Shimano 600 brake adjustment. Am I missing something?
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 677 Post(s)
Liked 459 Times
I see no way to adjust the front and rear brakes with a barrel adjuster.There is a barrel but I see no way to turn it. This is on an 86 Miyata 912.
Bianchi Goddess
Quoted: 2925 Post(s)
Liked 2,921 Times
That nut that looks like a washer should turn and screw the adjuster out.
Sugar "Kane" Kowalczyk
The adjuster is the part just above the brake arm, the second pic shows the rubber removed. It is threaded and as you turn it the inner cable holder will rise. Sometimes it helps to take off the cable tension by squeezing the caliper together against the rim.
Edit - Whoops, too late!
Quoted: 1946 Post(s)
Liked 2,004 Times
Where there was the rubber o-ring thingy was is a nut. It will turn to adjust the tension. It may be a good idea to remove the wheel, pinch the brake closed with your hand, and wrestle the nut loose. Or loosen the pinch bolt and dismantle all of it and lube it good.
Quoted: 1077 Post(s)
Liked 1,894 Times
I'm not familiar with these brakes, but you should be able to turn the nut between the conical nut at the top and the brake arm - that will lower or raise the conical nut. See how the thread has flats on it where it protrudes? That locks in to the rectangle hole in the brake arm so it doesn't turn when you make the adjustment. Does that make sense?
Edit: everyone jumped in while I was making a coffee.
Quoted: 350 Post(s)
Liked 276 Times
The nut is cammed on the bottom, so every half turn will seat itself so that it doesn’t back off the tension preload.
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 677 Post(s)
Liked 459 Times
I tried turning it but it is round and doesn't want to turn.
Likes For robertj298:
Quoted: 677 Post(s)
Liked 459 Times
Quoted: 237 Post(s)
Liked 83 Times
The barrel does not rotate nor thread into the brake arm for this kind of adjuster. It has flats to prevent it from rotating in the arm. The thumbnut is not a locknut, it is the adjuster which lifts the threaded shaft on the barrel and is indexed to the arm instead of having a locknut.
Quoted: 677 Post(s)
Liked 459 Times
Thanks. I think mines just stuck from non use. I'll try shooting some oil on it.I don't know why they don't make it knurled like on my other bikes.
