Need advice: Shimano 500EX brake caliper.
Quoted: 35 Post(s)
Liked 54 Times
I recently got a very good deal on a nice bike from the late 90's.
fantastic condition for the price. (unfortunately I can not post pictures until I have 10 messages posted)
It has shimano brake caliper EX500 .
It is silly, but i never had bikes with road brake before, and I just don't know how to remove the wheels.
On all videos I can see, there is always some kind of piece to pull to release the brake before removing the wheel.
nothing like that on the 500EX caliper.
Do I really have to deinflate the tyres ??? (I have no room left on the cable tensionner )
It seems trivial, but thanks in advance for your advice .
Bikes: Bianchi Ti Megatube; Colnago Competition; Planet-X EC-130E; Klein Pulse; Amp Research B4; Litespeed Catalyst; Trek Y11
Quoted: 605 Post(s)
Liked 480 Times
That's correct, the EX500 brake caliper has no quick-release flip thingy (I don't know the official name) to release the brake tension.
You can either
a) deflate the tyre,
b) undo the cable, or
c) bash it past the brake pads.
You can either
Quoted: 605 Post(s)
Liked 480 Times
If it makes you feel any better (and it probably doesn't), none of the Campagnolo calipers have this feature either. Lots of deflating/inflating tyres for me.
Quoted: 35 Post(s)
Liked 54 Times
(now, I have reached 10 posts and I can share with you a picture of the bike)
Good deal in my opinion for 50€. Very light and well equipped for daily ride
Quoted: 605 Post(s)
Liked 480 Times
They're actually a nice little caliper, I like the grey/dark finish on them. I took these off an old Cannondale (I upgraded to Ultegra) and have them in a box. Maybe I should clean them up and do something with them.
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
https://www.velobase.com/ViewComponen...7-eebf94e4dcdb
Likes For wrk101:
Quoted: 823 Post(s)
Liked 1,395 Times
Isn’t there a release on the brake levers themselves?
edit- On each lever there should be a roughly triangular button near the top of each lever itself - the way these are mounted those buttons are facing the ground. Gently squeeze the brake lever and push the button, then hold it down and let the lever close - it should swing out so that the end of the lever is further out from the bars and allow the caliper to open wider.
Quoted: 7348 Post(s)
Liked 2,465 Times
Or you could remove one of the brake pads. Putting it back on might be easier than inflating the tire.
Quoted: 823 Post(s)
Liked 1,395 Times
Check the levers for the button shown here -
- THAT is your quick release. Gently squeeze the brake lever, push that triangular button in and hold it in while releasing the lever. The lever will rotate further back and open up the brake caliper.
Likes For rustystrings61:
Quoted: 605 Post(s)
Liked 480 Times
Nice! Learned something new today.
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,600 Times
I like the look of that bike. Very nice. Excellent buy at €50, IMO.
Shifting is fun!
Bikes: Yes, please.
Liked 4,600 Times
BTW, who made that frame? It looks interesting. I wouldn't mind some more (and bigger) pics.
Death fork? Naaaah!!
In fact the 500EX levers do not have a release button.
Careful set up at initial installation will allow you to use the barrel adjuster as a (not quick) release to free the wheel without bleeding the tire.
Top
Top
Quoted: 35 Post(s)
Liked 54 Times
The brake levers have no quick release.
I already checked that too before posting.
I have about no idea about the frame itself.
The bike comes from a shop near Basel / Switzerland.
It may be a standard bike, or a special montage "à la carte" for a customer. ?
I just can say the the basis of the bike seems really good. He rides like a charm, very light.
The only thing to fix is the dynamo on the base of the frame.
I purchase it for my son to replace his current daily bike, because of the nice equipment needed for such use (rain, night, ...) . (I should consider keeping it for myself )
I could of course post more pictures . No problem
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I've been able to remove inflated tires on bikes having no brake QR by working the tire past the brake pads using some front-to-rear wiggling so that the brake pad's ends pinch in the tire a bit.
Using rims and tires that are a closer match in width will ultimately make the QR obsolete.
Shimano sells an inline cable quick-release that is normally used with their direct-mount calipers that are mounted under the bottom bracket.
Liked 2,465 Times
Thanks for the tip, @dddd. I never knew about that.
