rim size
Liked 7 Times
rim size
Does anyone know if there is a road bike wheel that has a larger diameter than 630cc. I understand the british roadster used a 735mm rim but unsure if this was the tire size or the wheel size.
Liked 7 Times
Quoted: 1819 Post(s)
Liked 1,693 Times
Wouldn't it be easier and less expensive to buy brake callipers with longer reach? Even if you find wheels you may have great difficulty finding tires
Likes For alcjphil:
Phyllo-buster
Quoted: 2298 Post(s)
Liked 2,054 Times
No, you've got the wrong brake calipers if you can't reach a 27', 630mm bead. Even 635 mm rims are usually Westwoods so no brake surface.
Pics?
Pics?
Liked 7 Times
Thanks all. Calipers reach on one side and are only about 2mm off the rim on the other. I will experiment with adding washers to see if that changes the angle enough to lower the reach.
Phyllo-buster
Liked 2,054 Times
Some calipers lend themselves to lengthening the slots. I'm not recommending that at all but angles won't help.
Liked 7 Times
I think we are saying the same thing. By adding a spacer you lengthen the distance between the fork and pads which also changes the angle that the pad hits the rim since the rim is curved. Unless what you mean by slot is the hole for the pads, which may be another option since the distance is so small.
Quoted: 2482 Post(s)
Liked 2,952 Times
Drop bolts may be available for your calipers, depending on the brake brand. But the simplest solution is, as suggested above, to buy longer-reach calipers.
Phyllo-buster
Liked 2,054 Times
As always, a picture of the problem helps, big time.
