One Man’s View Of Disc Brakes
#151
Quoted: 4717 Post(s)
Liked 1,882 Times
Discs: They make the rims more durable if you bike often in wet mess, the grit can wear through the rim sidewalls. For a wet-weather bike, I think a big plus. But pads are expensive.
Rim brakes: Replacement pads are dirt cheap, a bike shop near me has cartridge pads (with housings and inserts) for $4 a pair, but was out of them for about a year; When they finally got more in, I bought half a dozen sets.
Do you really worry about about spending an extra $75 per year on stuff like this?
Likes For noodle soup:
#153
Quoted: 20810 Post(s)
Liked 9,456 Times
He said "disc brake pads" failing. That's a far cry from fluid boiling.
#154
Quoted: 18883 Post(s)
Liked 10,646 Times
Pads fail all the time, but only ever with disc. That's why they're so popular, everybody who rode disc brakes is dead and can't tell us the truth. That's why Big Bike is forcing them on us.
Likes For Seattle Forrest:
#155
To be truthful, when I was first looking into a folding bike (because it fits in my tiny SRO), I wanted the cool one with discs but wasn't willing to spend twice the price. We have some long hills here and I was worried about the 20" rims heating up. But I've checked them after descents and they are fine. Later, I learned of the higher cost. But upon test riding a newer folder with mechanical discs, the wheels locked up incredibly easy, as the discs were designed for 26"+ wheels, not 20". Smaller road discs and hydraulics I think would be a necessity, but that ads complexity and field serviceability issues.
On the other hand, after about 5 years on the bike, the rim sidewalls are noticeably concave from brake wear. These are cheap rims, single wall, no hard anodizing, and several times a year I need to clean embedded aluminum bits from the brake pads, it think due to galling.
Discs would be nice. But if I ever get them, I'm going to use ones that have the most common, low cost pads, with good material selection.
#156
Quoted: 741 Post(s)
Liked 412 Times
When flying down a mountain pass, that is a distinction with the same consequence.
I thought maybe he was mixed up as I don’t remember pads being an issue ever. My point really was that was a very long time ago and those types of issues don’t exist today.
#157
https://www.wiggle.com/fuji-sl-23-disc-road-bike-2019/
https://www.wiggle.com/fuji-sl-23-road-bike-2019/
Its several hundred if comparing apples to apples.
#158
Liked 9,456 Times
#160
Liked 9,456 Times
Looking back at my comment, and the quote provided for context, I think it's pretty clear and that the failing is not mine. Cheers.
Likes For WhyFi:
#161
Likes For marcoguzm:
#162
Disc-equipped bikes are also theft magnets in my 'hood. Leave a carbon Colnago next to a disc Huffy, and the Hufster will get pinched every time.
Mind you, for their personal rides, the addict thieves tend to favour 50-pound full-suspension rigs (8" of travel front and rear with 3" knobbies) for riding around a paved urban environment with excellent roads. Big discs and largest rotors. Go figure.
#164
Liked 10,646 Times
#165
Bikes: Shmikes
Quoted: 10167 Post(s)
Liked 5,858 Times
#166
Quoted: 8279 Post(s)
Liked 9,033 Times
I think Shimano Dura Ace rim pads are at least that much.
#168
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
Brakes Campy SR, Campy Delta easy when you had the pull right (parallelogram). Most smooth carbon tubulars I would expect now. My current ENVE serrated surface rims - no way.
#169
Liked 371 Times
Point was the brakes alone did bend a steel Co-Motion tandem for in a panic stop.
A smooth clean rim with the right rubber sticks like crazy.
#170
Liked 10,646 Times
#171
Bikes: Shmikes
Liked 5,858 Times
#172
It would be prohibitively expensive or impossible to retrofit discs to my current bike, but if I ever buy new, I'll be looking for discs. Mind you, on a 20" wheel folder, in addition to needing a smaller disc or pad to prevent hair-trigger-lockup, disc rotors may be more susceptible to damage when transporting the bike folded.
#173
This thread has been an interesting read. I agreed with many of the viewpoints expressed in the video, though I found its style annoying.
With the exception of motorcycles I've never ridden disc brakes. I'm convinced of their utility, but I don't see myself getting a disc brake equipped bike any time soon. I live in a flat area, stay on paved roads, and only ride in the rain occasionally. For the time being, it makes a lot more sense for me to spend money improving my current bike with things like a power meter and better wheels than it does to run out and buy a brand new disc brake bike. If I build up my next bike from a frameset, it will have rim brakes too since that's what I know how to install and maintain. But if I buy an 'off-the-rack' bike, there's a good chance it will only come in disc brake format a few years from now. I'm fine with that.
Likes For McNamara:
#175
For riding in relatively flat and dry conditions, discs add a bunch of unnecessary weight, complexity and incompatibilities.
I was riding with a fast crowd yesterday on a ride that alternated between soul-crushing climbs and warp-speed twisty descents. With rim brakes and Scott brake pads, I was likely braking at the limits of wheel adhesion to the pavement. And this was on good dry asphalt. Good thing I was on rim brakes.
Likes For Dave Mayer:
