Ultegra short cage with 32t cassette OK?
Has anyone used a short cage Ultegra derailluer with a 32t casette?
I'm changing my Shimano 105 11 speed 11-28 cassette for a new Ultegra 11-32, (and new Ultegra chain). My current derailluer is the short cage Ultegra (RD R8000-SS) and Shimano says it's good for up to a 30 tooth cassette. Would I be OK using my short cage with the 32 tooth or am I asking for trouble?
I already bought the long cage (R8000-GS) but I'm questioning whether it's really necessary. I could still return the new one as it's still in the unopened box and within their 30 day return window.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Try it. I use the 32T-rated mid-cage Ultegra on a 36T cassette with no problem. Just crank on the B-screw.
Likes For Cyclist0108:
Quoted: 1975 Post(s)
Liked 232 Times
I will probably clear, it may not have enough take up capacity to work with both the 50/32 and 34/11 combo or 52/36. If you're ok with that size your new chain for the big+big combo and if there is slack in the chain on 34x11 just don't use that gear combo
Quoted: 152 Post(s)
Liked 173 Times
My 2015 Giant Defy Advanced Pro1 had the short cage derailleur (Ultegra 6800) and it worked fine with an 11-32T. Shimano says 28T max and the bike came with an 11-28T but I had the bike shop (a Giant company store) swap it out to an 11-32T and it always shifted great. Give it a try, nothing to lose but I bet it works fine on the R8000 too. Don't forget you need a longer chain more than likely.
Likes For August West:
Quoted: 2495 Post(s)
Liked 738 Times
The length of the cage has nothing to do with whether or not a given RD will clear a given size of big cog. It has everything to do with the design of the upper part of the RD. There are older long cage RD's that will not clear a 32T big cog. They can WRAP the chain resulting from a wide range front triple but they may not clear a too big cog. There are now a number of different companies making dropper bolts so a RD that doesn't quite clear a 32T or bigger cog can still be used as long as its cage is long enough to wrap up the excess chain of the lowest allowable gear.
Likes For Leisesturm:
For whatever it's worth, the factory claims a capacity of 35 with the short cage and I'd be at 37 with this 50-34 & 11-32 set-up. Guess I'll just use the mid-cage, I'd hate to mess with the currently excellent shifting.
Quoted: 1572 Post(s)
Liked 643 Times
Before you give up on the idea, when is the last time that you can remember actually using your 34/11 combination? Or your 34/12 or 34/14? I could picture myself accidentally shifting into the big/big sometime but never accidentally shifting into into the little/little.
