Have you ever see one fail like this?
#101
Bikes: Garmin/Tacx Bike Smart
Quoted: 646 Post(s)
Liked 289 Times
Look, I don't know what really happened since I wasn't there. You weren't either. So while we can all make assumptions, none of us can state for sure what really happened. That's all I've said all along. And yes, it does look like something got in the spokes that caused it to break.
#102
Quoted: 20810 Post(s)
Liked 9,456 Times
Likes For WhyFi:
#103
Quoted: 646 Post(s)
Liked 289 Times
Sigh...
I don't know you, I don't know your cousin and people get weird kicks.
This is the first time that you've acknowledged the likelihood that something got kicked up in to her wheel. Every other post has been, "nope - she didn't hit anything." "Nope, the other riders didn't see anything get stuck in her wheel." "Nope, you weren't there so failure is a possibility." etc, etc. IOW, denying the most likely cause (by a large margin) in favor of perpetuating a mysterious JRA failure. Sorry, but that does seem a bit trollish.
But please, "get weird kicks?" Are you for real?
#104
Liked 9,456 Times
Based on your responses, I'm feeling more and more certain that you're not for real... or you're super naive. Either way, not worth the time. Have fun. Bye.
#105
Why is the fork and its material and failure even being discussed?
It is obviously the the symptom of the incident not the cause.
Whatever jammed in that wheel would of put the rider over the bars regardless of the fork material.
I have a friend who broke his back (fortunately healed ok) when a tyre iron got flicked off the road by another rider and went through his front wheel.
His fork was also smashed but that is irrelevant to the outcome.
#107
Of course it's explained (if the rim is rigid enough and is impacted from the front); The rim is impacted and stops, unyielding due to rigidity. (Just the rim can be very rigid, and fully spoked it is more so, because as one side is impacted inward, the rim 90 degree forward and back (on top and bottom) resists the rim ovalizing due to the spoke tension.) The rest of the bike keeps going, most specifically the hub, blowing out the aft spokes beyond their ultimate tensile strength. But... aha... if the fork bent first, it wouldn't be stiff enough to yank the spokes. If the spokes broke first and the fork kept going into the frontal impact to bend the fork, the spokes on the front side would be buckled. I yield to your logic sir. I think there was something in the spokes. EDIT: Maybe. Just looked at the pic again, there's just enough spokes still on the back side to keep the front spokes from buckling. Tough call. No buckled front spokes, the aft ones aren't bent either.
#108
I’ve seen pics of a CF fork failing like this after a squirrel jumped into the wheel. While one might expect the spokes to cut the squirrel in two, the wiry little bastard stayed intact (but dead) and the fork gave way instead. Looks to me like something more substantial than a squirrel got into the wheel and started shearing off spokes. Every time the next spoke came up, the object was slammed into the back of the fork before the spoke failed. 6-8 broken spokes and 6-8 impacts against the fork later, it was the forks turn to fail. I would’ve said a stray tree branch, but a branch stout enough to do this damage would hardly be missed. Maybe a piece of metallic road flotsam, like a tool (wrench or screwdriver)?
#110
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times
IT'S A ****ING ALUMINUM FORK FOR THE 100th TIME IN THIS GD THREAD!!!!! A L U M I N U M.
Likes For cthenn:
#111
I would try to sue TREK
#112
Quoted: 980 Post(s)
Liked 776 Times
If this could happen to aluminum, god knows what the outcome would have been had it been carbon.
The OP would surely have had to donate a kidney at the very least.
Assuming he had normal kidney function, was over 18, in good health, a compatible blood type, and not a habitual drug user.
Likes For downhillmaster:
#113
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
I just read the first post which gave no indication of what material the fork was. But my comments still stand. So you are saying there is some kind of prestige having a Made in Taiwan sticker versus Made in China sticker lol. I want some of that Koolaid.
#114
6-4 Titanium
Quoted: 92 Post(s)
Liked 36 Times
Trolling? Really? So you think I asked my cousin to break her fork, go over the bars and end up in surgery to I could troll this forum?
#115
Randomhead
Liked 3,697 Times
#116
Quoted: 980 Post(s)
Liked 776 Times
Steel is real.
NASA has done tests and they have never been able to make a steel fork fail. They have even tried atomic energy.
I think the only known steel fork failure in history was due to an errant Chuck Norris roundhouse kick.
#117
But the material being aluminium makes more sense: incorrect heat treatment with a cold spot at the height of the break would cause a discontinuity in the crystaline structure of the metal, creating a a weak spot prone to fracture. It makes sense that the fork broke at the same height on both sides, indicating fatigue along this weak spot finally gave way.
Also notice that broken steel forks in other images are not completely severed. This is due to the resilent quality of steel, completely lacking in aluminium.
I really don't get it why someone would use an aluminium fork instead of good quality steel or even CF, just because it is much cheaper to make for the manufacturer.
#118
Quoted: 645 Post(s)
Liked 797 Times
The wheel is a 32 spoke variant. A squirrel won't fit into the space between the spokes (maybe a rat will, but who ever heard of that?). Maybe on those 20 or 16 spoke wheels a squirrel might fit, but the squirrel perpendicular velocity would have to be much greater than the spoke angular velocity to make it into the space between the spokes. Definitely something for a Marvel film.
#119
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 197 Times
Hope she's recovering well, and willing to get back on a bike--
Likes For superdex:
#120
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Whether this was caused by a squirrel or not, it's a little chilling because I have 5 or 6 mini-heart attacks during every ride these days when suicidal squirrels dart in front of me at the last second. Have visions of that cracked fork with the squirrel wedged in the spokes.
Likes For Reynolds:
#122
Administrator
Quoted: 11969 Post(s)
Liked 6,644 Times
Substitutes
I can appreciate the frustration, really can. lol. But in the future please just let our filter do it’s work and leave out the partial spellings that are really the same as saying the actual word. Personally I like to use the substitutes “frikkin “ or “freaking”. lol
Regards,
BillyD
Likes For BillyD:
#123
Expired Member
Quoted: 3674 Post(s)
Liked 5,430 Times
If the aluminum fork presents itself as carbon, is that structural appropriation?
#124
Quoted: 647 Post(s)
Liked 136 Times
Hi,
Regards,
BillyD
Regards,
BillyD
Likes For cthenn:
