Dillenger Kit
Dillenger Kit
I have a Specialized Roll Elite step thru that I've had now for a couple of years. I love everything about this bike, so considering a kit instead of buying a whole new bike.
I've read as many post that contain information as I can find on this forum and have seen some that aren't very positive. And some that are.
Anybody recently added this to their bike? Would love to see some recent reviews.
Thanks in advance.
Thanks in advance.
Mark
Mark
Quoted: 882 Post(s)
Liked 821 Times
Not recent, but their 350w kit seems very similar to one procured about six years ago and still in use. It was a very nicely integrated system and reasonably priced. However, IMO, try to discover how long their batteries have been dormant.
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
Go for the Specialized Como which is the electric Roll. It is an excellent bike and you will enjoy that bike quite a lot.
Quoted: 882 Post(s)
Liked 821 Times
This is the Dillenger kit which was transferred to a $200 3-speed cruiser after four years. Needed to procure a new battery, but my daughter rides it around Las Vegas and had a particularly fun time on the Strip when it was closed last year. Depending on your budget DIY is very attractive and you're usually not saddled with a proprietary system with nobody except factory mechanics able to repair it. Another statement that some OEM-lovers like to spout is there are a myriad of extraneous cables strewn around the bike. Well, one front brake wire and one for the three-speed hub.
Gone Biking!
Bikes: Orbea Gain, Lynskey, Redline Conquest Disc, Bike Friday, Cannnondale T2 Tandem.
Quoted: 42 Post(s)
Liked 50 Times
I have converted two bikes to ebikes with a Dillenger kit. I am satisfied with both conversions. The front hub Dillenger motor has its quirks, but nothing that would prevent me from recommending the kits as an inexpensive way to convert a bicycle to an ebike. I have one on a Redline Conquest and the other kit is on my Cannondale T2 Tandem. The three quirks are as follows;
1) When you stop from a sanding stop it kind of like a top fuel dragster taking off. It takes a little getting use to, but after awhile you learn to roll with it.
2) It is hard to explain, but I feel that sometimes the hub motor works against me pedaling the bike faster. Up to about 15-16 mph no problems above that I have to up the assist level so that the hub motor will let me go faster. (I have an Orbea Gain with a rear hub motor that does not have this issue. It is assists rather than resists my efforts.)
3) Neither one of my kits displays battery usage. It is always on full bar. I have replaced everything but the batteries. Not sure why this is happening to me, but I have figured out the range by assist level and it is no issue.
Quoted: 668 Post(s)
Liked 529 Times
https://www.amazon.com/Waterproof-4-...10521843&psc=1
This one looks nice
https://www.amazon.com/dp/B08L8RDW17...NsaWNrPXRydWU=
Age before beauty
I got the 750w "Premium Off-Road kit in January. I used it to convert a Specialized Crosstrail Sport Disc. The kit came 4-days after I ordered it and it had everything I needed - well, almost. The Rear Drive kit comes naturally with a wheel - but it uses a freewheel not a freehub cassette. The Specialized comes with the cassette so I did have to buy a new Freewheel which I also got from Dillenger. I ordered a 9-speed freewheel which is tight for a freewheel. They usually are found on 6 to 8 speed bikes. Spacing is the problem with a 9-speed freewheel and I had nothing but trouble getting a smooth operating drive train and in the end I had to buy an 8-speed freewheel and shifter to convert the bike to 8-speeds. Not really a big problem but it was unforeseen and Dillenger support wasn't helpful at all with this.
Also, the Specialized disc rotor was a splined hub type so, I did have to buy a bolt on disc rotor - not a big deal at all.
I looked at the Roll model when I got my Crosstrail but don't remember much about it other than the fat tires. I assume it's not all that different mechanically so you may have to do some of the similar changes.
So, far, Dillenger's support has been pretty unhelpful, but I do think that they've tried to help but just aren't very well versed in bikes. For instance, the drive wheel they provide has larger spokes and the standard Specialized wheel's spokes are smaller. So, my spoke tightening tool didn't work on Dillenger's wheel. With a hub drive bike you need to tighten spokes often. But when I asked Dillenger support what size tool I needed they had no idea. So, when I found the correct sizing I notified them and told them what it was. They said thanks because they had no idea.
I've seen at least one other Dillenger SP Roll eBike build and it looked great. It was a mid-drive kit however which is probably the only way to go because of the width of the tires. Dillenger's rear hub kit would never accommodate tires that wide.
Here's the Dillenger kit in the box that I received:
Age before beauty
I appreciate that the Dillenger Kit was so complete, as well. The box came quickly, installed in maybe a day and half max and has been trouble free.
Gone Biking!
Quoted: 42 Post(s)
Liked 50 Times
I wonder if you could mount a small voltmeter somewhere near the battery. The display on my bike lists volts and that is what I use to determine percent charge.
This one looks nice
This one looks nice
Just picked up my Roll after the installation! Wow! Such fun and great help. It only took about 3-4 days after I ordered from Dillenger to get the kit. My LBS did the install in 2 days. I couldn't be happier.
Mark
Mark
