Was this how they built bikes in the 80s/90s?
Quoted: 551 Post(s)
Liked 419 Times
Whenever I encounter vintage Trek/Specialized bikes, I notice they always have 5mm wound housing for both brake and shift.
At first I thought the last guy that worked on the bike lazily used brake housing for shift because it easy, or bought it from Walmart, but I am seeing it on vetted virgin barn finds that have never been repaired and all original.
Was this standard for manufacturers to use universal housing for their bikes then? Or done only on mid/low-end bikes to save on costs, inventory?
Unless someone can say otherwise, I can't see 5mm housing correct for shifter use because that just creates imprecise shifting. Brake housing expects a 1.5mm cable. There's simply just too much room in there for a 1.1mm shift cable to flay around, which is why 4mm compressionless housing is correct.
Quoted: 3538 Post(s)
Liked 2,949 Times
If you mean was coiled cable used for derailleurs, that's how I remember it. You can still find some images using it (below). It wasn't until later that the "SIS" compressionless cable with linear wires came along (which, in a twist, some of us now use for brakes). Back then, we didn't have long lengths of shift cable exiting our brake levers. The 10 or 12 inches of coiled cable at the derailleur didn't compress enough to cause any great loss in shifting accuracy.
You can still find some NOS with coiled cable housing:
Likes For smd4:
Likes For MNBikeCommuter:
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 371 Post(s)
Liked 470 Times
The Gore-Tex one came out in the 90's. Man, that worked great.
I kick myself for not buying loads of it. Not cheap. Wonder if anybody has a source.
Liked 2,949 Times
Quoted: 96 Post(s)
Liked 293 Times
Likes For streetsurfer:
Bad example
Quoted: 839 Post(s)
Liked 243 Times
I'd say rather that the coiled housing was adequate at the time, but that even friction shifting is improved with compressionless housing.
I like running old coiled housing for my friction shift bikes. Can use the same stuff and I don't have to figure out which freaking ferrule I need......... Cuts easier too.
Liked 2,949 Times
Liked 2,949 Times
Quoted: 551 Post(s)
Liked 419 Times
As I don't do half-arsed repais, I just couldn't figure out why manufacturers made bikes chose to keep the same housing for both.
Liked 2,949 Times
Likes For smd4:
Quoted: 343 Post(s)
Liked 776 Times
It works fine for friction shifting, and also for 5/6 speed indexing. Once bikes starting using more gears (narrower cog spacing), the compressionless housing helped to make shifting more precise. It’s not so much the diameter, but the stiffness of compressionless housing that helps.
Likes For bboy314:
Quoted: 551 Post(s)
Liked 419 Times
I understand how frictionless levers are forgiving to even the worst housing setup, and similar could be said for vintage derailleurs where the indexing was on the derailleur.
I was just surprised to see the stock 5mm coil wound housing on vintage 8s groupsets. Yes I can't believe that actually used to work.
I'm one of those "keep it as original as possible" types, but I'm game for tossing out all new condition 5mm housing just to get proper 4mm in there.
Liked 2,949 Times
And yet it did, your belief to the contrary notwithstanding. Either way, I never cared if something as mundane as a cable housing wasn't "period correct," especially if it looks nearly identical, but functions better.
Quoted: 551 Post(s)
Liked 419 Times
I've discovered that with proper 4mm housing, RD alignment can be eyeballed and would work fine.
With the larger 5mm housing, I have to use my DAG-3 on it. I rarely pull out this tool for dumpster finds.
Dumpster finds also only deserve used housing, brake and shift.
And the new special housing for the Shadow type RD is also wound, OT-RS900. This is used at the RD run only, so usually quite short & straight and should not have much of an effect.
Additionally, the early SP (linear) was 5mm, commonly used for SIS groups through 8 speed, called OT-SP50/51.
Here is Shimano current line-up.
Likes For KCT1986:
Quoted: 551 Post(s)
Liked 419 Times
I don't doubt there is shift-specific housing that is 5mm coil wound, but all the ones I've replaced look identical to cable housing, which I've verified by cross-section cutting them with a grinder to compare what's in them and ID and OD.
Bike OEMs and shops may have neglected to use the 'approved' housing (wrong color?). This is what you may be seeing.
Suntour, whos system was very sensitive to poor setup issued a tech doc to help. They didn't like linear housing, probably because of the poor cutting method being used.
Excerpt about housing.
Quoted: 551 Post(s)
Liked 419 Times
I heard about all of the above before but didn't suspect as much until I saw more and more virgin vintage bikes lacking 4mm housing.
I try to spend the least amount of time necessary to fully repair a bike for resale, that often means adjusting derailleurs/brakes just once by experience, any problems after that are reported by the buyer when they require aftersales support.
That was when I started to make sure all shift housing were modern compressionless and the RD complaints all stopped after that.
I'm rather generous with the housing at that large bend at the RD, I believe modern compressionlesses are better today than the time of the docs above.
Quoted: 4448 Post(s)
Liked 1,585 Times
My recollection is that MTBs in the early '90s had coaxial housing that was 5mm. Shimano currently calls it SP51. I think this preceded 4mm by several years.
I don't think bikes with relatively smooth cable runs have any trouble indexing with brake housing. And downtube index shifters don't require anything special for that short length at the RD.
Old fart
Quoted: 3594 Post(s)
Liked 3,407 Times
Compressionless derailleur cable housing only became necessary with the advent of indexed derailleur shifting, in the mid 80s. Prior to that, friction shifting worked fine with the same type of housing used on brake cables.
Liked 2,949 Times
