Lezyne cadence magnet does not fit
Quoted: 10 Post(s)
Dear Bike Forums Users,
I bought a Lezyne cadence and speed sensor. Regarding speed, no problems (I don't mean that I am very fast - I mean that I successfully installed the magnet at the right distance from the sensor).
Regarding cadence, though, the magnet does not fit. I mean, the gap between the crank arm and the chainstay is so small that the magnet does not fit.
My question is: does anybody know the specs of that magnet? I can buy a smaller magnet with similar specs and glue it to the crank arm...
Or, if anybody had a similar problem, any ideas how to solve it?
Huge thanks in advance!
Quoted: 18373 Post(s)
Liked 4,508 Times
There is no need for the magnet/sensor to be at the end of the crank. It can go somewhere in the middle.
If you want to epoxy it in place, then you can pick up a small Neodymium disc magnet off of E-Bay for cheap.
Quoted: 10 Post(s)
Thanks Clifford!
The problem is, I don't have a ton of room if I want the sensor to overlap with the rear wheel to measure speed as well.
I guess I'll buy a cheap magnet then and McGiver it to the crank arm. Will ANY magnet work? Does it even matter if I flip North and South pole?
I guess I will give it a try :-)
Thanks again!
Thanks again!
I had the same problem. A small (1/2" diameter) rare earth magnet stuck to the pedal shaft did the trick.
Quoted: 3375 Post(s)
Liked 5,513 Times
I switched all my bikes to using Neodymium magnets stuck to the pedal spindle years ago.
Of course the pedal spindle needs to be steel, (and not titanium).
And if the gap happens to be too large, you can just stack 2 or 3 to close the distance.
Quoted: 7348 Post(s)
Liked 2,464 Times
Yes, any magnet is likely to work.
And for just this reason - the alignment of magnets with pickups - I got rid of all my magnet based sensors a couple of years ago. The dual sensors that provide one pickup for both the wheel and the cranks are the absolute worst too. I don't know how Lezyne computers work with sensors, but if you can can go to the sensors without the external magnets, then do it. The aggravation you leave behind is worth the hit to the pocketbook.
j.
j.
GiantTCR
5
07-23-15 11:00 AM
bigredkevbot
Bicycle Mechanics
7
01-20-15 12:07 PM
