Gritty turning hubs. Repack or replace?
Old 07-09-20, 04:20 PM
phogi
Bikes: Specialized Singlecross, Trek 720
Quoted: 9 Post(s)
Hi all,
I recently bought a used hybrid bike, in part with the idea that I'd learn by doing maintenance on it. I've some knowledge because I've built a hodge-podge bike from a frame in the past, but that was just "need a bike to go" rather than "want to do this right."
My question: while fixing a flat, I played with the hubs, and noticed the bearings at the very least need to be repacked. When I turn the axle, it is noticeably gritty and not smooth. When repacking, should I also replace the bearings?
phogi is offline
Old 07-09-20, 04:24 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Loose ball bearings?
Open clean up and inspect. if races not pitted, re grease put in new bearing balls and put it back together.
fietsbob is offline
Likes For fietsbob:
Old 07-09-20, 05:34 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
And adjust it correctly.
dsbrantjr is offline
Likes For dsbrantjr:
Old 07-09-20, 07:13 PM
sch
Quoted: 303 Post(s)
Liked 136 Times in 104 Posts
Sometimes 'gritty' is really just too tight. So yes, clean meticulously, examine races on hub and cone, replace the
balls and then find out the minor frustration of final adjustment of the bearing tightness.
But on the off chance the hub bearing races are damaged, be aware that you will probably never notice while
riding. Just put things back together and forget about it.
sch is offline
Likes For sch:
Old 07-10-20, 03:51 PM
dsbrantjr
dsbrantjr's Avatar
Originally Posted by sch
... then find out the minor frustration of final adjustment of the bearing tightness....
This tool is very helpful in this regard: https://www.steintool.com/portfolio-...ub-axle-vises/
Old 07-11-20, 01:18 PM
davidad
Quoted: 582 Post(s)
Liked 171 Times in 138 Posts
If the balls still have their mirror finish you can reuse them. I use a 7/16" on the right side of the hub axle with the QR closed to make the final adjustment. There should be a slight amount of drag that indicates preload. When the QR is opened there should be a slight of play in the axle.
davidad is offline
