#3676
Bikes: Since new: 86 Rodriguez Tandem, wife's 87 Gitane Team Pro, 92 Burley Rock-n-Roll, 85 Fisher Comp, 88 Puch Pro, two 92 Bridgestone X0-1s; later: 66/67 Gitane Champion du Monde, 70 Gitane Super Corsa, 70 Carre, 87 Gitane Team Pro, 77/78 Ritchey Tandem
Quoted: 148 Post(s)
Liked 362 Times
Been “correcting” my recently acquired late 70’s Ritchey Palo Alto tandem. I guess a previous owner had wanted a triple so they had put a later Specialized triple crankset on the stoker drive side only. I yanked that and replaced with a correct and matching first-gen Dura Ace double (53/39). I also swapped out the stoker’s Sugino seat post with a Campy NR to match captain’s, and put on a proper pair of his and hers Brooks B17 Imperials. I borrowed the Silca pump from my wife’s Gitane Team Pro and put Avocet water bottle cages on...I had two yellow and one black so the black is down low and holds my period correct Kangaroo Bags tool roll. We have not been on a ride yet where this beauty isn’t ogled by someone.
Likes For Markeologist:
#3677
Quoted: 4507 Post(s)
Liked 6,373 Times
I finally acquired a frame that I should be able to ride, nothing like this but close in size, mixte stoker to MAYBE get Ms. merziac on but needs a lot of work.
This is my first tandem, fortunately the whole crankset is present and in ok to good working order so we'll see, HS was a mess but got it some sorted so should be good to go for the limited use this may see, may shoot for this spring to have it up and running, again, we'll see.
#3678
Quoted: 7341 Post(s)
Liked 2,439 Times
@Markeologist I'm ogling, too. We have a cheap tandem, and it has to do for now.
#3679
Quoted: 148 Post(s)
Liked 362 Times
Thanks merziac and noglider...good luck with your tandems! My wife and I have been riding tandem since 1986/87 (before we were married) and we did our honeymoon on our Rodriguez in 1988 (which we still ride). Here is us with our Rodriguez at start of 2017 Eroica California BEFORE some @$$wipe stole our Scott Pederson self energizing cantilever brakes, stoker's Suntour XC seatpost with Brooks Pro saddle (my wife is still pissed about losing that), and our solar computer (night after our ride while bike was parked in facilities of our pretty high end hotel). For the record, I was wrenching on the Rodriguez just the other day!!!
#3680
Liked 6,373 Times
Hopefully the thieving B*****D's got/get their due which is of course is not likely.
#3681
Liked 2,439 Times
@Markeologist, was it a women’s Brooks Pro? I might have one I could let go.
#3684
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
Likes For JaccoW:
#3685
Quoted: 378 Post(s)
Liked 1,409 Times
I have been fighting a front derailleur, SRAM Red 10-speed double.
You Tube only helped a little bit.
On an 85-mile shakedown ride, it did not want to climb to the big ring, then it tossed over.
Later on the same ride, it didn’t want to drop to the small ring, then it tossed to the BB shell.
Added a 2.5mm R BB spacer as the inner ring was very close, smaller cogs chattered on small-small.
I was running compact and 11-30 rear, so I figured chain slack was part of it.
Replaced the RD with a clutched X.9, rear is smooth and no slap.
Reset the FD per the video, and it really doesn’t want to drop to the inner.
Of course, backing off inner limit then compromises the shift to the outer ring. Aargh.
I am close to swapping in a Nuevo Record.
#3686
Later on the same ride, it didn’t want to drop to the small ring, then it tossed to the BB she’ll.
#3687
Liked 2,439 Times
Well done, @JaccoW!
Likes For noglider:
#3688
Quoted: 148 Post(s)
Liked 362 Times
Likes For RobbieTunes:
#3690
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 391 Post(s)
Liked 812 Times
Nice! I would love to remove the bb-un55 as well but have no idea how to start it. Bearing disintegrated after 1 month so theres no space for the tool. It was the only new part of the bike Anyhow Im going to massacre it, will be well documented..
#3691
Bikes: Indeed!
Quoted: 1506 Post(s)
Liked 3,459 Times
I was somewhat amused and a little curious why my SRAM Red 11 speed f. derr came equipped with a chain catcher to keep the chain from dropping off the inside of the front chainring, maybe because of the types of issues you are experiencing.
Brent
#3692
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
I will once it's done but right now it's a project bike that definitely still needs some work. But it's one of my wishlist models and in a very rare size (66cm, a.k.a. my size )
What do you mean there's no space for the tool? Do you have a picture to show what you mean? As long as the splines on the cups are still there you will have plenty of grip to remove it. All you need is a way to keep the removal tool in place. I usually use a big washer ring and the crank bolt.
#3693
Quoted: 391 Post(s)
Liked 812 Times
The splines are intact, so is the tool as both were brand new. So the axle is pointing to the side to an extend that I cant insert the tool in the slots.
Actually wanted to open a Help thread about it since I'm not 'wrenching" just would like to... but let the pictures talk.
Obviously methods implying big force are off, since I'm happy if the frame does not fall apart on its own. My planned idea was to drill/grind the cartridge to an extend where i can move the axle to a better pos, or remove it completely.
Odd, that the non-drive side is not as off as this, also I was able to remove the ring there.
#3694
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
Obviously methods implying big force are off, since I'm if the frame does not fall apart on its own. My planned idea was to drill/grind the cartridge to an extend where i can move the axle to a better pos, or remove it completely.
Here I removed the Drive side by fixing the tool in place with a washer and a nut:
And the non-drive side was done with the tool, a bolt and some washers on both the outside and the inside:
If you want I can shoot some better pictures to explain.
Likes For JaccoW:
#3695
Quoted: 391 Post(s)
Liked 812 Times
Ah that looks like the dust cap popped out and it was improperly tightened. I would say start a thread. You can probably get that out just fine with a tool, a rod and some washers.
Likes For Lattz:
#3696
Liked 2,439 Times
Robbie, just a guess but your problem may be your chainrings. I've heard that some of the 10 and 11 speed systems can be quite finicky if the chainrings aren't one of the few factory combinations. Seems that the ramps and pins are set up to work well only when they are matched between the two chainrings.
#3697
Edumacator
Quoted: 2429 Post(s)
Liked 3,098 Times
Where does one get a wrench that beefy/long!?!?! I need one!
#3699
Overdoing projects
Quoted: 784 Post(s)
Liked 1,237 Times
#3700
Edumacator
Liked 3,098 Times
And of course, as I speak, another seized project...this time a Dura Ace 7 speed freewheel on a Dura Ace hub.
Likes For jdawginsc:
