Storage
Bikes: 2014 Focus Mares AX 2.0, 2019 Cube Litening C:62 Race Disc Teamline
Quoted: 121 Post(s)
Liked 140 Times
Storage
Hey team
I have a do it all recreational and commuter - 2015 Focus Mares AX 2.0 - currently running 28mm durano plus.
I'm looking for storage to hold a set of clothes (undies, slacks, top, deodorant) etc and maybe even some work shoes for my commutes to work.
Caveat is, it needs to be easy to remove for the days i want to do a rec ride.
At this point of time i'm thinking a handlebar bag of sorts between the drops, but i really have no idea what i should be looking at. I trying to move away from using a cycling backpack so i'm free to enjoy the ride instead of feeling like a donkey.
Thanks in advance.
Thanks in advance.
Non omnino gravis
Leave a pair of shoes at work, they always take up too much space. Maybe you can get a small frame pack like what you would use for bikepacking. Something similar to the Specialized Burra Burra frame pack (and there are many other brands) should hold a change of clothes without adding to your wind resistance.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
There’s several kinds of “quick release” bags. Panniers are often held down to the rack with a spring or bungee on the bottom and hooks on top. Rivendell has something for large saddlebags that used a hub skewer. A handlebar bag can use a decaleur. Topeak sells a rack and bag system called MTX where the bag slides in and latches, and some of the bags are large... the one that came with my trike is a top bag whose sides unfold to panniers. And one of the racks is a seat post cantilever type that comes off with one pinch bolt.
Undoing a frame triangle bag isn’t that quick - it’s eight or ten 2” Velcro straps. But it does have the advantage of needing no rack.
Quoted: 1364 Post(s)
Liked 1,677 Times
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
Something like this: https://www.rivbike.com/collections/...ckville-bagboy
They have other sizes as well, but this gives you an idea. It'll take a little bit to futz with the buckles to remove, but just a minute or 2.
Bikes: 1969 Peugeot PX10, 1992 Della Santa, Linus Roadster 8, Biria 700C ST-8
Quoted: 794 Post(s)
Liked 508 Times
Non omnino gravis
I got a deal in a craigslist buy where I picked up a full set of Topeak MTX bags and racks and they are one of the best things I’ve bought. I have large and small bags with collapsible side Panniers and a basket all of which just slide on and lock into place on any of my MTX racks. I even have one quick release rack that attaches to the seat post and can be added or removed from my MTB as needed. I use the large rack for my commutes and can collapse or expand the side pannier sections as needed. I use the small bag when I want to go out for a ride but might need some extra storage for layers or think I might pick something up while out.
I have a separate carbon road bike so if I want to go fully light then that’s what I ride. If the weather is iffy, or I might need to carry stuff I take the aluminum/commuter/gravel bike with the rack.
Liked 1,677 Times
have a messenger bag i mostly use while going to work and just bought a couple of 45 cm bungee cords. tied some knots in order to shorten them and it worked pretty well. did use a third one on top to hold it down just in case, bust still way easier than my usual set up.
Quoted: 212 Post(s)
Liked 83 Times
A lightweight Tubus rack such as the Fly Evo or Vega Evo plus a single Ortlieb pannier. The rack (particularly the Fly) is so minimal you'll just leave it on all the time. And Ortlieb panniers attach and lift off in about two seconds. Removal is seriously just lifting a handle. This is my commuter setup.
Well, actually I have a Fly on my road bike and a Tubus Cargo Evo on my commuter. The Cargo is overkill for a commuter, though. I'll probably re-list it on ebay after I've found a Vega to take its place.
Liked 1,677 Times
Nice!
Liked 1,677 Times
If the rack were lower you might not need the top bungee, but this looks like it should work. In the rain you could just cover it with a plastic trash bag, which you could carry folded up in the bag.
i technically dont need to top bungee, but from time to time i get weird urges to commute like a jack ass at top speeds. so for those random moments i have that top bungee
Quoted: 1002 Post(s)
Liked 237 Times
Rear trunk rack plus pannier bags.
It's the solution that was specifically designed to address the problem you want to solve.
The bags hold securely to the rack when riding but pop off with ease (no bolts, snaps, fasteners, etc) when you don't want them.
For carrying a full set of clothes in a single pannier I recommend a minimum of a 15 liter bag. And that's it's you have small feet (and thus small shoes). If you've got size 11's or bigger make the minimum an 18 liter bag.
A pair of 15 liter bags (one on each side of the bike) will get most anyone through their day with a full change of clothes, lunch, a book, maybe a laptop, etc.
Quoted: 5224 Post(s)
Liked 3,581 Times
I'm a rear rack & trunk kind of person ...
Liked 237 Times
It's also worth noting that every option presented in this thread so far is a viable one that will solve the OP's needs.
None of them are stupid.
The 'best' one all depends on the OP's personal preference. OP, you can't go wrong picking the options here that appeals to you the most. You might change your mind 2 years down the road once you have more experience using the option you picked. But they will all work and the only thing that matters is which one YOU like the best.
I've been using an Ibera Pakrak bag and rack system. The bag will hold everything you said including the shoes. It has a solid locking system that can be attached/detached in seconds. I've been using the same bag for 3 years and it's still rip free and the zippers are still solid. I do use a rain cover in inclement weather.
Products | Ibera ? The Cycling Life
Liked 1,677 Times
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
If you have a place to store things at work, consider going a step further and bringing a couple changes of clothes with you at a time. Then you can have days off from transporting things and travel really lightly.
