I may have SLIGHTLY over inflated my inner tube
Quoted: 1002 Post(s)
Liked 237 Times
Darth Lefty is smarter than all of you.
The tube was a size too small.
I put it in 2 years ago as an emergency tube when it was all I had handy. I went to the store to buy the proper tube the next day and never bothered to switch them. I've kinda known it was a matter of time since then but figured 'screw it'.
The smaller tube finally gave out due to overinflation this morning. And the replacement tube I bought 2 years ago is going on the bike.
Everyone else assumed they knew the relevant data points. No one did. On Darth Lefty was humble enough to say 'if' and not declare he knew everything.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Humble, that's me.
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Arizona Dessert
Quoted: 5345 Post(s)
Liked 2,169 Times
Most likely underinflated and resulting pinch flat. That happened to me once.
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,430 Times
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,430 Times
Likes For RubeRad:
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,430 Times
Unlisted member
Bikes: Specialized Hardrock
Quoted: 1376 Post(s)
Liked 432 Times
I had one blow up when the cats and I were in the living room and the bike was in the spare bedroom. We were all startled, but I recognized the sound and sure enough a tire was flat. I don't remember just why it failed, but it definitely did.
I'm the anecdote.
Bikes: '12 Schwinn, '13 Norco
Quoted: 1110 Post(s)
Liked 1,176 Times
This thread is the best piece of pure entertainment I've come across today.
Of course, I don't get out much and have antenna TV, so . . .
Likes For Skipjacks:
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
It's really hard to imagine how that's the only cause of the explosion. The tube doesn't stretch any more at the seam from over-inflation, unless the tire moves off the bead. It was either pinched, or something inside the tube or on the rim was pressing against the tube.
Liked 237 Times
Another one who hasn't seen the tube, touched the tire, looked at a single piece of the evidence who's telling the person who did inspect all those elements that he didn't see what he saw?
And all of you just ignore simplest explanations like a tube just having a weak point that was worn out and exploited by being overpressured?
Because a $6 rubber inner tube that's too small and god only knows how old (seriously I have no idea...don't even know where I got it) is infallible, right? It MUST be something else?
Rubber never dries out and loses it's elasticity over time, causing weak points to be weaker. That never happens.....
Keepin it Wheel
Quoted: 26 Post(s)
Liked 3,430 Times
Maybe you should post a pic of the long linear tear along the seam to exonerate yourself.
Speaking of seams, I patched 3 holes last week, why are they always within 1mm of a seam! Why do tube manufacturers put the seam directly on the outside (where punctures are most likely), instead of like 45deg off? (Maybe it's to discourage patching and encouraging buying more tubes?)
Seriously?
Liked 237 Times
The thing is, the wall of the tube has to stretch to fail the way you're describing. If the tire didn't move, the tube has nowhere to stretch to. You're right that none of us can see what you have seen, but I had the exact same thought as several other posters here. It just makes way more sense that the tire came unseated before your catastrophic tube failure. Or there was some other defect allowing the tube to bulge somewhere.
It was old. This is an actual thing that happens to rubber. I swear I'm not making this up. Rubber gets old and brittle. I could even feel the rubber near the seem rip was tougher and less pliable.
People, it's just an old tube that was undersized for the tire it was in. It had a weak spot that failed.
The thread was about the loud bang. It was funny! I didn't even tell you all the part about the woman from the office next door asking if I had a nail gun! It's funny stuff!
Laugh! Enjoy! Don't over-analyze it!
Life's too short for this.
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
I had just moved into my townhome when in the middle of the night I heard that BANG! I had no idea where it came from. I checked the basement, everything seemed fine.
Several days later when I when to inflate the tires on my bike, The stem was gone on my back tire. I thought WTH! Then it dawned on me that BANG I heard was the stem blowing off.
I think the (annoying) kids call this "humble-bragging"
Liked 237 Times
Just yesterday I got some new tires in a much bigger size than I normally use. Being a very smart person, I ordered tubes from a completely different website, and so they haven't arrived yet. I considered using some of the smaller tubes I have on hand, but was worried about this exact issue. Thanks for learning that lesson for me.
Even then it took 2 years to fail.
If it was a new tube at the time and in a box and I hadn't way overfilled it yesterday it would probably still be fine today. Some people use smaller tubes all the time and they work.
Bikes: Nashbar Road
Liked 341 Times
Seriously?
Not that it matters either way. I just thought you might like to know.
Unlisted member
Liked 432 Times
The flat I mentioned was right by the stem on an older tube, and likely failed after being inflated too many times. And the hole was too big to patch, so I just put a new one in.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
How deep are the claw marks in the ceiling?
Liked 237 Times
I understand it when I'm on the side of the road and don't feel like walking home. But I don't understand patching tubes until the tube is more patch than original.
Tubes are cheap. I can always find a use for an old one. I just don't get riding on tubes with 15 patches on them.
Maybe it's because I blow a tube about once a year across both my bikes and my kids' bikes and its just cheap to replace one. Maybe if I lived in a place with goat heads and cactus needles and nails everywhere and had a punctured tube every other week like some people it would get expensive to be constantly replacing tubes.
Does anyone here patch them until you can no longer see any of the original rubber?
I picked up a load of new tubes from Performance on their last day. 90% off, so like 70 cents each. They will hopefully last 10 years in the box, because I bought quite a few.
