How long do resin pads last?
Old 08-08-18, 05:50 PM
epnnf
epnnf's Avatar
Bikes: 2016 Masi strada vita due, 2019 Kona Dew Plus
Quoted: 103 Post(s)
Liked 8 Times in 5 Posts
My lbs says semi metallic brakes pads are a happy medium, but I dont like their squeak. Will resin pads wear out much sooner than semis?
epnnf is offline
Old 08-09-18, 12:40 AM
cpach
Bikes: Too many. Cannondale SuperSix, Trek Remedy 8, Trek Crossrip+ get the most ride time.
Quoted: 374 Post(s)
Liked 138 Times in 114 Posts
Sure, yes. Maybe a bit less than half as long? I got 700 miles on my eBike on my last pair of Sram road organic pads with a very steep and windy descent at the start of my commute every day, moderate traffic, and a tendency to brake hard and late into corners. YMMV I would pick pads based on my preferred feel/modulation. Replacing them isn't such a big deal.
cpach is offline
Old 08-11-18, 02:12 PM
Tony_G
Mostly Harmless
Tony_G's Avatar
Bikes: 2018 Cannondale Synapse AL 105 SE, 2017 Giant Roam 1
Quoted: 72 Post(s)
Liked 5 Times in 5 Posts
Originally Posted by jonmanjiro View Post
Subscribing to the thread as I just got a bike equipped with resin brake pads. 700 miles doesn't seem like a whole lot :O
I could probably get 3,000 miles out of Shimano B01S pads. But I usually change them early to make sure I donít damage the disc.
Also, at least on my bike (a Deore equipped hybrid), they donít wear perfectly flat. One end of the pad is a little bit thinner than the rest of it, so eyeballing the last millimeter of pad thickness while still on the bike isnít easy for me.
At under $10 per pair, I just swap them out at 2,200 to 2,500 miles.
Tony_G is offline
Old 08-11-18, 02:20 PM
jimc101
Quoted: 345 Post(s)
Liked 13 Times in 13 Posts
Day, month, year, who knows... all depends on what your riding, and conditions, on a road bike, in the dry, you could get a very long life, off-road, in the rain, with a gritty surface getting sprayed onto the pads, you could blow through them in a ride.
As an example of resin vs sintered (metal pads), I was using stock Shimano pads on my CX-75 brakes, and having to stop and adjust (for wear) them after almost every decent (on road wet but mainly dry), have changed these out to sintered pads, and now only have to adjust occasionally
jimc101 is offline
Old 08-11-18, 09:53 PM
cpach
Quoted: 374 Post(s)
700 miles also includes a thousand feet of descending every time I leave my house, use in rainy conditions, an aggressive braking style, and lots of hard braking in traffic. Many trail bikes will get less life--a DH bike ridden in bike parks considerably less. For most road/commuter riders they'll get much more.
cpach is offline
Old 08-11-18, 09:56 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4730 Post(s)
Liked 1,401 Times in 815 Posts
Never used anything other than resin pads. Of all the brands I've tried, I've averaged about 6,000 miles a pair.
DrIsotope is offline
azza_333
Bicycle Mechanics
5
08-12-15 05:32 PM
dvald001
Commuting
11
01-17-14 04:08 PM
dabee1106
Bicycle Mechanics
8
09-09-12 11:13 AM
TurbineBlade
Bicycle Mechanics
8
12-10-10 06:59 PM
KonAaron Snake
Classic & Vintage
10
04-08-10 10:09 PM
