Anyone heard of 24x1-3/8 "F3" tire size?
Old 10-10-19, 05:16 PM
1987cp
Albatross bars are cool!!
1987cp's Avatar
Bikes: Raleigh Alyeska; mystery Nashbar MTB tandem
Looking ahead to likely getting tires for an old JCPenny bicycle I found by a dumpster.
It's a stepthrough sport tourer, drop bars with safety levers, Ashtabula crank with skip tooth big ring, and impressively cheap frame construction. Not quite sure yet if I'll actually make use of it, but I do have a 12 year old getting just too big for his very cool (and apparently very rare) ~1987 vintage 20" StreetRunner 10 ATB.
Sheldon Brown lists a good handful of bead seat diameters for "24 inch" tires, but his charts don't seem to show:
24x1-3/8 FIT TO RIM F3
I assume I can find the right size by measuring the circumference of the bead seat ... still, any guesses what BSD these are?
1987cp is offline
Old 10-10-19, 05:43 PM
riva
low end rider
riva's Avatar
Bikes: 80's. hoarder.
Quoted: 34 Post(s)
Liked 21 Times in 20 Posts
Have got bikes with three different 24" sizes. 507, 520, 540. I'm guessing yours is none of those three, but 547.
riva is offline
Likes For riva:
Old 10-10-19, 06:26 PM
clubman
Youngman Grand
clubman's Avatar
Quoted: 1081 Post(s)
Liked 90 Times in 77 Posts
This charts lists a few designations but no F3. There's an EA6 that's not on Sheldons chart and it gives you the bead measurement, but it's not likely to help you source a tire.
File Type: jpg
clubman is online now
Likes For clubman:
Old 10-10-19, 06:48 PM
1987cp
1987cp's Avatar
Huh, the, F8 (66" circumference) figures to ~534mm. That's interesting, anyway!
1987cp is offline
Old 10-10-19, 06:49 PM
ThermionicScott
hungry
ThermionicScott's Avatar
Quoted: 2387 Post(s)
Liked 307 Times in 228 Posts
Here’s a more comprehensive chart: https://www.bikecollectives.org/wiki....php?title=Rim
Looks like you’ve got 540mm rims.
ThermionicScott is offline
Old 10-10-19, 06:54 PM
clubman
Youngman Grand
clubman's Avatar
540 might be worth a try. Bead circumference measurements are fussy.
Thermionic Scott got there first!
Old 10-10-19, 06:55 PM
1987cp
1987cp's Avatar
Actually has F 3. How awesome is that? Looks like this problem is solved - thanks!
I think I'll try driving people nuts by calling it a 600A. :-p
1987cp is offline
Likes For 1987cp:
Old 10-11-19, 10:02 AM
riva
low end rider
riva's Avatar
Quoted: 34 Post(s)
On a roadbike I laced up with 540 rims, I went with 1" bmx racing tires because all I could find narrow enough was wheelchair tires or bmx tires. Worked fine.
Looks like now days Schwalbe 24x1" in 540mm are available from online retailers.. not sure if they are intended for bicycles or wheelchairs though.. not sure how much it matters. I would think the construction is different for lean angle, but maybe not. You could always step down to a 520 rim I guess if the brakes reach.
riva is offline
Likes For riva:
