2.3 to 2.5 Maxxis Minions
B*ck From Th* D**d
Bikes: 2015 Kona Process 153
Quoted: 23 Post(s)
Liked 8 Times
Has anyone gone up in tire size and found out it was a good choice? My tires will need replacement soon and my buddy has suggested I increase my tire size, at least my front.
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
Some models size up small (my 2.5 is really a 2.3), other are true to size.
B*ck From Th* D**d
Quoted: 23 Post(s)
Liked 8 Times
I run DHFs on both front and back and 27's. I think I am going to go bigger, at least in the front, I am just curious to see if others have jumped and have any advice to give.
Advanced Slacker
Liked 2,537 Times
I'm running a "supposedly" 2.5 DHF on the front of my 26" bike, but in reality it is a 2.3 (identical in size to the 2.3 Aggressor I run in the rear, and several other 2.3s I've run). I'm OK with the size, but I do wish it was just a tad bigger. Over the years I've always gone for 2.4-2.5 in the front. Then a few years back someone highly recommended the Butcher in 2.3. I was at first a bit dubious of the smaller size, but it ended up being the best tire I had ever run in the front. The DHF I have now is the same size, and I like it even more. Not sure if I like them in spite of their size or because of it.
In your shoes, I would probably try the 2.5 in the front, especially if you have the rim width for it. I find 2.3's as big as I ever really need in the rear. I never ran a DHF back there, I usually go for something a little faster.
Bikes: Too many
I would go up in size or even try the new Assegai 2.5 if I were you. Just make sure that you aren't putting a 2.5 tire on a 21mm internal rim - too much squirm and you are better off with the 2.3. Ideally 27-30mm for the 2.5. Maxxis' new WT tires are definitely true to size.
Likes For plipperpete:
Advanced Slacker
Liked 2,537 Times
I would not think twice about running a 2.5 on a 21mm rim. A wider rim is definitely better, but if you want to try a wider tire, go for it. People were running 2.5s on 21mm rims (or narrower) for many years.
B*ck From Th* D**d
Quoted: 23 Post(s)
Liked 8 Times
I have Spank Oozy Trail 345 Rims, 30mm inners. I don't know if the profile will matter so much as how they perform. I would like to be able to blast through rough stuff a little faster, which I hope the tires can help a tad.
Likes For WannaGetGood:
Advanced Slacker
Liked 2,537 Times
As far as blasting through rough stuff faster? Maybe, or maybe not. Look at what Enduro and DH racers are running, and you see mostly 2.3 through 2.5. So some are finding 2.3 faster, some 2.5. There are a lot of factors going into what works best. You probably won't really know unless you try it.
B*ck From Th* D**d
Quoted: 23 Post(s)
Liked 8 Times
Yeah, with 30mm rims I would definitely want to try a 2.5.
I run a 2.5 DHF front, and a 2.4 aggressor rear. Just as good as the DHR, imho. rolls better than the dhr. A little flatter profile knobs, only trade off is mud, which I tend not to ride in.
