Alloy wheels on a carbon bike
That guy
Bikes: 2012 Felt FC build
Quoted: 25 Post(s)
So I'm a novice rider who got an amazing deal on a bike built on a 2016 Felt FC 1 frame. It has carbon everything, including the wheels, which are an older set of Novatec 52mm tubulars. The tires are great quality (relatively new Continental GP 4K tires with low miles), but I really don't want the hassle of riding tubulars, and the tires are narrower than I'd like at 22mm.
As a relative newbie, I'm having trouble justifying spending $1K or more on a new set of carbon clinchers. A couple of veteran riders have told me just to get a pair of aluminum wheels and I probably won't be able to tell much difference. But my LBS is telling me I'd regret not investing in carbon, especially from a ride comfort standpoint. (Although my first bike was an all-aluminum entry level Trek, and I never felt uncomfortable riding it.)
So what do you guys think? Would you feel weird putting a pair of Campy Zondo C17's (or similar alloy set) on this bike?
Quoted: 11 Post(s)
I don't see any problem or concern any alloy wheels on the carbon bike but at least a mid range of alloy wheel for better performance. Not those 2kg wheels without tyres.
Quoted: 20810 Post(s)
Liked 9,456 Times
Get a carbon wheelset if you want some deep/moderately deep rims that are still relatively light and/or for the bling factor (hey, cool wheels are cool). Otherwise, you're not going to be unhappy with the performance of a good alloy wheelset.
Quoted: 2952 Post(s)
Liked 3,106 Times
Totally normal to have alloy wheels on an carbon bike. Most people I know who race save their carbon wheels for race day and have Al training/commuting wheels for every day.
And the biggest factor in ride comfort is tire quality.
Quoted: 1528 Post(s)
Liked 718 Times
Either they're willing to tell you any old crap to sell you stuff, or they don't realise that wheels are not a factor in ride comfort. The vertical deflection of a rim in a wheel with adequate spoke tension is a poofteenth of bugger-all.
I'd recommend a lightly used set of Shimano's carbon-laminated ally rims; they're awesome. The front rim weighs 365g, and there's an aluminium brake track. Bladed straight-pull 16/20, offset rear rim, and I don't care what anyone says; Shimano's high-end hubs are the best you can get. C24* RS80, RS81 or Dura-Ace can be had in decent nick for as little as $400 if you're lucky. I picked up a worn set of RS80s for AU$200 - the rear rim is close to maximum wear, but I barely use the rear brake, and they were as true as the day they came out of the factory. The only caveat is to check for corrosion under the rim tape; they don't like salt air.
*The C24 variant is the lightest and cheapest option; I think there are two deeper sizes but of course they're heavier and more expensive, and instead of an offset rear there's triplet lacing, which isn't as good a solution for increasing NDS tension because they're harder to true and it's just not as robust.
Farmer tan
You've already got carbon wheels.
Buy alloy so you can beat them up without worry.
If you miss the feel of carbon, just swap the old wheels back on for a Sunday ride.
Quoted: 1851 Post(s)
Liked 679 Times
Yeah, carbon wheels won't affect ride comfort.
They theoretically will provide an aerodynamic advantage, but aluminum clinchers are more than fine. I only use my carbon tubulars in races. All other riding is on aluminum clinchers.
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
There is no comfort standard for wheels.
5 PSI will make more a difference than anything about the wheels. Your LBS is simply playing you for a fool to get you to buy something you don't want. I'd find another.
Quoted: 18883 Post(s)
Liked 10,646 Times
Most carbon bikes come with aluminum wheels. There's nothing wrong with it.
Quoted: 551 Post(s)
Liked 277 Times
Just buy yourself a set of Meilenstein Lightweights and you are done.
Quoted: 51 Post(s)
Quoted: 58 Post(s)
if you tend to see locals on a group ride or such and they are riding aero wheels, you can always ask them if they are willing to sell you their stock wheels if buying new is too much. nothing wrong with alloy wheels, especially for beating up day to day.
Farmer tan
I considered the C24 but it's a 17mm/20.8mm and I'm a 25c queen. Shimano leader said they have no intention of going to the new industry standard of 19/23 because of weight and costs. Love Shimano but their wheelset team is a little too nostalgic and stubborn for my tastes.
Great wheels.
Woman make me faster
My Felt F2 came with alloy and I ditched them for some Carbon Williams wheels and loved ridding the bike but living in the land of rain(Seattle) decided I could ride more with alloy because of braking concerns with carbon. Now I only use alloy wheels. Personally I have had great luck with November wheels and ride quality isn’t any different from carbon to alloy, tire pressure and tire choice get more results than the wheel material. Bike shops crack me up with the sales b.s. being slung about.
I was told by a shop once that Roval was the gold standard and if I didn’t pick up a set of deep profile wheels over any thing else I would regret it. BTW, shop had six sets to offload. I liken bike shop sales to used car salesman. This is the same shop that delivered a brand new Tarmac with literally no adjustments made. I spent over an hour dialing in everything before a real ride could be made. Not all shops suck but things like what the op stated keep me from really giving any shop loyalty.
Quoted: 26 Post(s)
Liked 12 Times
I agree with the masses here. I have some good quality alloy rims and some blingy 45 mm deep carbon rims on a fairly high end carbon frame. The aluminum wheels actually ride a little bit softer (same tires, same pressures.) I am thinking it's because the spokes are super thin and also longer, so they move around a bit, but that's just a guess. In any case, the carbon wheels look awesome and make cool sounds, but they really don't make me any faster 98% of the time, and I can't actually tell during the remaining 2%. The aluminum rims brake a little better. Decent alloy rims are just fine for just about any non-competitive riding, bling factor notwithstanding.
Quoted: 4407 Post(s)
Liked 1,560 Times
If anything, carbon rims are stiffer and the spokes are shorter = less comfort.
Quoted: 51 Post(s)
It was my 2nd choice. I guess I got scared away from those bulbous charts. I wasn't sure if 25c would be too much for it so I just erred on the side of caution and picked Fulcrum Zero which were cheaper anyway.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Fulcrum Zeros are nice. I've got two sets of carbon wheels but run my Zeros most of the time.
Keep the chain tight!
Quoted: 1020 Post(s)
Liked 463 Times
My C59 and C60 run on aluminum wheels.
Get yourself a good set of tires and maybe latex inner tubes and you will be good to go.
Have fun and ride safely.
That guy
Quoted: 25 Post(s)
You guys are awesome. This is certainly what I was hoping to hear. I appreciate the thoughtful, real-world responses. As someone who is just now getting into the whole road biking thing (and loving every minute of it), advice like this is worth its weight in gold!
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Me too - 25 mm Rubino Speed G+ on C24 wheels.
I run 25 mm tires on wheels with 13 mm inside width. People say it isn't aero, won't handle right, isn't supported by the manufacturer, is dangerous, is responsible for the sinking of the Titanic, blah blah blah... It rides perfectly fine.
-Tim-
-Tim-
