sram omniums = best track cranks to choose?
#51
A little North of Hell
Quoted: 71 Post(s)
#53
Fresh Garbage
#54
Magnets, how do they work
Bikes: the good kind :)
As a person who has experiences both "square taper" cranks and the sram Omnium, I would highly reccomend the omnium. While you will never get as good a spin from the omnium, they are much easier to maintain and adjust the bearings. The priamy use of the crank that I have on my bike is for commuting, so resiliace is the primary factor that I am looking for, If i was on a track, I would probably be running a square taper crank. They spin much better and you don't really have to worry about keeping the internals clean and dry.
#57
SRAM Omnium Crankset - Q-Factor needed.
I try to find the data for the crankset.
I cannot find the Q factor data.
Next Question.. Q-Faktor on track ... banks with 47° FSA Crankset carbon has 148mm
I remember old Dura Ace and campa are under 140mm ...
What is possible on track side till you bump on the wood.
#58
Clark W. Griswold
Quoted: 4359 Post(s)
Liked 4,001 Times
Barring that you might ask SRAM to confirm any data needed or just look at what the pros are using if you are serious about track racing and use what they have but one would have to imagine a crank designed specifically for the track would do pretty well on the track.
Likes For veganbikes:
#59
Omniums Thanks for reaching out to SRAM Rider Support. I am happy to help. The Q factor is 145mm on this crankset. I hope this helps. Please feel free to let me know if you have any other questions or concerns I can help you with.
Warm regards,
LeviSRAM Rider Support
Warm regards,
VictorYlap
Track Cycling: Velodrome Racing and Training Area
4
12-18-18 07:51 AM
EsqDavidK
6
05-20-15 10:06 AM
sbs z31
11
11-22-13 02:37 AM
