Addiction LXXVIII
#6451
So it is
Quoted: 11399 Post(s)
Liked 4,748 Times
Stuff is weird in the country, but Addiction? Not so much. Things OK with you?
#6452
Quoted: 18409 Post(s)
Liked 15,530 Times
#6453
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Likes For Trsnrtr:
#6455
Super Modest
Liked 4,620 Times
We've been hovering around 60 for a few cloudy/rainy days. I swear that the damp air at 60 feels worse than the dry air at 35. Supposed to have 80s by this weekend.
Keep the chain tight!
#6456
Quoted: 3359 Post(s)
Liked 3,637 Times
#6457
VFL For Life
Bikes: Velo Volmobile
Quoted: 28604 Post(s)
Liked 1,855 Times
#6458
Should Be More Popular
Quoted: 22592 Post(s)
Liked 8,925 Times
#6459
Liked 8,925 Times
#6460
Quoted: 20810 Post(s)
Liked 9,456 Times
I am in desperate need of a ride. My wife took Friday off and I figured that I could ride Sat and Sun, so I busted my hump working on yard/garden stuff, instead. Then Saturday morning came and I didn't suit up because it was one of those days where the threat of rain hung right in front of me... and it kept hanging there, all morning and through the middle of afternoon. Pissed me right off. Sunday was a wash from the get-go - rain from bell to bell.
#6461
Sophomore Member
Quoted: 1628 Post(s)
Liked 1,057 Times
That worked OK. But what I ultimately ended up doing was getting a set of short clear demitasse cups, so I can see how fast the cup is filling up. With my machine, sometimes you get the steam all at once, and sometimes you have to wait a few seconds. Worst thing you can do with your shots is let 'em run too long, they end up tasting watery.
#6462
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Cold and damp is the worst. Cold and dry is pleasant. Not that I've experienced either in a long time, but that memory remains intact.
#6463
Mostly Harmless
Bikes: Have two wheels
Quoted: 13711 Post(s)
Liked 4,525 Times
#6465
Mostly Harmless
Liked 4,525 Times
#6466
Mostly Harmless
Liked 4,525 Times
#6467
Liked 9,456 Times
I had to buy some special short cups for mine, I only had one cup short enough to fit under the machine, but it barely fit, and I couldn't see how much espresso was coming out. So I started timing the shots to 10 seconds.
#6468
VFL For Life
Liked 1,855 Times
#6469
VFL For Life
Liked 1,855 Times
Cycling helmets with a built-in mask.
Claiming the patent now.
NFL testing new protective face masks with surgical or N95 material
#6470
Administrator
Quoted: 11966 Post(s)
Liked 6,632 Times
Anniversary celebration done and dusted. We watched two episodes from season three of Mr. Robot, while waiting for darkness to fall. Then out came the cheese and crackers, and one beer for me and two for the Mrs. And let's not forget the floating candles in the indoor/outdoor water feature. Very romantic. The Mrs. tells me we're going to Europe for number 30. Will it be safe to travel a year from now?
#6471
Liked 9,456 Times
I can't fathom repeatedly going anaerobic with a face mask on.
#6472
So it is
Liked 4,748 Times
#6473
Super Modest
Liked 4,620 Times
Anyway, I'm 5 shots (2 doubles and a single) and I've been up less than 2 hours and slightly wired. I may have to grind up some decaf espresso beans.
#6474
Sophomore Member
Liked 1,057 Times
In general, you're looking for a ~30 sec extraction for a given shot volume and adjustments to grind (and tamping pressure, to a lesser extent) gets you there. So if you're getting 3oz in 15 seconds, your grind is too coarse and you want a finer grind and/or firmer tamp (the rule of thumb for tamp is ~30 pounds of pressure, but you can adjust up and down a little).
