CycleOps JetFluid Pro Trainer
https://www.amazon.com/CycleOps-JetFl.../dp/B0049AF5HA
LBS carries this model and I'm thinking of going with it. Is it a pretty good value for the money?
https://www.amazon.com/Kinetic-Kurt-M...1396913&sr=1-1
And yes, I own two of them.
Bikes: Specialized road
I just bought Cyclops JetFluid Pro and I'm very happy with it. It is very quiet, solidly built, and it has a great road feel. I considered buying KK Road machine, which is a great trainer, but I feel the JetFluid Pro is less noisy and it has better roal feel. Cyclops are built in the US, by a company which makes high end trainers and bicycle products. I read several posts about Cyclops leaking, but this problem was fixed by the company. The JetFluid Pro comes with a lifetime warranty, so I do not worry about the leaks. The trainer is a nice design, easy to set up, and very stable. I highly recommend it.
I thought just the opposite about the road feel but that is where personal preference comes in. I think anyone wanting to buy any trainer or rollers needs to try them first. As far as noise goes, are you using a trainer tire or your road tires? Makes a difference for me.
Bikes: '09 Gary Fisher "Kaitai, '09 Raleigh Team", '91 Trek 8700, '97 Cannondale SR500, '12 Raleigh Twin Six
I've been very happy with mine. Couple thousand miles and no issues. That being said, if I were to do it over again, I would spend the coin on the Kurt Kinetics Rock and Roll trainer. It will work the core muscles and improve your balance on the bike.
Quoted: 50 Post(s)
The technique bit of rollers is totally, utterly over-rated. Does little for your real world handling skills. Yes, it's hard at first to ride rollers, but even after you master them, your handling skills in real world situation are pretty similar to before. That's because rollers teach you to go dead-straight, and that's it. No cornering at all, which is where the real handling skills matter. If you're so sloppy on the roads that you can't even hold a straight line (how friggin' hard is that, anyway?) then you won't even be able to ride the rollers at all and the answer there is not to ride the rollers (you won't be able to) but to ride outdoors until you can hold a line. (Then you can try to stay on the rollers.)
The biggest problem after you get on rollers is accidentally jerking off the front (not side) on hard pedaling. How often does that occur in real life? NEVER.
Yes, rollers smooth out your pedal stroke, but I can tell you after going from a super jerky pedal stroke (from being a runner) to smooth one that I can do onelegged on the rollers that it did NOTHING for me in terms of speed. Actually, I have to intentionally jerk my acceleration harder than ever now that I ride with competitive roadies where you often have to make a gap if you're out in front to drop the draftees behind you. Even when I'm riding smoothly with a group, I never ride as artificially stock-still as I do when I'm on the rollers.
Much better power consistency from a trainer, which is key to structured interval workouts. Use a speed-power conversion chart and your trainer is as good as a powermeter indoors.
LowCel
Road Cycling
0
11-23-11 04:46 PM
FlashBazbo
Road Cycling
18
07-03-10 09:36 PM
