KMC vs Shimano
KMC vs Shimano
I'm going to replace the chain on my bike but can't decide if I should go with the KMC X8 or the Shimano CN-HG71. They've both the same price where I'm from. The advantage of the KMC is the Missing Link while theoretically, the Shimano one should perform better since I have a Shimano Hyperglide cassette and it's the model of chain that Shimano recommends for it. Does anyone have any experience in the performance difference between using a matching manufacturer chain (with the make of the cassette) versus that of another brand?
Dirty Heathen
Quoted: 889 Post(s)
Liked 906 Times
I don’t actually have Shimano chains on any of my bikes; they’re either KMC or SRAM. No problems with Shimano cassettes/freewheels, or FSA, Suntour, or Sugino chainrings (don’t have any Shimano cranks)
I use KMC on my 7-speed bikes (Z-51)because I found a some for super-cheap, and SRAM on the 9-sp, because they weren’t as cheap as the KMC, but still less than the Shimano’s
Likes For Ironfish653:
Quoted: 1188 Post(s)
Liked 1,154 Times
Neither. Wippermann Connex
Recreational Road Cyclist
Quoted: 257 Post(s)
Liked 252 Times
Regarding quicklinks, the SRAM link included with its chains was fine. The KMC link included with its chain was defective and couldn't be used. One of the pins was not perpendicular to the side plate.
I tried the Wippermann Connex link with the Shimano chain, and it works well. Can be installed and removed without tools. I'd like to try the Wippermann chain but it's costly, and while I'm sure it's compatible with Shimano, it may not be optimum.
But they all shift.
Quoted: 523 Post(s)
Liked 230 Times
Shimano lists their HG CN71 chain as "Acera" level which is near the bottom of the line for MTB components so it is not a premium chain compared to the KMC X8.93. It's a lot easier to find the KMC chain at bargain prices on eBay or Amazon from bulk sellers who cut it from a large roll. I buy my recumbent chains (3 lengths of chain) on eBay where the Shimano chain in a fancy box is $25 for the 8-speed while the KMC chain is $13.75 with no box. Both include free shipping. Prices are similar on Amazon where I refuse to shop.
Shimano https://www.ebay.com/itm/254975967920 KMC https://www.ebay.com/itm/254757500023?
Likes For VegasTriker:
I have a Shimano CS-M771-10 cassette and it shifts better with the Shimano CN-HG95. I tried KMC and went back to Shimano. I also like the pin for the Shimano 10 speed chain compared to the KMC quick link. I never take my chain off for cleaning, so the reusable quick link was a waste. I also found out that the quick link will be the weak link in trying to get a chain to high mileage. At around 3500 miles the quick link pins had worn out the holes in the chain and the rollers were shot also. All the other links were fine. With a quick link you are putting two pins into holes in the chain that are not as tight as a pin(and you are only pinning one hole when using the Shimano pin). Never tried the Wippermann Connex, it might have better tolerances.
i had a gold shimano ug chain that came with my 84 stumpjumper, darn thing went for years, heavy climbing,
99 bucks on evilbay nowadays
sram seems cheaper than KMC, sram chain went for about 2000 miles and was toast.
i can get about 8 KMC chains for that, 99 dollar uniglide so KMC.
Shifting wise, either chain will work fine. But the Shimano chain will give you the quiestest mode of operation with Shimano cassettes. This is true up to 10 speed drivetrain.
But once you get to 11 speed drive train, then ALWAYS go with the manufacturer chain matching the manufacturer cassette. This is due to tighter tolerance between components.
Likes For aclinjury:
Bikes: 2014 Fuji Traverse 1.3, 2020 Electra Cruiser 1, 1995 Giant CFM-4
Quoted: 124 Post(s)
Liked 51 Times
Sorry to gravy train the thread but now I'm thinking I may want to try a Shimano chain next. I have a KMC X9 chain currently. My derailleur is a Deore 591 and cassette Altus 9 speed and crank is Acera if that matters. What Shimano chain do I need?
Thanks.
Thanks.
dang, how many watts? ^^
i throw away those quick links, they did not have those in the 70's and 80's, when did they make their ugly reappearance?
Likes For Papa Ado:
Quoted: 668 Post(s)
Liked 529 Times
I pretty much run nothing but KMC chains. They are excellent performers, priced right and available everywhere. They have yet to give me something to complain about.
Picking a chain to match the brand of cassette is pure marketing BS. Rise above the rhetoric and make an informed decision.
I run a mid-level chain in whatever brand is cheapest at the time. (Mid-level rather than cheapest, which is a superstition more than a noticeable difference) and have not experienced any funtional difference in performance.
While I have had 'quick-links' fail on me one or twice, that only happened when I made a very badly timed shift (arguably exactly when you don't want a chain to come apart!).
Though I've done no detailed analysis on chain longevity or function, I suspect that most of the differences in experience w various manufacturers might come from what each user is used to, maybe even the packing grease the chain comes with and not compatiblity or manufacturing tolerances.
I think all (most?) chain of the correct width is pretty much interchangeable.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
When peened pins with the ends nearly flush with the outer plates appeared, that's when. If you are pushing pins in and out of modern chains, you are looking for trouble.
Likes For Dan Burkhart:
With 11-speed, and now 12-speed coming, tolerance is tight. To the casual observer, KMC and Shimano chains here look almost identical, but close observation will revel that they have slightly different profile. This sligh difference is enough to cause noiser drivetrain, and it may be enough to cause issue when you're cross-chaining in the big-big gear combo, or when you pedal backwarks (the chain will off the cassette). This is especially true if the bike frame has a short chainline (ie, greater chain angle).
for the 8,9,10-speed stuff, it doesn't matter which chain you use
Quoted: 2325 Post(s)
Liked 4,993 Times
it depends. With 10-speed or lower drivetrains, the tolerance is loose so matching brand components isn't critical. Also, a frame with a longer chainline (thus a lesser chain angle) will be less picky about chains.
Then looking at my picture archive I can see I ran a SRAM chain with the Ultegra build of the NOS Vitus Argal. It worked great and was very silent once we fixed the problem of the FD rubbing on the crank arm. Very tight rear end and tolerances on this 1990's bike running that 11 speed setup.
Really short and tight rear end on this one.
SRAM chain/Ultegra 11 speed groupset.
Steel is real...and comfy.
Likes For jamesdak:
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
What is a KMC XL chain? That's not a model I recognize.
Well, my experience on at least 4 bikes running 11 speed setups says otherwise. I'm using KMC XL chains on them with no problems at all. One setup is Ultegra, one is Athena, one is Super Record, and one is a mix of Super Record.
Liked 4,993 Times
Likes For jamesdak:
Liked 4,993 Times
That said, why would you worry about such a thing? You're certainly not riding like that are you? You can't fault user error. I'll bet it jumps off too, to what end does that prove anything?
Just out of curiosity I did just try it with my Y-Foil running an Ultegra 11 speed setup and a Shimano chain. Guess what, it jumps off so staying with a Shimano chain still doesn't save you from user error.
I mean let's be honest, if you're setting up your crankset, RD, chainline to be able to cross chain at it's most extreme and backpedal then you might want to rethink what you are doing. Or is there a legitimate reason to be worrying about this? Asking honestly because I certainly don't know everything. Even if I did stay in a Holiday Inn last night LOL!
Quoted: 668 Post(s)
Liked 529 Times
I must not be the only one who thinks KMC chains are fine because the bike came shipped from the factory with one. Seems pretty common for factory bikes.
Advocatus Diaboli
Liked 1,533 Times
However, another thread around here, and it seems the case if you shop around online, has that KMC has put in MAP, so the X11SLs seem to now be $70 everywhere. So with Record or DuraAce chains close to $20 less, would you still opt for a KMC chain?
Liked 4,993 Times
I have an 11SL on my bike currently. Runs fine. No better, and I don't think any worse (but it seems to need lubrication more often.. is that possible). I only got it because it wasn't much more (~$5) than a Campy chain at the time and it was all silver.
