "Aww, ****!" moments.
One time I hacksawed a steel steerer with the star nut inside. Sawed straight through the star nut and had to hammer in a new one.
Mother Nature's Son
Quoted: 855 Post(s)
Liked 1,448 Times
Too many, too often, some that I don’t care to share. I will say that the ones that get repeated are the most frustrating, and bring out the self flogging.
Likes For delbiker1:
Quoted: 2624 Post(s)
Liked 1,966 Times
Some years back, I was tasked with collecting "lessons learned" (an institutional requirement). One co-worker told me, "I never say something was a lesson learned. It may have been a lesson available for learning, but I've never seen this organization learn a lesson."
Likes For pdlamb:
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 299 Post(s)
Liked 685 Times
Trying a new BB for size on a newly painted frame.
Decided to tighten the crank bolt before checking the clearance to get an accurate measurement.
Through the paint on the chain stay down to the metal.
BB works perfectly with a 3mm spacer: 2 mm gap instead of -1mm.
Chain stay paint fixed 3 months later..
Liked 12,047 Times
Horse....water...drink.
Quoted: 830 Post(s)
Liked 1,968 Times
A couple times I have made changing a flat into a lesson of futility.
First time, double flatted when I could not locate the cause of the puncture. Finally, went over the rear tire painstakingly to find a sliver of steel embedded in the tread only visible when flexing the tire.
Second time, bent two Presta valves with a faulty minipump (likely user error).
A roadie graciously gave me a tube and a CO2 cartridge to get back to my car.
Clark W. Griswold
Quoted: 4437 Post(s)
Liked 4,086 Times
Usually it is poor routing of a chain through a rear derailleur I will sometimes just do it mindlessly and then realize oops wrong way. It doesn't happen super often but every once and while.
Quoted: 233 Post(s)
Liked 323 Times
Broke an aluminum chain ring bolt because I didn't appreciate the difference between greased and dry torque specs. Fortunately I was able to "borrow" one off a crankset I wasn't using in order to make the next ride.
Likes For CrimsonEclipse:
Cantilever believer
Quoted: 554 Post(s)
Liked 1,920 Times
Finding the "perfect" crank on a used frame. Pull the bolts, start the puller, feel significant resistance, stop, apply penetrant, wait. Try again... and watch the puller "pop" out, taking the little aluminum shavings of the former threads with it.
And many years ago getting in a hurry installing a bottom bracket, and realizing that I cross-threaded the fixed cup. Put it back in straight with copious amounts of blue Loctite, and it seemed to hold. At least for a while.
Cantilever believer
Quoted: 554 Post(s)
Liked 1,920 Times
*cough* JB Weld *cough*
Likes For RCMoeur:
Cantilever believer
Quoted: 554 Post(s)
Liked 1,920 Times
Cantilever believer
Quoted: 554 Post(s)
Liked 1,920 Times
Er, um, that's what I meant. Fixed several broken racks that way. And they've held up OK. Another application of those reinforced concrete classes I took in college.
They do not get lost. They know exactly where they are going. They bounce deliberately and end up in a nook or cranny where they know they will stay well hidden. A few even made it to the floor drain 12 ft away
Oh, and their friends, the tiny screws as well
Grupetto Bob
Liked 5,776 Times
Epilogue to the new computer mount: Was about 25 mile into today’s ride and the bars slipped down while braking and hitting a bump. Got out the multi-tool and snugged the top two bolts, but did not use a ton of force because didn’t want to over-tighten and strip another bolt and be screwed so many miles from home. After another 10, rolled into a bike shop and asked if I could borrow their torque wrench. They said, they would prefer to do it and took one look at the bolts and said the top and bottom bolts were not equidistant and they were also at a slight angle - so they removed the computer mount and said it was a Scott mount and would never mount up correctly to my stem. I told them to s-can it and to fix my poor job. I insisted on paying for their time even though they said, “no charge”.
So now I am out $15 for a bad mount
$27 for the repair
1 stripped bolt
And now the old Garmin mount will be reinstated like before. Luckily all of it together was cheap and I didn’t crash when my bars slipped. Doh!
$27 for the repair
1 stripped bolt
Likes For rsbob:
Quoted: 341 Post(s)
Liked 281 Times
-Used a crank arm puller and forgot to remove the bolt that held the arm.
-Mounting tires with the rotation arrow backwards.
-Cutting a threadless steerer tube a wee bit too short.
-Mounting an inner tube with a double twist in it, so it's like a balloon dog inside the tire.Hey it was OK til I had a punctture a year or too later,
-Cutting a little metal off a seatpost tube to allow a lower seat and finding that the remaining stub was too thick for a quick release clamp. Had to use a boot on clamp.
Commuter
Bikes: Main Bikes: 2023 Trek Domane AL3, 2022 Aventon Level.2 eBike, 1972 Schwinn Varsity, 2024 Priority Apollo 11
Quoted: 289 Post(s)
Liked 390 Times
I did The Classic noobie mistake a few weeks ago.
I had my new bike up on the work stand. Wanted to change the stem. Anyone with experience knows you don't do that on a work stand.
I took off the stem cap and the stem and all the head tube innards and spacer rings and washers from the top dropped out all over the floor. I didn't find one spacer ring and had to buy another one.
Lesson learned.
Lesson learned.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 343 Post(s)
Liked 242 Times
Lesson learned.
Lesson learned.
Likes For Wileyrat:
Bikes: Santa Cruz Blur 4 TR, Canyon Endurace cf sl, Canyon Ultimate cf slx, Canyon Strive enduro, Canyon Grizl sl8
Quoted: 241 Post(s)
Liked 1,003 Times
Had one of these moments today...back story, I got my new Canyon Ultimate last month. It has the adjustable-width handlebars and I was certain I had both sides lined up correctly when I put the bars together.
Anyway, fast forward to today and I cleaning up the factory bar tape that started to come undone on one side. One thing led to another and I decided to narrow the bar position. That's when I discovered the I'd been riding around the last 400 miles with the right side about 10mm further away from centerline. I'm embarrassed I didn't notice it while riding, as I'm picky about bike set up. Anyway, got my bars set at 39cm width, with both sides equal.
Grupetto Bob
Liked 5,776 Times
I too cannot tolerate any issues and immediately have to fix them 100% or kill myself in the process getting it right. Rear mechs are my specialty.
