Cannondale Quick CX Gravel Crank?
Looking to upgrade my drivetrain from stock Shimano Tourney/Acera 2x8 to to a 1X11 with a Shimano GRX 40T crankset and Deore XT or SLX derailleur. Curious if anyone has put a Gravel crankset on their bike. Curious if it makes a difference (gravel vs MTB vs road bike) crank. Main reason for looking at the gravel crank is the availability of the 40 or 42 tooth crank. Largest chainring available on the Shimano MTB crankset (according to the website) is a 38T.
Quoted: 576 Post(s)
Liked 1,003 Times
Likes For DorkDisk:
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 143 Post(s)
Liked 433 Times
More info would help and DorkDisc is pointing you in the proper direction.
What year and model Quick CX is it? That will help with your initial question.
Some googlefoo yielded these links:
https://www.******.com/r/bikewrench/...eplacement_on/
This is where things go beyond my knowledge.
The width of your bike frame where the bottom bracket goes is 73mm. The length of the rotating spindle on your bottom bracket is 122mm. The other numbers are the thread pitch - it's usually referred to as English threading or BSA threading and it's by far the most common pitch for threaded bottom brackets...
https://www.youtube.com/watch?v=oQrlb-tDgXk
Quoted: 576 Post(s)
Liked 1,003 Times
Sorry, I meant bottom bracket shell, as in the frame member. Road bikes use a narrower shell, thus narrower chainlines and Q factor.
This should be 68mm for a road crank
Likes For DorkDisk:
I see youre running a quick. I Didnt think that there would be that much difference between the quick and the quick CK. I figured the basic bike from the Neck back would be the same, Guess not
Deraill this!
Quoted: 143 Post(s)
Liked 433 Times
My Quick 1 Disc came with a FSA crankset and I upgraded the crank to 105 over the winter. FSA has their own BB and once I figured out the replacement BB and purchased the tools, it was a direct swap. I know NOTHING about the cartridge BB that the CX uses (and it seems like an odd choice to me).
I am also curious about the differences - geometry and component choice are definitely different.
Likes For bald1der:
Quoted: 576 Post(s)
Liked 1,003 Times
IRD offer a crankset that works with 73mm shells and can do 30/46 or 1x. You'll still need to check the chainring clearance with the frame and its a bit pricey.
Likes For DorkDisk:
Clark W. Griswold
Quoted: 4357 Post(s)
Liked 3,995 Times
I would highly caution against putting money towards a tourney equipped bike beyond enough to keep it safely riding. Save your money and get the bike you want it. If you want to build up a bike then get a nice frame and build something nice. Tourney bikes are not a good starting point they are designed to hit a price point and that is about it, it is rare the frame is much of anything and the fork is usually the same. Rideable till you get what you want but nothing to really spend morey towards.
If you are desperate to put money towards that particular bike I would look at CUES it is Shimano's new groupset designed to replace the low end Shimano with something lower cost but a little higher quality and from what I have seen here and there it looks promising. Save the XT build for a nice frame.
Quoted: 1400 Post(s)
Liked 1,883 Times
the current rear hub with 8 speed cassette might not permit a 11 speed cassette … some will permit a Shimano 11 speed MTB cassette with a 34t or larger big cog - but it can vary … ???
so - a new rear wheel might be required - or a new rear hub / freehub
so there is that
the crankset should generally pair or match with the rest of the drivetrain (including cassette) … so there is that …
so there is that
Liked 1,883 Times
Cruising through the old inter web and came across my old post and figured I'd update you. The Quick runs a road bike geometry and running gear where as the CX is more mountain bike(barely) You are and can run the Shimano 105 whereas I will have to run the Deore as an upgrade and run the XT BB 68/73mm bottom bracket. Upgrades are a work in progress and still coming.
the Quick CX 1 uses MTB components
the Quick 1 Disc uses road components
both bikes were upgraded to use external BB cranksets ; the CX 1 has a Shimano XT M770 crankset and the Quick 1 Disc has a Shimano Ultegra 6800 crankset
the GRX cranksets are typically designed for bikes with 47 mm chainline … this may or may not be compatible with a Cannondale CX … ???
Likes For t2p:
so there is that
the crankset should generally pair or match with the rest of the drivetrain (including cassette) so there is that
so there is that
