Looking for cranks that look like old stronglites
Old 06-13-23, 03:37 AM
trashbiker
Bikes: Lemond Zurich Record 10spd, Klein Quantum Race r7000
Quoted: 23 Post(s)
Liked 15 Times in 12 Posts
I'm building a fixie to honor my bikes that were stolen. I had a pair of stronglight cranks on my first bike and I think something similar would look good on this new build. I don't want to just get a pair of real stronglites because I don't want to deal with all the BS that comes with them like the pedal threading and 122 bcd. The cranks had 5 triangular arms with the middle of the arm cut out, kinda looked like a pentagram. I'm new to the forum so I can't add a photo. If there are single or double cranks with similar looking spider arms please drop a link. Thank you!
edit after some research, they were stronglight 93s
trashbiker is offline
Old 06-16-23, 03:51 PM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times in 407 Posts
Are you describing Stonglight Model 93?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
tiger1964 is online now
Old 06-16-23, 08:50 PM
Senrab62
It's the little things
Bikes: Too many, yet not enough
Quoted: 279 Post(s)
Liked 326 Times in 147 Posts
I believe stronglite made a model 93 Piste version. If you can find one, I'd assume it might be pricey. Not familiar with a modern version or equivalent.
What bike is it going on?
Senrab62 is offline
Old 06-17-23, 09:06 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
Stronglight mod. 49 also used the pentagram design for the outer ring. The mod. 49 crank used a 50.4mm 5-pin mount compatible with many other 5-pin cranks, from TA, Sugino, Shimano, Lambert/Viscount, Williams, and others.
JohnDThompson is offline
Old 06-18-23, 10:10 AM
TejanoTrackie
Veteran Racer
TejanoTrackie's Avatar
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times in 432 Posts
That's certainly a good solution to avoid dealing with French pedal threads, although I was easily able to tap two Stronglight 93 crankset French pedal threads out to English. I think the Stronglight mod. 49d cranks were also sold as TA Cyclotouriste.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Old 06-18-23, 07:48 PM
JohnDThompson
Old fart
No, the Stronglight mod. 49 and TA Cyclotouriste cranks could use each other's outer chainrings, but they were otherwise entirely different, and inner rings did not interchange. If you used a mod.49 outer ring on a TA crank, your inner rings would have to be Stronglight 122mm BCD. And if you used a TA outer ring on your mod.49 crank, your inner rings would have to be TA.
Likes For JohnDThompson:
Old 06-18-23, 07:54 PM
trashbiker
Quoted: 23 Post(s)
Thaks for the tip!
Old 06-18-23, 08:01 PM
TejanoTrackie
Veteran Racer
Thanks for the clarification.
Old 06-18-23, 08:04 PM
TejanoTrackie
Veteran Racer
Thanks for the tip!
You're welcome, and good luck in your quest.
Old 06-27-23, 03:42 PM
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
My first reaction was this IRD crankset: https://www.interlocracing.com/shop/...2923,1529,3097
It sort of has the right design cues.
Car dependency is a tax.
base2 is offline
Likes For base2:
Old 06-29-23, 02:13 PM
rustystrings61
Quoted: 823 Post(s)
Liked 1,395 Times in 694 Posts
A vintage suggestion - Nervar Star cranks. They used an odd 128mm BCD but you CAN modify 130mm BCD rings to fit, AND they take standard 22.0mm crank tools unlike the 23.35mm Stronglights. I’ve been running a set on my ‘73 Raleigh Competition with much success.
Later Stronglights made for 22.0 tools might be another choice.
rustystrings61 is offline
