Flexible Frames and One-Handed Riding
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
I have Lemond Tourmalet I really like, but it has one problem. If I’m descending, even on a slight grade, with one foot down, and take one hand off the bars to get a drink, the frame goes into a terrifying speed wobble. Frame is 525 Reynolds.
The part of the frame where it originates seems to be the joint between the seat tube and top tube. If I sit on the bike to pull on the bars, they cause the frame to flex about 1/2” both right and left. My CF, aluminum, and stiffer steel bikes do flex some when I do this, but not to this degree. I have discovered the same problem on a Peugeot PH 501.
I guess there’s no solution other than to find a stiffer frame (or lose about 50 lbs). I have to wonder if this is not one of the reasons why pro bikes are typically so stiff, so that a rider taking a drink doesn’t go into a speed wobble and take out the entire peloton.
Anyone else have a wobbly frame, and if so, how do you deal with it? Could it be the wheels be part of the problem, or is this a frame issue?
Quoted: 3359 Post(s)
Liked 3,638 Times
My two suggestions are as follows:
Check your headset preload. An excessively loose headset can exacerbate shimmy/speed wobble, and you may want to try tightening it just a little bit more than optimal to stiffen things up. This will come at the expense of your headset life but it wouldn't hurt to try just for a bit.
Try to get into the habit of every time you take a hand off the bar, press one of your knees into the top tube. This is a well-known method to help calm down a speed wobble. It seems like you don't continue to pedal if you take a hand off the bars so that shouldn't be much of an issue.
Quoted: 18883 Post(s)
Liked 10,646 Times
I don't think it's frame flex. Any bike can develop a speed wobble, the planets just have to align differently for a different bike. See if touching the top tube with your knee makes it go away. Failing that, have your drink at the bottom.
Likes For Seattle Forrest:
Sophomore Member
Liked 1,057 Times
Thanks for the replies. I was hoping someone would suggest getting one of the Lemond frames in Reynolds 753 (stiffer?) and see if that fixes the problem. I may still do this if i see a good deal on a used one on CL.
Until then, I will try the leg on the top tube test and see what happens. Either that, or keep the pedals level when I take a drink. But it ain't the same, not being able to have one hand in the drops as I crest the climb and take a big drink as I begin the rapid descent, Tour de France-style.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
I suggest getting a Tourmalet with 853. I have one, 53cm, and it handles and rides terrifically. Never a wobble when descending. I look at Lemonds a lot and have not seen steel Tourmalet in that size, but there are some in other sizes on Ebay.
Quoted: 1324 Post(s)
Liked 927 Times
Check the entire frame carefully for minute cracking. Seems that when a pedal is at the 6-o'clock position that it might be a bottom bracket/seatube flexing problem as weight is put onto the pedal subconsciously.
Cheers
Cheers
Quoted: 4560 Post(s)
Liked 2,802 Times
After inspecting the frame and fork, I'd try a different front tire and see if it helped. Maybe the tread pattern on that Panracer doesn't get along with the pavement pattern and your speed, weight, balance, etc.
