Shimano PTFE or Jagwire Road Elite cables/housings
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 559 Post(s)
Liked 63 Times
About to replace the chain and cassette on my Cannondale CAAD12/Ultegra to change cassette ratios. At the same time, I am planning to install new cables and housings. It's down to Jagwire Road Elite Sealed and Shimano PTFE cables and housings. I already have Jagwire Road Elite for the brakes and am happy with the result. A nearby LBS recommended the Shimano product.
Any thoughts/comments from those who have tried both?
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
Likes For noodle soup:
I have a good experience with the Jagwire cables (elite link). It had smoother cable pull feel overall compared to the shimano cables it replaced. I would buy the same if ever I need to replace them.
Adding, it looks great as well.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Shimano Optislick for shifting, Jagwire or anything else for brakes. Haven't had any peeling or other problems.
On Your Left
Liked 2,433 Times
I have Shimano with the optislick crap and at what I estimate to be 1200 miles, I and the LBS agree I'm probably in need of cable replacements, at least for the RD. They said the regular, non opti should go for 3000ish miles.
On Your Left
Liked 2,433 Times
Actually you should do what I did a eliminate the shifter cables.
Likes For popeye:
just switched myself from shimano to jagwire. The shimano stuff works fine just need to change it more often imo
EDIT:
Shimano says:
"OPTISLICK
Shimano OPTISLICK shift cables offer outstanding shift performance and impressive cable longevity for a wide range of components. From Shimano 105 groups down to entry-level ALTUS and CLARIS components, OPTISLICK technology provides smooth and reliable shifting for riders of all levels. While low-end cables are made of steel, Shimano’s OPTISLICK cables are produced from corrosion-resistant stainless steel. Then, the cables are electrically coated to reduce friction and extend the lifespan considerably. OPTISLICK cables are Shimano’s longest-lasting option, designed to ensure the best possible value and user experience.
POLYMER
Shimano delivers the fastest shifting possible with its premium Polymer Coated Cables. Paired with Shimano's race-level XTR, DURA-ACE, and ULTEGRA component groups, these low friction cables deliver top of the line shifting performance.
The Polymer Coated Cables feature inner stainless steel wires that are wrapped with ultra-slick polymer tubes. This polymer coating creates a series of tiny ridges, which reduces the surface area that is in contact with the outer cable housing – resulting in the fastest, lowest-friction shifting possible.
The polymer strands on these cables wear out slightly faster than the cables themselves and can increase friction as they age. That's why Shimano includes the premium Polymer Coated Cables with its race-oriented groups, where riders typically replace their cables more frequently."
https://bike.shimano.com/en-US/infor...ated-shif.html
Quoted: 7648 Post(s)
Liked 3,465 Times
I like Jagwire but I am running the Shimano polymer coated cables at the moment thanks to a great deal I found online. They are very good and no fraying/peeling so far.
