Inherited a vintage Peugeot
Hi Folks - I would greatly appreciate any help with identifying the year/model/value or any other particulars you think are of interest. I've listed below all markings I could find and tried to take relevant pics (I regret I am not very bike savvy!). The bike was last ridden in the late '80s and has been stored since then and needs a good cleaning, and tune-up in order to get it back on the streets in the San Francisco bay area. There is also an extra set of wheels with the same markings as those on the bike. Many thanks in advance for sharing your knowledge and expertise
Record Du Monde
Tube Special Allege Peugeot
Serial# 1728044 (underneath side of bike)
Mafac Racer
Simplex
Rigida Chrolux wheels
Normandy (center of wheel between spokes)
ADGA Chatillonnaise on seat
Lapize / Lyotard pedals
"We are all one ride away from a good mood"
Cheers!
Record Du Monde
Mafac Racer
Simplex
Cheers!
Quoted: 3803 Post(s)
Liked 3,324 Times
hello shern,
thanks for posting
fine job with the pictures
model is called U08
date is 1971
you will find a marking on the backside of the bicycle's Simplex Prestige rear derailleur with a date mark
it is great that the bicycle is so all original and has no damage
usually by this age they have had parts changed and show usage wear
hope you enjoy it, if it is a reasonable size for you
hello shern,
thanks for posting
model is called U08
date is 1971
Likes For juvela:
Quoted: 1372 Post(s)
Liked 1,749 Times
My guess would be an early seventies Peugeot UO8 and it looks to be in great shape. The 71 on the back side of the front derailleur cage is a pretty good vintage indicator, suggesting a vintage of 1971...
The UO8 is nothing of high end quality, however; the bike has a reputation for being a very nice riding machine. To that add that is livery screams vintage in any language. All in all a nice bike to clean up and ride. Be careful, though as such bikes can be theft magnets. And, you should take a very close look at the front derailleur. These derailleurs are very prone to cracking in half, making shifting impossible...
You should also know that French Bicycles can offer some rebuild issues a bit uncommon for other countries of origin.
So, were I the OP, I would make the bike road worthy and safe for a Test Ride. If satisfied, spend the time and money (one to two hundred dollars depending on who can do the work) to properly clean, lubricate and tune the bike. You will not be sorry you did so.
Likes For randyjawa:
Thanks so much Juvela & Randy - especially for adding those pics. I located the 71 marking. It was well cared for back in the day by my father, so hoping with a little TLC I can get it back to riding condition, but will check the deraileurs as suggested, thank you! Would either of you be willing to take a stab at it's value?
P.S. Juvela: I used to spend summers with friends who lived in Baxter so have been through Alta quite a bit (30 yrs ago!) - lovely mountain area!
Shern. Really nice nice looking bike you have there. Those MAFAC brakes work great. Nice to have the frame pump, gloves, water bottle and the bottle cage is a neat piece. The rope is a mystery, maybe to hang from a beam in garage? A little soap and water and the bike will shine! Cheers. Kevin.
Likes For Kdogbikes:
Quoted: 3464 Post(s)
Liked 2,827 Times
sellers list these locally in Southern California for $200 and they sit. $100+/- is probably the median.
Original tires, check them carefully, these were quite decent when new. I see at least one original tube too.
Brake blocks are OLD, Kool Stop replacement pads would be the way to go.
I would get one new brake cable and one new shift cable, make the rear cables the front.
The shift cable end is Simplex, smaller than most others, grind the end or drill the lever to accept.
grease the cables where they pass through any housing.
You have been visually warned about the front derailleur body. I have had them just crack while mounted on a bike in storage.
The year of your bike - might have Metric pedal threading, might be 9/16"x 20.
All the bearings could use a new grease servicing, and oil for the freewheel.
Likes For repechage:
Liked 3,324 Times
happy to read information of help.
wrt Alta: the "Alta" in me listing doth refer not to be town but to the region as "Alta Californina" as opposed to "Baja California" - am located in the San Francisco Bay area.
the bike is in such great shape for its age that with just a bit of cleaning/polishing and lubrication you can have it in fine fettle in no time
pedals are metric thread 14mm X 1.25 and marked D and G on spindle ends. They are Lyotard model Nr. 36.
PS - does the bike exhibit a shop transfer anywhere? if present, it may be one I am able to recall...
Cheers!
Thanks for the info on the pedals. I don’t see any shop transfers, but who knows what I’ll uncover after removing the 30 years of grime!
Liked 1,749 Times
Value, if you have good marketing skills and if the bike is clean and in road worthy condition - $100 to $200 US. If you are patient, $150 - $250 US.
If you decide to keep and ride the bike, be prepared to at least - replace brake pads as they tend to harden with the passing of time, open up and grease the bottom bracket, head set and wheel hubs. That is the minimum. You might give some thought to replacing brake and transmission cables also, but not absolutely necessary. Those items will set you back about $30.
Now, to be safe, replace the tires since, once again, the passing of time will negatively impact the integrity of the tires strength, perhaps allowing for a blow-out while riding. Most of the time a flat causes pain in the butt (figuratively speaking), however; a nasty and sudden tire pop on the front might cause both you and the bike considerable crash pain.
If you have to have others do the work, add $100 at least to your clean up and make road worthy costs.
Quoted: 5888 Post(s)
Liked 3,471 Times
Lovely bike and well worth fixing up and riding. Alloy wheels will be a big help performance wise if rebuilding the bike.
Price wise, these bikes tend to go $50-$100 here in a mid sized city in the midwest; it has to be worth more in SF.
Likes For bikemig:
Thanks very much. This will be my labor day weekend project! My bike enthusiast colleague also suggested the alloy wheels so will look into that. Greatly appreciate your thoughts on the value. Cheers!
Funny ... as I read this thread, I thought someone has to mention aluminum wheels. It's not for looks. It's not weight, though aluminum rims will weigh a lot less than the steel that's on the bike now. It's for safety. Steel is VERY hard to stop when even a little wet. If it's possible that you may have to go down a hill in a serious fog, and you have steel wheels, you will be in grave danger. (Every time I've been in SF it's been sunny. )
That bike will clean up really nice! Id honestly replace the cables and tires and brake pads and a service and ride as is. unless you plan to do serious riding on it.
Thanks! Today is bike clean up day and can't wait to see it's renewed look. Then off to the bike shop next week for some new parts. Cheers!
Likes For shern:
westfalia
26
11-06-12 08:37 AM
lovinbiking
8
06-17-12 07:51 PM
troylarson
3
08-07-11 08:41 PM
