Go Back  Bike Forums > Bike Forums > Fatbikes
can i put 30 pounds of air in fat bike tires
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 10-18-18, 06:03 PM
windhchaser
Bikes: Felt nine flow
Quoted: 656 Post(s)
Liked 4 Times in 3 Posts
i think it says 15 pounds or some low number that cant be correct
And the moral of the story is,
A band with no talent can easily amuse
Idiots, with a stupid, puppet show
windhchaser is offline
Old 10-18-18, 08:35 PM
HerrKaLeun
Bikes: Giant Toughroad SLR1 and Motobecane Sturgis NX
Quoted: 704 Post(s)
Liked 41 Times in 36 Posts
typically limited to 20 psi. riding pressure is only 3-10 psi anyway.
30 psi would be very hard.
30 psi is for MTB with 2.x tires, if even that.
HerrKaLeun is offline
Old 10-18-18, 08:49 PM
DeadGrandpa
DeadGrandpa's Avatar
Bikes: Trek 1120, Santa Cruz Tallboy 3CC, Fandango DC-9 MTB tandem, Jamis Renegade Expert, Bike Friday Pocket Llama, Santana Arriva tandem, Bridgestone RB-1
Quoted: 220 Post(s)
I have a 29+ bike with 3 inch wide tires. 30 pounds gives you a bouncy ride and I don't recommend it. At 14 pounds pressure I get grip in the corners of both singletrack and forest service roads, steep inclines, whatever you can roll over from washboard to roots, chunk or whatever. 13 pounds isn't quite enough. 16 is too much.
DeadGrandpa is offline
Old 10-19-18, 09:22 AM
5teve
Quoted: 56 Post(s)
Liked 16 Times in 7 Posts
Fat bike tires/rims are designed for much lower pressure than that. I've never run more than 10-11psi in mine. I think 30psi would very possibly damage your rims or tires.
5teve is online now
Old 10-19-18, 09:24 AM
GrainBrain
GrainBrain's Avatar
Quoted: 696 Post(s)
Liked 61 Times in 44 Posts
Go ride your bike windy!
At about 15psi.
Post ride pictures!
GrainBrain is offline
Old 10-23-18, 06:06 PM
buffalo4life
Bikes: 86 Trek 330 fixie, 2011 Trek 1.1, POS mb
Quoted: 10 Post(s)
I rode my fatbike on the MUP today and took the tires up to about 12 psi for making some speed!
buffalo4life is offline
Old 10-23-18, 06:19 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 1687 Post(s)
Liked 173 Times in 118 Posts
The limitation is probably to prevent damaging the rims.
The larger the tire, the greater the outward force on the rim, at the same pressure.
I was once running some 2" tires that advertised a 65psi max on the sidewall.
After breaking the second perfectly good Mavic rim, I realized that was simply too much for the rims, and settled on lower pressures.
Lengthy discussion of hoop stress here: https://www.velonews.com/2017/03/bik...buildup_433214
Shimagnolo is offline
Old 10-23-18, 07:05 PM
unterhausen
Randomhead
Liked 85 Times in 72 Posts
forget where, probably on the FB FB group, I recently saw a blown out tire and destroyed rim at some pressure lower than 30psi. That's what I like to run in my gravel bike 38mm tires, so yeah, it's too high for a fat bike tire.
unterhausen is offline
Old 10-23-18, 08:09 PM
rm -rf
don't try this at home.
rm -rf's Avatar
Quoted: 647 Post(s)
Liked 24 Times in 23 Posts
This is windhchaser's "blog", there's a ton of separate threads. Most of them in foo.
30 psi on a 5 inch tire is like 150 psi in a 25 mm road bike tire. That's extremely overinflated, enough to damage the tire and rim. Not to mention that it's terrible for comfort and handling.
See this article on "hoop stress", needed air pressure is proportional to the tire width. (like Shimagnolo posted above.)
rm -rf is offline
Old 10-24-18, 09:05 AM
prj71
Quoted: 926 Post(s)
Liked 12 Times in 11 Posts
Depends on what the tire allows which is stated on the side of the tire. That varies with every manufacture and the type of tire produced.
I used my Specialized Fat Bike for a gravel race once and aired up the tires to 25 psi, which is the max stated on the sidewall.
prj71 is offline
Old 10-25-18, 07:16 AM
Hypno Toad
meh
Hypno Toad's Avatar
Bikes: 17 Breezer Radar Pro; 15 Surly Pugsley; 13 Felt Z85; 11 Globe Daily; 09 Kona Dew Drop; 96 Mondonico
Quoted: 689 Post(s)
Liked 69 Times in 51 Posts
Why do you want 30 psi?
This thread I started a couple years ago might help understand fatbike tire pressures: https://www.bikeforums.net/fatbikes/...ned-photo.html
I race my drop-bar Pugsley on gravel grinders, and I don't go above 15 psi (I was the second fastest fatbike of 30 registered for the 2018 Filthy 50):
Photo credit - https://markmanoutdoorphotography.com/
footnote/details: tires are Panaracer Fat-B-Nimble 26 x 4.0, rider is 170 lbs (likely 200+ lbs in this pic with all the water/ice/snow/limestone dust).
Hypno Toad is offline
Old 10-31-18, 10:46 AM
baj2
Quoted: 7 Post(s)
What size tire? I have two sets of 4.8" x 26", one is 15psi max, the other is 20 psi max. Either gets to be a rough mtb trail ride above 8-9psi. I've gone below 2psi for deep snow riding.
baj2 is offline
Old 11-08-18, 06:18 AM
Speedway2
Speedway2's Avatar
Bikes: Specialized Langster, Giant OCR, Marin Muirwoods, Felt Speedway2. Norco Indie3. VROD:)
Quoted: 49 Post(s)
Liked 31 Times in 23 Posts
I've mainly owned bikes with tires recommending 100-120psi.
When I (recently) bought my first fat tire bike (4"x26") the recommended max pressure on the tire was 20psi. I scratched my head and thought it must have been a mistake because at 20psi the tire felt "soft".
After searching the internet for answers (and reading this thread) I'm keeping my tires under 20.....
Speedway2 is offline
Old 11-09-18, 12:39 AM
MarcusT
MarcusT's Avatar
Quoted: 312 Post(s)
Liked 35 Times in 25 Posts
My tires give 30 psi as the max, one day the trail I was riding had been washed out and I had to take a very long detour on paved road. Not sure if I put in 30 psi, but it was close, because it was the end of a long ride and I wanted to get home a fast as possible. No problems, no damage, it was a little bouncy though.
MarcusT is offline
Old 11-09-18, 02:04 AM
daoswald
Quoted: 181 Post(s)
Liked 30 Times in 17 Posts
You would need tires with a capacity of 371 liters to put 30 pounds worth of air in them.
daoswald is offline
Old 11-10-18, 06:54 PM
lmtada
lmtada's Avatar
Bikes: Trek Fuel 100, GT Road Bike
12 lbs in Mine.
lmtada is offline
Old 11-11-18, 01:57 PM
baj2
Quoted: 7 Post(s)
PSI is pounds/square inch = force density, not a weight. If it was a weight few would be able to lift their road bikes with two 100+lb tires.
The best way I've found to think about tire pressure is this. The air pressure in your tires is supporting the weight of you, your bike, and your gear. The tire will deform on the bottom based on the pressure in the tire and the weight it's supporting. If you are 180lbs, have a 35lb fat bike and 10 lbs of clothing and gear, that's 225lbs. Roughly speaking, if your tires have 10psi in them they will deform to create 22.5 inch^2 of ground contact to support that weight. If you run 5psi the tires will deform to create 45 inch^2 of ground contact.
If you are riding on loose or new snow, the lower the pressure you can run in your tires, likely the better your bike will perform. It varies with snow conditions of course. The pressure in your tires (PSI) roughly equates to how much force your tires are putting on the snow/inch^2. The example above is basically me when I ride in the winter, so at 2psi my 4.8" tires are getting flat enough on the bottom to create a total of ~112.5 inch^2. And yes, the tires look ridiculous and it is a heck of a lot of work to pedal, but it's pretty impressive when you are grinding your way through 10" of fresh snow.
baj2 is offline
bcpriess
16
08-10-17 12:10 PM
CliffordK
Bicycle Mechanics
17
03-29-15 06:08 PM
DunderXIII
Commuting
14
10-14-14 07:11 PM
PatrickGSR94
Bicycle Mechanics
32
07-30-12 06:32 AM
s5fskzfv
Utility Cycling
25
02-21-12 10:41 AM
