how the !@#$ do you get a chain pin back in?
#51
KMC chains are cheap[no more than 10 bucks] and come with a master link.
Quality and Star bike are usually a bit cheaper than the bicycle link in downtown savannah. I haven't been to the new bike link store on the south side, but had to get my crank puller sent up from that one.
#53
Originally Posted by rustang
ha, i appreciate all the concern.
i already bought a new chain, even though i'm pretty confident that mine would have held up fine.
the new one came with a masterlink (as i suppose most new chains do)...is a masterlink really going to be more durable than putting the chain together with regular links? something about a little cotter-pin style connection has me kind of spooked.
#55
main screen turn on.
Bikes: centurion dave scott ironman - now fixed gear
i just recently had this same problem.
it took a few tries, but i was able to line it up just so and get the pin started with a hammer.
then used the clamp/bolt thingy (the same tool i used to get it out) and the chain is fine.
it took a while and it was really frustrating, but everything worked out even though the pin came totally out.
#56
I know this is an old thread, I'm just adding to it for the benefit of searchers who have newly suffered the problem in the title...
With much cursing, I was able to reinsert a pushed-out chain pin like this:
1. Partially break the next chain link, pushing the pin out just enough to release the outer plate
2. Take your plate and pushed-out pin somewhere flat and level. Start the pin in the plate by holding with tweezers and tapping with a hammer. Be sure to start the pin from the outside of the plate!
3. Go back to the bike. The pin and plate, plus two chain ends will be difficult, but not impossible to hold in alignment, in the chain tool. Drive the pin home.
4. Push the next pin that you loosened previously back into position.
This method worked for me for the moment, we will see if the chain holds up under load. The chain is a Shimano 9-speed, super-narrow CN-HG93. The pins seem to have a slight bulge at each end that sheared off due to all my inserting and un-inserting. Hopefully this does not cause the chain to come apart under use.
I really didn't want to go hunt down another snap-off connecting pin, this method hopefully saved me that hassle.
If you too have suffered this super annoying screw-up, good luck, I have also felt the pain!
#57
aka Phil Jungels
Push the other pin out of the other end, and put them both back together with a KMC Quicklink.
#58
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
I didn't read all of the posts.
1) Your chain is integral your acceleration and braking system.
2) Most broken chains happen because of user error. Either trying to put pins back in or not hooking the master link up right.
3) Breaking a chain during hard acceleration or braking will hurt.
4) You can get a new chain for around $10.
5) or you can get a second master link and combine it with an inner link and bridge the gap you just made by taking too much chain off.
In short, just get a new chain. It's the drama-free route.
#59
Fresh Garbage
#60
Ths Hipstr Kills Masheenz
Bikes: tirove
because you are the weakest link, goodbye.
and because it's a wear item and would have to be replaced eventually anyway so why worry when you can replace it cheaply?
#62
Follow up:
The pin re-insertion method I described previously has held up just fine. 500 or so Km, occasional high loads, heavy rains... The chain seems fine thus far.
To address previous comments:
Excellent idea, I will pick up a couple the next time I am at my LBS.
The chain I was attempting to install cost $50. I'm not going to toss it just because there is a slightly increased risk of it failing.
In the event that it did break, I don't anticipate much in the way of injury. To clarify, I'm commuting to work on this thing, not racing.
#64
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
Follow up:
#65
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1337 Post(s)
Liked 765 Times
This whole discussion makes no sense to me. If you buy a new chain, it will have extra links that you can remove and save for a rainy day. If there is a problem such as described above, you can simply discard the faulty link set (one inner + one outer), and replace it with another set that is in good condition.
#66
No, No, No. Do not re-use chain pins! If you remove the chain pin with a chain tool you must buy a replacement pin. If you reuse the pin, you will compromise the integrity of the pin/chain and it will likely snap. I hope you you won't be out of the saddle pedaling when it breaks.
How do I know this? I did it and it happened to me. Luckily I wasn't pedaling too hard but nonetheless, I messed up my knees and elbows pretty bad.
#67
GONE~
How can you even reuse a pin when it is almost impossible to put a pin back into the link..
Nor do I understand how it will compromise the integrity of the chain...
#68
for what its worth, i saw two chains fail last week on a 442 mile bike tour. fortunately neither caused an accident but i am sure neither were fun. i would have helped, but both riders were on shimano and i only cary campagnolo 10spd chain parts.
edit:
ive never had a chain fail. (campy on the road bikes and sachs/sram on the fixed)
#69
car dodger
Chain pliers. Pushes the pin far enough to separate the link, but not completely out. Then pushes the pin back in the correct amount!
Mine works that way w/ a 1/8" chain:
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
#70
Kilo TT
Didn't read much of the thread, but I popped a pin out once, and that ***** would not go back in, no matter what I tried. Luckily I could just take out another link, but I learned from my mistake and that will never happen again.
#71
Oh, you know...
Bikes: '74 Schwinn Sports Tourer (Polo), S-Works E5 Team Festina (Chorus 11), Trek 2200 Bonded Carbon (Fixed), Trek 920 (7 speed IGH), Chesini Olimpiade SL (1x7)
I've pushed pins back in before. Put the chain flat on a sturdy surface (like the sidewalk), held the pin in place with a pair of needlenose pliars and hit it with a Heavy Thing (in this case it was a pair of channel locks) to get it started. Still riding that chain.
#72
Kilo TT
I tried holding the pin in with pliers and pushing it in with the chaintool, but didn't think about a hammer. I would be a little worried about the chain breaking, but if you are still riding it, more power to ya.
#73
so i've always been told how much of a drag it is when your chain pin gets pushed out -- but i was in a rush and i pushed it out -- damn - it is a drag! so i read these posts (after of course) and thanks for the advice. after only 3 hours or so i got it back in -- here's how i did it:
- figured out that using the chain tool is the only way -- impossible to hold the chain otherwise.
- put the chain tool in a workbench vise to free up my other hand -- you need two hands to do this
- set the chain in the tool and ran the pin through it to make sure it was centered and aligned -- you have to keep doing this every so often when you fail to get the pin in
- with one hand open the tool screw just enough to set the pin between the space - hole and pin screw -- this takes fine adjustments and trial and error
- with other use tweezers to gingerly place pin in space between (again book out some time for this!)
- when you have to lodged in a bit tighten/loosen screw and make small adjustments with the tweezersuntil as centered as possible
- push it in and have a beer
