ANT+ Cadence Sensor With Static ID
ANT+ Cadence Sensor (Magnet Type) With Static Device ID
I need a ANT+ cadence sensor with a fixed ID. It needs to be persistent through power cycles, i.e through battery removal and replacement. It should be a magnet-sensing type, using a reed switch.
It seems common practice to randomize the ID at power-up. Probably so the manufacturer doesn't have to individually program each device on the manufacturing line. Makes sense but doesn't work for my project.
Any experience with this? Do you have a cadence sensor with ID which doesn't need to be re-learned after battery replacement? Thanks!
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times
I have no idea if it uses a reed relay or not.
A reed switch requires a magnet to trip it. You can hear the "pling" when a magnet comes within range. All of my ANT+ sensors (Wahoo, Cateye, and Garmin ) have a unique address to pair to.
Purchased and tested a Bontrager Interchange cadence sensor. Confirming it appears to power up with the same ID after a battery change. My initial test was with a Niterider Rebel cadence sensor which definitely rolled its ID on a battery change.
All my ANT+ sensors come up with the same ID whenever I pair them.
Curious, why does it have to be the magnet sensing cadence sensor? As long as it's a new sensor, why wouldn't you want to get rid of the external magnet issue?
I'm mashing up anemometers with cadence sensors. The resultant unit reports air speed on the cadence channel. I'm doing aerodynamic drag testing so I care about air speed, not cadence. I log that "cadence", a well-known value to all sorts of cycle computers, and post-process the logged cadence to obtain airspeed.
An old-style cadence sensor interfaces to a simple digital input, a magnetic reed switch. The anemometer interface into that cadence sensor is (relatively) trivial. A new style magnet-less sensors use an accelerometer to infer orientation, and there is not an obvious way to fool them with a different input.
My test bikes are all equipped with legacy wired or ANT+ Powertaps acquired at reasonable prices. For drag testing, important to know power at the wheel, not at the crank. Were I to move to BT, Weather Meter anemometer is supported by CdaCrr app, looks pretty cool. Anyone have experience with that combo?
