2020 TREK FX3 Pictures
2020 TREK FX3 USA Personal Pictures
Likes For Rick53:
Bikes: Trek FX 3 Disc 2020
I got same bike 2 weeks ago. My first proper bike (aka: not a 20kg steel bike with cheapest parts available) and loving it so far. Bit weird with the gears (the change between front gears is huge and I usually have to go up 2 gears on front to compensate when changing to lower gear on the front), but I guess I'll get used to it eventually.
Did 20 mile ride on my first day and it felt so good.
How does it compare to 2019 FX3? I was thinking about buying it, but since my local shop had 2020 version in stock, I went for it.
Bikes: United Motocross BMX, Specialized Langster, Giant OCR, Marin Muirwoods, Globe Roll2, VROD:)
Quoted: 238 Post(s)
Liked 405 Times
Congrats on the new bike! Always nice to see pics of shiny new bikes.....are you doing any mods to personalize it?
Went with just the wife for a short 6 miler : Traffic was terrible So we took a short cut down a dirt road. Mainly loose gravel. Bike rear tire kept slipping sideways : Trying to go even 10 MPH made control almost impossible. She was riding a Verve 2 and went thru it just fine.
I don't intend on that large of a Tire: I thru on the 40C size that come on a Dual Sport 2 . Handled really good : So I can easily go 40 size wise :
BontragerCX0 Tire,
LT2 Comp or
H5 Hard-Case Ultimate Hybrid Tire All 3 come in 700 X 38C .
Currently the Bike has Bontrager H2 Hard-Case Lite. When I put the knobby 40C tire that comes on the DS 2 .
It handled black top just as fast as My Skinner H2's in 32 did. Bontrager's CX0 has really good reviews from the Cycle Cross guys : They have those in the 33C on Closeout because everyone wants the 35 or 38 size. Makes sense :
I might get a New seat : I put a Selle Royal on My Wife's Bike and She loves it :
Seats aren't really a Priority for me.
These New FX3 shift very smooth and teh weight of teh Bike at least feels much lighter then a DS 2 . Even though Online specs note just a Few Pounds difference : Feels a lot lighter :
The 2020 FX 3 model isn't available in USA yet : They didn't have it on the Floor. When I asked about it that made it ok to show it to me. The LBS Owner said We can't dis[play these until mid Sept :
Quoted: 238 Post(s)
Liked 405 Times
My bike has 700x45c "Pavement" tires. I'm actually surprised how well they handle when I come across paths with gravel and/or grass.
They probably add some weight to the bike and slightly slower rolling but if speed is what I want....I have other bikes for that. Besides, I like the Beefier look and with the proper psi they add comfort and traction.
I ride mostly pavement so they work for me. Personally, I wouldn't put on knobbies....but your goals are obviously different then mine.
They are putting "next service due" stickers on bicycles now? Is it just the ~6mo adjustment after the cables stretch? I'd remove it, but leave the shop sticker if possible.
Nice bike.
Nice bike.
The FX-3 Great for 2020 was sorta Blah
Hi Rich,
i have an FX3 that came with the 700X32 H2’s as well. Great on pavement but terrible on crushed limestone screenings. I switched them out for 700X35 Schwalbe G-1 All Arounds. Surprisingly smooth rolling on pavement and more sure footed on loose stuff.
Likes For Bothrops:
But in all sincerity It actually seems like it rolls better : I'm sure that's the bigger tires > It also seem to take less effort to pedal : And you do set more upright : The handle bars are slightly above the seat where the FX slightly below.
I am 63 . Butt I am in good physical Shape. I am really debating strongly about loosing 150.00 and getting the VERVE .
We even swapped Wheels out when we got back home : The FX3 was smoother with the larger tire < The verve however with the 32 tires really flew :
Maybe it was matter of saddle?
The saddle on FX3 is pretty stiff and after first couple of rides I was thinking about changing it. Eventually I actually liked it - as while cycling initially it felt too hard, after those couple of rides my bum didn't feel sore or anything. And it always felt sore on my previous bikes if I rode them after some break.
As more than 90% of my cycling is on a hard surface (asphalt or concrete) I don't feel like changing the tires. I'm 6'3" and my saddle is more-less on a same height as the handlebar (the bike is in XL size) - anyway the position feels great for me. I've tried Giant Escape 1 before buying bike and Trek felt much more comfortable.
On the other hand, I live in Ireland and there are only electric versions of Trek Verve available here, so didn't even bother to try it out.
Well, here's a couple pics of my FX 3 (XL 22.5 size) as purchased (weighted in at 26.6 lb) and then after transferring most of my other items to it (now weighs 29.2 lb) from the old FX 7.2.
I found that my old pannier rack does not fit since the upper mounts are wider on this newer bike. Really don't want to drop $45 of the Bontrager version that's made for it, but might if I can't find a decent alternative.
Items added/replaced so far:
- Swapped out 32mm H2 Hard Case Lite tires for 38mm H5 Hard Case Ultimate tires
- Swapped out Satellite City pedals for Wellgo M085 pedals with Zefal half toe clips
- Swapped out Bontrager H1 saddle for Forte Easy Rider saddle
- Transferred Topeak Repair kit bag under seat
- Transferred Ibera Top Tube bag for iPhone/snacks/keys
- Transferred 2x bottle cages (1 for water bottle, 1 for JBL bluetooth speaker)
- Transferred front light and mount
- Transferred DuoTrap S Bluetooth module
Likes For stuman74:
Question: with only 2 crank rings instead of 3 on my old bike, I'm trying to make sure I select the proper gear combos. Maybe with only 2 it's not as big of a risk for crossing the chain as much to the cassette.
Looking at the Sheldon Brown site and gear calculator, it looks like for this bike the following gears ratios are equivalent (first digit is crank, second digit is cassette):
26 = 19
25 = 18
24 = 17
23 = 16
22 = 15
21 = 14
Assuming I should still minimize crossing, is it recommended to only use combos 29 through 24 and then if I hit a tough hill toggle the crank to use only 16 through 11? Thanks!
26 = 19
25 = 18
24 = 17
23 = 16
22 = 15
21 = 14
Just about 50 miles on the new FX 3. Been great so far! All loaded up and with my accessories and bags full of gear, comes in right about 35.0 lb now.
Oh i am loving it. Especially the black color. My next bike will be black all right. The stack height is enticing for people like me who like more of an upright stance while riding. Double chainring is also a good idea. I have triple right now, and i think it is possible to get all the gears that i have with a double chainring setup with less shifting hassle (considering that the small chainring is the same size as mine or just a tad larger as it has more cogs than mine also)
PS: The bike seems light. The frame tubes are thin. The thinner tubes will have some flex to them, which in turns would make this bike a lot more comfy. I really love the choices they make with it. This is a "does it all" kind of bike imo.
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 143 Post(s)
Liked 430 Times
Saw the FX 3 in that awesome red last week at the local Trek dealer. Sharp looking bike!
https://www.trekbikes.com/us/en_US/e...olorCode=black
I did (after the fact) look at other storage options for under the top tube instead of adding a rear rack and bag. My main concern has been that my legs might rub against the bag which would be super annoying. Not necessarily this bag, but something that would mount like this one: https://www.amazon.com/dp/B07S7B7FWV/
