39-52 crank replacement
Quoted: 11 Post(s)
Hi all,
Owner of an old Murray mountain bike from mid 80’s.
Long story short. Purchased 4 months ago from an older couple who never used it and stored it indoors - 40$. Have 600 miles on it since mid August. Been flawless. New tires and pedals. That’s it. Heavy as crap but been super fun to ride.
One arm on the crank finally bit the dust. Not sure where to look for a replacement. I myself am unsure if bearing size is consistent on mountain bikes and all that stuff.
any help?
any help?
With a mighty wind
Quoted: 1085 Post(s)
Liked 858 Times
It's a pretty common lower end set-up. The bearing is probably fine, no need to replace.
I'd bring the whole crank into the shop. Bring the pedal too just to be sure of the spindle size. They should have some, either new or in the spare parts bin. Probably $30 or less.
Do you need them to install or will you be doing that yourself? Add 15-20 bucks for installation.
Quoted: 11 Post(s)
Doing it myself. I’ve turned a few bolts and head gaskets and such.
thanks for the info - I’ll bring the pedals in as well. Good thought.
So bearing size is pretty consistent and arm length as well I would assume.
I was all ready for 30 miles today. Thank God it happened right in front of the house.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
Or go whole hog and convert it to a 3 piece cotterless crank.Probably drop at least a pound of weight.
Insane Bicycle Mechanic
Quoted: 797 Post(s)
Liked 694 Times
Here's a how-to on the Park Tools site. It looks like you've made good progress without it: https://www.parktool.com/blog/repair...vice-one-piece
Jeff Wills
Jeff Wills
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Quoted: 797 Post(s)
Liked 694 Times
A co-worker broke a similar crank in the same fashion. I pointed him to the same Park Tool as above and he managed to replace the crank himself. He's pretty handy for a pharmacist.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
