Do all pedals take the same size wrench?
Recreation Ecologist
Bikes: Schwinn Criss Cross (hybrid beater), Nashbar AT-2 disc MTB
Quoted: 2026 Post(s)
Liked 1,096 Times
Almost all good quality pedals require a 15 mm wrench and are threaded 9/16" x 20tpi. Most good quality pedal wrenches are 15 mm only.
Those that take a 9/16" wrench are mostly on cheap "Department Store" quality bikes or on older American bikes with Ashtabula cranks and are threaded 1/2" x 20 tpi.
Park Tools makes one pedal wrench that fits both 15 mm and 9/16" wrench flats but their other pedal wrenches are 15 mm only.
So be careful with the 9/16" designation as it can refer to either the thread size or the needed wrench size.
Bikes: Surly Crosscheck, Surly Pacer
However, some pedals (such as the Crank Brother's Egg Beaters) take neither a 15mm nor a 9/16" wrench. Instead they take an allen wrench.
What is the BMX standard? I know they use a 1/2 inch thread instead of the 9/16 so maybe the flats are 9/16 for them?
Bikes: 1983 Dawes Galaxy, 2006 Raleigh Airlite, 1982 Sun Solo (fixed)
I just use a 15mm open-ended wrench anyway, works fine on all the pedals i've ever used it on.
A group for all Dawes Galaxy owners to give and recieve information about them
https://flickr.com/groups/dawes_galaxy/
i jam my thumbs up and back into the tubes. this way i can point my fingers straight out in front to split the wind and attain an even more aero profile, and the usual fixed gear - zen - connectedness feeling through the drivetrain is multiplied ten fold because my thumbs become one with the tubing.
A thicker budget priced 15 will often not fit on some pedals. But I've had good luck using a rather flat 15 that came with a slightly thinner wrench set. It fits anything I've got or ever had so far.
Bikes: Trek 1000, two mtbs and working on a fixie for commuting.
Location: Beaufort, South Carolina, USA and surrounding islands.
Bikes: Cannondale R500, Motobecane Messenger
Quoted: 11 Post(s)
Some pedals use a 6mm or 8mm Allen wrench on the backside of the spindle.
Liked 1,096 Times
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
If we're going to sit here listing what pedals have what system for taking them on/off we'll be here for a while.
True, but we will in so doing answer the OP's question.
Low car diet
Bikes: 2006 Windsor Dover w/105, 2007 GT Avalanche w/XT, 1995 Trek 820 setup for touring, 201? Yeah single-speed folder, 199? Huffy tandem.
Well, let's wrap it up, shall we? OP: Yes, that wrench is for a specific size (15mm), which is the most common size for pedals for modern 3- and 2-piece cranks.
If you're not sure what size wrench your pedals take, measure it or go the trial-and-error route.
Low car diet
1-piece (Ashtabula) cranks come on department store, lower-end BMX, and older bikes: https://sheldonbrown.com/opc.html . The cranks are smaller than 3-piece (your 12-year old bike did not come with newer 2-piece) because one arm has to slide through the bottom bracket. On 3-piece systems, the cranks bolt onto the bottom bracket spindle.
See: https://sheldonbrown.com/gloss_bo-z.html#bottom . The left two are 3-piece, the right one is 1-piece.
JiveTurkey, you're really helpful. Thanks man! I'll check my crank type before I begin my commute home this afternoon.
