Go Back  Bike Forums > Bike Forums > Fatbikes
Surly Lou rubbing against front derailleur
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 06-24-19, 10:08 AM
hawksfan90
I have a 2015 Specialized Fatboy and I just changed out the original Specialized Ground Control (26 x 4.6) for the Surly Lou/Bud at 26 x 4.8. The tires clear fine width wise, but the rear tire (Lou) is rubbing slightly against the front derailleur. Short of changing out a brand new tire, any suggestions?
Thanks!
hawksfan90 is offline
Old 06-24-19, 01:39 PM
rangie
Quoted: 28 Post(s)
Liked 10 Times in 6 Posts
Time to go 1x.
The Lou is a big tire. Not many bikes are going to handle a tire that size and a front mech.
Early fatboys were 177mm rear?
rangie is offline
Likes For rangie:
Old 06-24-19, 10:12 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 617 Times in 344 Posts
I find it strange that the tire rubs against the derailleur and not the chain stay.
Is it possible your BB axle is too short or reversed?
MarcusT is offline
Old 06-25-19, 08:50 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
Just looked at a pic and it seems very possible as the cage sits fairly far back to accommodate the small rings
As @rangie noted, 1x is your easiest option short of going to narrower rubber. The Lou/Buds are one of the few true to size tires depending on rims my even exceed the claims
If don't know already, you will likely need a clutch rear derailleur and a narrow wide chain ring to limit dropped chains
qclabrat is offline
Old 07-08-19, 12:37 PM
prj71
Quoted: 2975 Post(s)
Liked 1,181 Times in 771 Posts
What's a front derailleur?
prj71 is offline
Likes For prj71:
qclabrat
Mountain Biking
8
07-25-19 08:02 AM
drousseau33
Touring
45
02-24-17 09:28 AM
Bikedued
Bicycle Mechanics
5
07-19-16 04:23 PM
Troggie
Bicycle Mechanics
4
04-07-15 07:33 PM
gt eunuch
Bicycle Mechanics
7
02-01-13 09:22 PM
