How come is inner peak of the rims of Campagnolo Zonda wheel shaped flat?
Old 09-10-19, 03:21 AM
Quintessentium
How come is inner rims of Campagnolo Zonda wheel shaped flat?
Was thinking to buy Campy wheels in my price range as I heard they were quiet hub
but I just don’t understand the inner shape of the rim at all !
Are there any additional attachment that I don’t know!?
flat mountain
flat surface would confront the air!
Quintessentium is offline
Old 09-10-19, 05:38 AM
gfk_velo
Bikes: Too many!
Quoted: 58 Post(s)
Liked 18 Times in 10 Posts
Please can you ask your question in a clearer way?
Do you mean the inner surface where the spoke nipples are (and the areas between the nipples) or do you mean the inner surface where the tyre sits?
gfk_velo is offline
Old 09-10-19, 06:11 AM
Quintessentium
Where the inner surface nipples are and between
thank you!
Old 09-10-19, 06:43 AM
ridelikeaturtle
ridelikeaturtle's Avatar
Bikes: Bianchi Ti Megatube, M Alloy Pro, Sprint 76; Amp Research B4; Colnago Crystal; Klein Pulse; Litespeed Catalyst, Fondriest Squadra Corse
Quoted: 354 Post(s)
Liked 77 Times in 56 Posts
thank you!
I noticed this on mine and thought it was simply a style thing, that maybe it shaved a bit of weight and/or added strength (like "boxing" a frame on a car).
Someone w/inside or actual technical info would be interesting!
ridelikeaturtle is offline
Old 09-10-19, 07:01 AM
DaveSSS
Bikes: Look KG461, Colnago C-RS
Quoted: 138 Post(s)
Liked 19 Times in 15 Posts
The extra material around each spoke nipple adds strength. If the entire rim was shaped that way, the wheels would be extremely heavy. The inside surface has no holes to weaken the rim. A magnet is used to pull the nipples to the spoke holes. The Zonda is one of the best wheel values, particularly if purchased from a euro source for $320, including shipping.
DaveSSS is offline
Old 09-10-19, 07:22 AM
dabac
Quoted: 845 Post(s)
Liked 15 Times in 13 Posts
Whatís your question - the lack of holes for nipple access?
Thatís getting to be fairly common. Mavic has some like that too. Probably other manufacturers as well.
Flat vs concave bottom of the tube/tire side of the rim profile doesnít matter much, as long as there is enough difference between the min/max diameter of the rim.
dabac is offline
Old 09-10-19, 08:20 AM
Quintessentium
inner rims
Old 09-10-19, 08:32 AM
darkhorse75
Quoted: 16 Post(s)
Liked 5 Times in 2 Posts
I think the OP is concerned about the aerodynamic efficiency of the boxy section of the rims.
darkhorse75 is offline
Old 09-10-19, 08:43 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 1924 Post(s)
Liked 126 Times in 96 Posts
Then don't use this rim with it's "concerned" shape. If one were competing and one's pay check depended on this stuff then I can easily see who the minutia might benefit one's life. But most of us here are just having fun when we ride. Sure we delude ourselves by calling this fun "Training" or "Racing" but even at the local racing level it's all about how we want to have fun. So make a choice and go have fun. Andy.
AndrewRStewart
Andrew R Stewart is offline
Old 09-10-19, 09:56 AM
AnkleWork
Bikes: old clunker
Quoted: 609 Post(s)
Liked 47 Times in 33 Posts
They have to be shaped in some way and regardless of which way you could always ask why.
AnkleWork is offline
Old 09-10-19, 11:51 AM
HTupolev
Quoted: 1315 Post(s)
Liked 115 Times in 74 Posts
but I just donít understand the inner shape of the rim at all !
I suspect they're doing it to achieve a high strength:weight ratio at their price point. The rims are probably extruded with a thick rounded section at the bottom that's strong enough to withstand the force from the spoke nipples, but machined flat to save weight in places where there aren't spoke nipples.
Does this result in worse aerodynamics? Probably. Plenty of entry-level wheels aren't overly concerned with aero, though. Heck, it was only a few decades ago that essentially all wheels had rectangular profiles.
HTupolev is offline
Old 09-10-19, 11:58 AM
AnkleWork
Bikes: old clunker
Quoted: 609 Post(s)
Cosmetic removal of a few milligrams.
Old 09-10-19, 02:00 PM
ridelikeaturtle
Quoted: 354 Post(s)
I'd believe that, at this level wheel, saving a bit of weight is more significant and noticeable (to the end user) than saving a few seconds bc of aero.
Old 09-10-19, 02:47 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 819 Post(s)
Liked 95 Times in 72 Posts
I do agree that the wheel having the channels cut into the rim between the spokes leaving a surface that is orthogonal to rim movement (that is, the cuts create blunt faces that have poor aero qualities) is poor form. But they are small surfaces. The cut out sections remove weight. And these are pretty well-regarded rims (durable, efficient) for normal riding So I don't think its a biggie.
WizardOfBoz is offline
Likes For WizardOfBoz:
Old 09-10-19, 05:49 PM
DaveSSS
Quoted: 138 Post(s)
Campy offers the even less expensive scirocco that has the more aero shape. It uses conventional spokes and requires rim tape.
The bearings are a less expensive cartridge type, but many high dollar wheels use them, so it's not necessarily a negative.
DaveSSS is offline
Likes For DaveSSS:
Old 09-10-19, 07:44 PM
Ronsonic
Quoted: 79 Post(s)
Liked 17 Times in 14 Posts
With the spokes spinning around I doubt there's enough clean air in that area to make any aerodynamic difference. IMO, at that weight / price they are remarkably aero compared to the alternatives.
Ronsonic is offline
Likes For Ronsonic:
sanmi
Bicycle Mechanics
21
11-23-17 11:29 PM
metz1295
Road Cycling
28
06-15-15 09:54 AM
onespeedbiker
Bicycle Mechanics
2
09-21-12 01:36 PM
mikeonabike64
Road Cycling
14
10-11-11 11:51 AM
xpacpal1x
Classic & Vintage
8
04-23-11 02:33 PM
