Show us your Campy Triples
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
I can hear that RD screaming from here- and you're just in the middle ring and not even to the big cog!!!
Commence to jigglin’ huh?!?!
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Here’s my recently acquired triple set up (from essthreetee). Racing T RD with some form a aftermarket set up for the crank. Vague plans to put it on my Ciöcc frame. My also recently acquired VO compact crank to confirm my ongoing decline in hill climbing prowess.
Sugar "Kane" Kowalczyk
Liked 1,700 Times
I have one piece of Campagnolo equipment- a triple crankset- it's really pretty beat up, I think the chain rings look "cheap" and I don't think it's particularly high end. I was going to give it to someone- but they got too impatient, so it sits.
It isn't exactly a Campagnolo piece- but I have an Avocet triple that I think is pretty neat, and awfully pretty.
1986 Trek 400 Elance by Dave The Golden Boy, on Flickr
Last edited by The Golden Boy; 01-01-19 at 11:47 AM. Reason: Left out the comment about Andy's Racing T components!
Likes For The Golden Boy:
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Likes For Barrettscv:
Bianchi Goddess
Liked 2,923 Times
That is something! It looks like part of a watch movement.
Likes For Bianchigirll:
Liked 1,700 Times
I put the drilled RINO rings on there- but even the drilled arms are cool. I think it's capable for 144-110-74 BCD rings.
Edit:
oops- 144- 102- 74
Edit:
oops- 144- 102- 74
Have a Gippiemme triple its like the Campag , triple , but the spider is thicker for blind bored mounting holes an 86 BCD so possible granny 28T
I built it as a wide double a 222 CX Campag chainguard instead of the outer 52 middle , 36 inner .. Its in storage for 20 yeats.. will sell
3 bikes with Race T 2 50-40 , 24 1 52-42, 26..
Drop by , bring your camera..
Bikes: Numerous
Quoted: 1678 Post(s)
Liked 3,097 Times
Quoted: 4511 Post(s)
Liked 6,378 Times
You are absolutely right, it is a "stretch" but actually still within the cage/angle rule as long as you don't go big-big. It was a compromise to keep it working when on the little ring up front and still work well/ok in all the middle gears. Did very well all the way around and won't stay that way.
Liked 6,378 Times
That's really pretty stuff!!!
An Avocet is on my watch list, very elegant and obviously very well up to the task as they were a go to rando/brevet/touring crank for a long time by many very serious riders.
Liked 1,700 Times
I think I remember there are differences in Campagnolo pull ratios between speeds, so I don't know a cool looking 6 speed Campagnolo RD is replaceable for a shorter cage, or not quite as cool looking 8 speed...
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
The 1996 Campy catalog says it takes the same bottom bracket as the double, which I think was a 111 Campy taper. I generally have been using JIS 107s with them and that works for me, but 110 might be better. For the bike with the Nuovo Record and triplizer I had to use the longest spindle I could get, which was a symmetric 122.5.
My Bikes
My Bikes
Liked 1,700 Times
I've been cautioned about the Avocet/Ofmega triples having a tendency to break around the pedal hole. I'm not a particularly strong rider, and this is on an errand/commuter bike- but I do look at it much more frequently than I have to.
On the other hand- after stripping the anodizing- even with the deep scratches on my example- this crank looks amazing when it's shined up!
Liked 6,378 Times
Are there longer cage derailleurs that would allow you to have a longer chain?
My Campy Racing Triple 8 speed lives on my Univega Viva Sport mixte. She’s my “sleeper” bike on the local MUPs .
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times
Voltaire
Voltaire
Liked 6,378 Times
Bikes: Yes
Quoted: 301 Post(s)
Liked 15 Times
My favorite triple of them all. Hodgykins has one on his black Paramount that’s to die for...
Quoted: 2323 Post(s)
Liked 4,988 Times
Steel is real...and comfy.
Bikes: Yes
Liked 3,868 Times
@trainman999, I really like both of those Paramounts. The newer Record triple crankset in particular is on my wishlist. Very nice.
My Bikes
My Bikes
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
'72 Paramount P15-9
Likes For Hudson308:
Mr. Anachronism
Quoted: 526 Post(s)
Liked 256 Times
If you wanted to stay Campy within a reasonable cost, you could convert a Nuovo Record using one of the Soma long cage kits. Polishing the cage so it matches the rest of the derailleur is a piece of cake.
Bikes: fuji finest, klien pinacle
Quoted: 17 Post(s)
Liked 5 Times
First read the title and thought...Campy? 60’s Batman, Elvira and Rocky Horror..... then I realized I should be thinking about either a triple or a compact. 52t just doesn’t cut it anymore. I have never been a grinder. Anyone know if I can downsize my Superbe Prop lol?
Cheers
Tony
Cheers
Tony
Liked 1,700 Times
Cheers
Tony
Cheers
Tony
Finding a 48 or 50 big ring and a 42 little ring for a 144 BCD crankdset shouldn’t be too difficult.
