New Chain Issues
New Chain Issues
This is my second road bike but the first I have taken seriously, just finished my first 1000k on it with 105 Shimano R7000 and decided to replace the chain with a KMC 11 Speed Gold Chain. I matched the chain length to the previous chain during install. When in the two biggest sprocket on the cassette and on the 50 chainring it will drop to the 34 chainring, if I am hill climbing and the tension is great it sometimes holds. No issues in the 34 chainring at all or in the 50 at the smaller sprockets. It feels a lot smoother than the old chain, I only did about 5km testing it out and noticed the issue, which brought me here looking for advice.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Are you sure you didn't drop an extra link?
Likes For tntyz:
The new chain has the exact same link count as the old. Not the issue than.
I was very rough on the chain when I first got it, cleaned up my shifting and then decided to upgrade from the stock shimano chain to the KMC 11 Speed.
Still do not have a fix to the issue. It only has trouble in the 50 Chainring with the 25 & 28 sprocket.
Interesting that you didn't see this happening on the Shimano chain.
You may want to reconsider your gear selection. This is cross-chaining which will generally run poorly and cause more rapid chain wear. Dropping down to the 34 chainring and running in the middle of the cassette will be smoother and help your chain last longer.
I use a 52-34 chainring and 11-28 cassette on SRAM. I really, really try not to cross-chain and pay attention to my big to small shifts b/c of the wide range. If I do cross chain it will sometimes pop off the 52, but only if I'm in the 28 and normally when I have a dirty drivetrain. Having issues in the 25 makes me think something other than alignment is up.
Quoted: 20810 Post(s)
Liked 9,456 Times
Adjust the trim position of your FD.
Quoted: 6199 Post(s)
Liked 4,816 Times
Make sure your front DR is still fully going to the high limit. Shift into the 50 and then pull on the bare cable. If the DR moves very much, then give a partial turn or two to the inline adjuster. If you don't have one, then you'll have to re-secure the cable in the holdfast which might be more issues for you if your DIY abilities and sensibilities aren't up to par.
Possibly could be the high limit needs to be moved some. But that's rarer.
Don't worry about the cross-chaining nay-sayers. Just pity them that their bikes can't do it well. <grin>
It's not like you are cross-chaining for a long time during the ride. If you are, you need to change your gearing.
The basis of this problem all started with Lance Armstrong wanting an extra gear for climbing and they changed from the super reliable 8 speed to the 9 and the cog race began.
Likes For RiceAWay:
Liked 9,456 Times
Are you adjusting while in the trim position? If you're adjusting so that there's minimal gap between the chain and FD cage while in the largest cogs, you should be doing so while in the trim position.
Likes For WhyFi:
Liked 4,816 Times
They still make those "super reliable" 8 speed rears if you want them. Or are currently happily riding one. <grin>
Quoted: 3957 Post(s)
Liked 7,310 Times
So, if it hadn't been for Lance Armstrong, we'd still be using 8 speed cassettes? Forget about doping, this is the real story!
Adjusting the trim for the H on front derailleur fixed the issue. I can tell at times it wants to come off but it cannot due to the adjustments.
Non omnino gravis
Likes For DrIsotope:
