Post/I.S.?mount, steel, curved fork blades: Min wall thickness?
130lb rider considering getting a fabricated, curved mid-trail, qr, disc fork.100mm. To pair with a frame also.
Have read about the Kaisei blades that Jan Heine sells for rim-brake builds, but I'm wondering how thin a blade type I could go for disc, at my weight?
Something that would give some kind of plush ride, but can still be suitable for disc brake forces, but not be too noodly when braking forces applied.
Suggestions on blade models would be appreciated. 29x2.2/24 tyre on light carbon rim.
blahblahblah chrome moly
Quoted: 1181 Post(s)
Liked 2,576 Times
Maybe look at a Lauf fork?
Here's what you don't want:
That third one was a drum brake, but it shows that even a disk brake mount that attaches a bit further up the blade (e.g. Willitts style) may not save you.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
^ What Bulgie said. Also, ask your self how much compliance you need with a 2+ inch tire? You will never notice a compliant fork with that much tire.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Quoted: 321 Post(s)
Liked 263 Times
Likes For guy153:
Randomhead
Liked 3,701 Times
Torch and File has a lightweight Reynolds disc fork blade. Maybe ask your builder about using those. I hate their website so I didn't look to see if they have bent ones: https://www.torchandfile.com/reynold...-tip-pair.html
I agree that forks are no place to play games, but I weigh 80 more pounds than the OP.
Likes For unterhausen:
Quoted: 2338 Post(s)
Liked 2,827 Times
A disc fork to be save has to be built enough heavier that weight is noticeable and performance is not as good as a build for a rim brake. He advised against disc unless I had a very specific need like a lot of down hill riding in the rain
ymmv
Randomhead
Liked 3,701 Times
Turns out there is a bent version of those blades I linked. Cool hammer too. https://www.torchandfile.com/reynold...-tip-pair.html
Quoted: 27 Post(s)
Liked 9 Times
If you look in the Reynolds catalogue, the 631 and 853 curved fork blades that they say are "for disk" are 1.1mm wall compared to 1.0/0.6mm for rim brakes. Outer dimensions are 27.5/20mm oval. I would go for something in that kind of size (631 is about the same strength as cromoly) and wall thickness for a plush ride consistent with sufficient safety.
Likes For Nomad2:
