Most consistently reliable inflator?
Old 05-29-09, 03:42 PM
sp00ki
partly metal, partly real
sp00ki's Avatar
Bikes: Hummer H2
So my pedros inflator recently sprung a slow leak. I usually keep unpierced carts in my bag, but once i crack it, it's now done within two days.
It used to hold carts for months with no problem...
Can anyone recommend a good inflator that has not sprung a leak? looking for something relatively small that can get me up to at least ~90 lbs and is relatively well designed (ease of use, holds a cartridge, etc).
Thanks
sp00ki is offline
Old 05-29-09, 04:04 PM
fuzz2050
Real Men Ride Ordinaries
fuzz2050's Avatar
Quoted: 17 Post(s)
Liked 3 Times in 3 Posts
Maybe a pump? I hear those rarely spring leaks.
I thought CO2 cartridges weren't made to be stored, that once you pierced the lid they were basically done for.
fuzz2050 is offline
Old 05-29-09, 09:34 PM
SSBully
HAMMER DOWN
SSBully's Avatar
Bikes: Sold '08 Jamis Coda Comp, building a Leader 720TR. I know, let the hating begin!
You are correct! However, I'm going to go with the temperature becoming hotter as the culprit here, and not the inflator head. Higher temps will increase the pressure in the canister causing it to leak out much faster. OR the heat is softening the o-ring in the inflator head. Either way, you're lucky to have used carts more than once, anyways.
SSBully is offline
Old 06-01-09, 07:31 AM
sp00ki
sp00ki's Avatar
Bikes: Hummer H2
i see. yeah. maybe the pedros inflator was better than i gave it credit for.
bought the super small (green) innovations one anyway (forgot to check this thread). it's super tiny, and at a bulk cost of less than $1 a 16gm cartridge, using one per wheel from now on isn't a very big issue.
sp00ki is offline
Old 06-01-09, 07:37 AM
SSBully
HAMMER DOWN
SSBully's Avatar
SSBully is offline
