Check for chain wear
Bikes: 2022 Specialized Creo E-Bike XXL with Custom Wheels, 1992 Serotta Colorado II with Dura Ace STI, 2021 Zinn Ti Clydesdale Team XXL with Ultegra Di2
Quoted: 54 Post(s)
Liked 39 Times
My 11 speed chained bike has about 1500 miles on it and I am meticulous about chain cleanliness and checking wear. I use a Pedros chain checker My check this morning indicated 5 checks all at less than 0.5%, however, a check that includes the connecting link measued just at 0.5%, maybe just a touch less…
Is it normal to get a higher number over a connecting link and should I replace the chain?
SRAM 1130 chain…..I use Silca Synergetic wet lube
Quoted: 6196 Post(s)
Liked 4,811 Times
I use my chain checker for quick checks. However since they are basically a go-no go gauge, you don't get much idea what the wear is on the ones it doesn't fail. So maybe if you use a metal tape measure or other scale, then measure out 12"along the part of the chain that doesn't include the quick link and see how close the rest of it is to being 0.5%.. A 1/16" more than 12" is just a tad more than 0.5% So if the rest of the chain is close, you might as well change it. But for one link, even if the quick link, I might not worry about immediate replacement. But I would try to figure out what is up with that quick link. Is it the same brand as the chain is or is this a universal quick link for any 11 speed chain?
1500 miles isn't very much on a chain. I've got over 5000 on a 11 speed chain currently. And my previous 11 speed chain on another bike went at just 4000 miles. Actually it was probably bad earlier, but I got lax about checking.
Likes For Iride01:
Quoted: 54 Post(s)
Liked 39 Times
Thanks. For the reply….Since all my other checks that didn’t include the connecting link meaure ok and the 1 measurement that included was marginally good, i think im ok….
I was just wondering if it is normal to expect a slightly “sloppy” measurement when that quick link is included. Since that link is only one (really only one half) of a link, I cant forsee it really causing any premature wear. It is the original SRAM quick link…..chain has never been off the bicycle
Not really sure I’d trust a ruler. Hard for me to eyeball the pin center…..
Likes For 55tele:
Liked 4,811 Times
Likes For Iride01:
Since we’re at the topic of “wear” on drive train components. What do people use to gauge when to replace cassettes?
I hear 2 different school of thoughts. One being change cassette when change chain. The other school of thought says the exact opposite. Change chain early so it to minimize wear on the cassette. So for the believer of the latter, how do you figure out when to change cassette?
Quoted: 54 Post(s)
Liked 39 Times
Point well taken…..still does not seem to be a precise method to measure pin center to center on a chain.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times
Cassettes, if you manage your chains and replace before excessive wear about every third chain you might need to replace cassette. If you run your chains until they are way past 5% you will likely need to replace sooner. Either way when they skip with a new chain it is past time to replace.
Sir Mark, Knight of Sufferlandria
Likes For Black wallnut:
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
Visual inspection. If the teeth are symmetrical and shaped like they were when new, you don't need to replace it, no matter how many miles it's gone or how many chains you've been through. If the teeth are starting to take a shark fin shape, it's time to replace. Likewise if the drivetrain is getting noisy or hard to shift--or if you can't seem to get it adjusted to keep from skipping and other components can be ruled out.
By the way, these last criteria are the best way to judge when it's time to replace the chain. If the gauge indicates less than .75% and it runs smooth and shifts as it should, why replace? Likewise if it's only at .5%, but it doesn't run right, maybe replace that chain.
Liked 4,811 Times
But I'm okay with chain checkers too. Though some can give a false indication as they measure to different sides of the rollers and some have made a good case that sometimes that wear can be from the rollers internal wear and not always the wear that matters. There are chain checkers that measure to the same side of the roller. Shimano makes on and I think Pedro's does too. So maybe yours is that model.
Liked 4,811 Times
Iride01 this is a bicycle forum, not a machinists forum. In that context ruler is an appropriate term. He could also use a machinists rule.
But perhaps I should read your response the same way and just imagine you are poking some friendly fun too! <grin>
Likes For Iride01:
Quoted: 506 Post(s)
Liked 639 Times
Likes For KerryIrons:
Quoted: 5793 Post(s)
Liked 2,585 Times
The thing to keep in mind when considering chain wear and replacement is that it's not a binary -- pass/fail -- thing.
It's progressive so there's no great harm in delaying replacement when it;s a close call. Equally, the only harm in replacing before it passes the "magic" replace now mark is the economic loss of not getting full value from the removed chain.
It's kind of like changing oil in a car. Even folks who are religious about changing oil at 2,500 miles won't pull off the road and do so the moment they hit that exact mileage. So, think about the replace time on your chain check as a zone, and feel free to take it with a grain of salt.
BTW - to answer the original question, yes wear on the quick link pins may be different. Those pins might be made of a different steel and harder or softer than the others. Also, there's always some variance when steel parts are heat treated. Manufacturers segregate parts for QC, so while the odds are that all pins in a single chain are from the same batch, those on the links won't be, accounting for slight differences.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Someone jerked your chain and you woke up with your tail a waggin'
"a measure"... hoo boy.
PS.. to clarify... this is "friendly fun", 01
Quoted: 503 Post(s)
Liked 634 Times
Liked 4,811 Times
Of course it's friendly fun. If y'all were a little more aware, any of you might have pointed out that a scale also includes a straight edge and is sometimes used to scribe lines. Which has been my retort to others when they get on to me for calling it a ruler forgetting that some machinists are picky about the jargon. Might be dependent on the area or region of the country. Maybe even the shop.
Likes For Iride01:
That said, I'm not sure that I've ever received a useful result from it as I've yet to measure a cassette that indicated meaningful wear. Not even on a 1991 Miyata 1000 that I picked up recently that had it's OEM HG50 and, supposedly, was used to tour the length of South America. I do tend to be a fairly early replacer of bike consumables.
So, while we have a prophylactic reason to avoid significant chain wear, I feel that we do not have a prophylactic reason to avoid cassette wear. As such, I don't feel that there is a need to replace cassettes until they start performing poorly with respect to shifting, skipping, etc. And this approach is consistent with most of the other recommendations previously expressed.
Likes For Harold74:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
I don't trust chain checkers. I use a ruler which never lies:
Bicycle: Measuring Chain Wear using a 12-Inch Ruler
Likes For Lombard:
Quoted: 502 Post(s)
Liked 436 Times
