Sliding Dropouts Problem
Ok so this is a problem i've had after converting to fixed gear, I've been riding it for 2 years now without much issue until i converted it to a fixed gear about a year ago. If i apply too much pressure then i basically pull the the wheel towards me and it goes into the frame. I have no way of tightening the screws other than by the 2 hex bolts. I've almost considered gluing a bolt in there as a stopper.. I checked tuggnuts but i doubt they will work here.
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 764 Times
Maybe you could drill a hole though the right side of the frame, then tap the adjustable dropout plate to accept a bolt to act as a stop. Of course, as the chain stretches it will get too slack, so you will have to replace the chain frequently.
Your cog is slipping.
Riding fixed doesn't place any more forward pressure on the drivetrain - and in this case, the rear dropouts - than riding single speed.
Calamari Marionette Ph.D
What size are those bolts? They look big enough to be really cranked down on with no problems.
Quoted: 4792 Post(s)
Liked 3,918 Times
You have probably already thought of this, but you have taken de-geaser (or strong detergent) and cleaned the surfaces of both the frame and the dropout mating surfaces I trust.
Ben
That's an aluminum frame, isn't it? There are limits to what the frame threads can take. (I might think about drilling out those holes and using longer high quality bolts and huts + lockwashers on the wheel side if it were my bike and I really wanted to ride fixed.)
Ben
Ben
yeah it's steel. And alu frame. I could always try cleaning it up again and see if that helps, Norway is sloppy as hell so my bikes get dirty a lot. I'll also check out those washers, could help reduce friction a bit right?
You'd want to INcrease the friction, wouldn't you?
Quoted: 18354 Post(s)
Liked 4,502 Times
I've been trying to think if there was something to put between the frame and the dropout to increase friction. You could try putting in a piece of emery cloth between the parts. I'm not sure if it would increase friction, or give the effect of 1000 bearings, but at least it would be worth a try.
I think the idea is to increase friction under the bolts.
Liked 4,502 Times
You can try a flanged nut under the bolts, it's a cheap fix only 2 bucks and I've never seen a wheel slip that way.
If its a nice single speed get the dura ace nuts and clamp them down with a torque wrench. If it's just whatever try the flanged nuts.
I'd go with the flanged nuts, it's not elegant looking but the wheel just does not slip no matter what.
Liked 4,502 Times
As I understand the problem, it is not the wheel that is slipping, but rather the dropout is slipping.
Chronic 1st-timer
Bikes: ...take me places.
Be sure the surface between the frame & dropout do not have any paint.
I had to sand off paint on the inside of a frame in that area a few yrs ago to keep this from happening, after that all went well.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
The right washer under the two hex bolt heads might help increase the surface area gripped by the the bolts.
Would also protect the aluminum frame.
howeeee
Singlespeed & Fixed Gear
6
08-18-14 10:10 AM
Steev
41
03-06-11 11:36 AM
