Old School Shimano Freewheel Remover
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Help! I've lost my (older) Park Tool Shimano freewheel remover, you know - the one they decided not to make anymore despite the fact that thousands of bikes still have the old-style Shimano freewheels. All ranting aside, I'm in a bit of a pickle and I can't find the one I JUST KNOW that I have around here somewhere. Can anyone give me a direction to search for a new one, or old one, Park or otherwise? Any help at all would be so greatly appreciated. Thanks!
Quoted: 2026 Post(s)
Liked 1,096 Times
The current Shimano cassette lockring tool is a very close (but not exact) fit to Shimano freewheels. Sometimes they work if the freesheel isn't on absurdly tight.
I have a genuine Shimano freewheel extractor (TL-FW80). If you can't find your Park or the lockring tool doesn't work, PM me.
aged to perfection
Quoted: 835 Post(s)
Liked 1,252 Times
tons of options on eboy. I think the FW 30 is compatible.
Mark Petry
Bainbridge Island, WA USA
Mark Petry
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
2-Wheeled Fool
Liked 677 Times
I think the OP is referring to the older, long deprecated Shimano splined tool, which is not at all compatible with the newer tool. Park, et al only make versions of the new tool. I'm not aware of any current production of this type of tool; it's only available on the used market:
Old fart
Liked 3,400 Times
That'll be the tricky part. I looked on my tool, and it is completely unmarked so I can't give you a part number to search for, and I bought it new forty years ago or so when they were readily available. But I can tell you it is 20.0mm in diameter (the new version tool is 22.6mm diameter) and has twelve splines.
Bon chance!
Update: I just took a look in an old United Bicycle Tool catalog and found that Bicycle Research made a version of this tool, described as the remover for "Shimano Boss freewheels." The Bicycle Research part number is CT-4:
Bon chance!
2-Wheeled Fool
Liked 677 Times
Funny. I had to go the long way around, but I actually found one on Amazon.
VAR
Better price than some of the NOS deals on the original Shimano tools I've found.
VAR
SE Wis
Quoted: 2745 Post(s)
Liked 3,390 Times
I just pay the LBS $5 to remove those when I encounter them.
Liked 1,096 Times
Insane Bicycle Mechanic
Quoted: 802 Post(s)
Liked 703 Times
Yep, Bicycle Research CT-4. It requires removing the axle spacer before it will fit so it's a bit of a pain to use. It's also the one that fits the Shimano FFS non-freewheeling "freewheel".
It's available here: Shimano Splined Freewheel Remover (pre-1985)
Jeff Wills
Jeff Wills
Old fart
Liked 3,400 Times
Further work finds the Shimano part number for the official tool: TL-FW20
