Is this OK?
Is this OK?
Is spacing the calliper this far out going to put too much stress on the mounting bolt, possibly bending it? The nut covers about 8mm and the bolt is 6mm so I think it has enough capture.
Quoted: 4195 Post(s)
Liked 3,837 Times
There's no way I would put that out on a bike I or others would ride. I take it that the "recessed" nut is bottomed out on the front side of the steerer. This offers the caliper much less resistance to the rocking that braking action can create. When the recessed nut is properly bottomed on the crown's backside there is a significantly greater bracing ability, the one designed and intended by people far smarter then you and I.
Now when one adds a bracket to the mix the importance of keeping the caliper's mounting bolt tight and positively held is even greater.
So what to do? The best option is to get a shorter nut. One that will have it's shoulder seat against the crown's backside. It's possible that the current, too long, nut has enough threads to just cut down to an appropriate length. But most every shop I've worked in has a lot of these nuts bin various lengths. Some bikes come with more then one and the extras get tossed into the misc. bin. Andy
AndrewRStewart
AndrewRStewart
Thanks for the reply. The nut has a step in it and is clamping in the back side of the fork. The condition you describe was what I ended up with at first and I agree that wouldn’t have worked.
So now it’s clamping the entire crown and my only concern is if the stud will bend being that much further forward.
Quoted: 836 Post(s)
Liked 1,058 Times
If that were a solid spacer I would say it's fine but it looks like some kind of wire bracket (am I assuming correctly?) and that would worry me as it may tend to shift from the movement of the calipers causing some play or even slipping off the mounting bolt. Keep an eye on it just to sure and I think placing the thin washer in the front of the bracket rather than behind as it is now would be a little more secure.
Quoted: 18350 Post(s)
Liked 4,502 Times
Is that a headlight mount?
I think the brake attachment point is commonly used. It looks like it comes awfully close to rubbing the headset. You might be able to gently round the lower corner of the headset cup.
As Andrew Steward said, make sure the recessed nut is set right.
On the front tire, forces would tend to bend the brake forward (and upward). Watch for the shoes rubbing on the tires, but it won't be driven downward and into the tire.
Anyway, I wouldn't worry about it too much if everything is adjusted right.
Yes that bracket is a headlight mount from Busch & Mueller. It’s really stiff and isn’t going to flex at all. There is daylight between the headset and the bracket.
Liked 3,837 Times
AndrewRStewart
AndrewRStewart
Quoted: 11 Post(s)
I would much rather move the light to a fork blade mounted bracket. As you can't get the light bracket fully up bacause of the headset, the surface area is much smaller than designed when using the brake as a mounting point. On a beefier fork, you can get about 200 degrees of contact instead of those two small contact points by moving the bracket up.
