beginner building experience
Quoted: 76 Post(s)
Liked 76 Times
i've done some brazing in the past, but nothing where it was as important to maintain proper heat on the parts like with bicycle frames. i would love to eventually build my own frame, but to build up to that point i was thinking of making my own racks and maybe doing some frame and fork mods on existing bikes.
is this a good route to take?
as an example - i'm loving my 26er drop bar thing - it's a 90s univega mountain bike i've set up with some old and modern parts to be a cheap gravel/go anywhere bike.
eventually i'd like to replace the frame dropouts with some modern modular dropouts to make the bike even more adaptable. it would, for example, make replacing the rear derailleur hanger cake if it were to ever break off, etc. it could even make a 650b conversion doable at some point.
this particular frame also has a few dents i'd like to repair to gain that experience as well, and i feel like it would be a good candidate for other mods too, such as maybe internally routing the cables and maybe adding some bosses on the top tube for a gas tank bag or what have you. it's not really a question of if this particular frame is worth the work to modify it, but rather if it's worth gaining experience working with bike frames i already have prior to setting out to build my own.
what are your opinions? are frame mods and rack building a good way to get your feet wet, or is it better just to dive right in and build a frame from a tube set?
Quoted: 4201 Post(s)
Liked 3,857 Times
Yes, racks and mods are a good way to begin your building foundation. Not sure this Univega frame is worth all that though... Andy
AndrewRStewart
AndrewRStewart
Quoted: 76 Post(s)
Liked 76 Times
thanks for the feedback! like i said, it's not really a matter of if the frames i have on hand are "worth" putting the work into, but more if putting work into them is a good way to build experience.
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
When I decided to learn how to build frames I went straight to building a frame. The materials are cheap enough that I don't see the point in doing anything else.
Randomhead
Liked 3,696 Times
you can buy 4130 and brazing rod and stick them together. Probably worth doing. You can also get two sizes of 4130 that slip together and practice brazing lugs.
Liked 3,857 Times
t e r r y- I can help you with "reasons" to do any mods or project you wish. I have a life time of doing such and rarely get even half of the cost covered. I always called this the cost of education Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
kroozer
Classic & Vintage
56
04-16-14 08:19 PM
4Rings6Stars
Classic & Vintage
25
11-11-10 05:00 PM
