Looking for a good bike rack solution for a sedan...
Old 12-11-19, 09:51 AM
wclarkin
Quoted: 8 Post(s)
I have a big SUV that has been my bike hauler for years, but it is on death’s door and I need to get my sedan ready to haul my bikes around when the SUV dies. I’m fairly particular with my car, so I really do not want a bike rack that could potentially damage the car: I do not like the bike racks with a bunch of straps, as it seems like the metal clasps on those are just ready to damage my paint. But if I could find one with less straps then the standard it may be a possibility at this point. My current bike rack holds three bikes which was OK because I could put two inside of the car, so I’m really looking for a bike rack that can hold four or five bikes on the sedan. I’m looking for the best cost friendly solution to haul my bikes around: any suggestions? Thanks
wclarkin is offline
Old 12-11-19, 10:05 AM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2749 Post(s)
Liked 2,516 Times in 1,422 Posts
You want a rack that holds 4-5 bikes on a sedan? You are going to have to go with a hitch-mounted rack, and with 4-5 bikes you are going to want a 2" receiver if you can get one for your car. There are not many that will hold 5 out here, though. You might also consider a 3-4 bike hitch mount rack and then a roof rack mount for the other 1 or 2.
Kapusta is offline
Likes For Kapusta:
Old 12-11-19, 10:53 AM
wclarkin
Quoted: 8 Post(s)
I would prefer that it holds four or five, but if that’s not reasonably possible then I could settle with a rack that holds three bikes since I can fit one in my back seat. What’s most important is that it is something I can easily take off and put back on. I will probably be getting a different car in the next couple years, so I’ve had trouble justifying the expense of installing a hitch I can’t keep when I sell the car.
wclarkin is offline
Old 12-11-19, 11:02 AM
thumpism
Bikes are okay, I guess.
thumpism's Avatar
Quoted: 2647 Post(s)
Liked 2,445 Times in 1,557 Posts
If you regularly haul that many bikes you need to do what's necessary for the task. If that means buying a receiver so a hitch-mount will fit, that is what I'd advise. It's the best way to minimize the possibility of damage from a trunk-mount rack and/or the bikes on it. Check your local junkyards; you might find a sedan like yours with a receiver for cheap. Do the same for the next vehicle and move the rack to that one when the time comes.
I tend to get minivans and I buy used. The last one had a 2" receiver that I used a lot and when I replaced the van the next one was the same year and also had a 2" receiver already installed. Shop wisely.
Draftmaster Racks
thumpism is offline
Likes For thumpism:
Old 12-11-19, 11:20 AM
freeranger
freeranger's Avatar
Quoted: 421 Post(s)
Liked 690 Times in 430 Posts
I know you said rack, but sounds like the best solution would be a receiver and a small utility trailer that you could modify to hold bikes. The trailer could also come in handy if you wanted to haul some mulch, dirt, whatever, that might be too heavy to put in the trunk of your sedan.
freeranger is offline
Old 12-11-19, 01:03 PM
smashndash
Quoted: 850 Post(s)
Liked 344 Times in 247 Posts
I have a sedan with a 4 bike hitch rack. It was not cheap. I would highly recommend not going the way I did. Here are the issues I ran into:
1) Rear suspension sagged
2) Rack/hitch scraped (HARD) when exiting driveways
3) Bikes constantly scraped each other. Had to buy a bunch of straps to preload the bikes against the rack and then put electrical tape on possible rub points. It worked... usually. You’ll have to live with the look on your buddy’s face when there’s a giant spot of paint missing on their baby.
Those are the main issues. I’m using a Yakima Fulltilt ($420) and it sucks for the price. The tilting mechanism adds some play to the rack, the bracket mechanisms have a TON of play/flex so the bikes sway around like crazy (hence the straps), the hitch mechanism needs greasing (which means it will need cleaning) and it’s very unwieldy to frequently reinstall (but better than most hitch racks I assume).
Carrying 4 bikes with a sedan is already a tall order. They’re not designed for it. I would suggest finding a hitch rack that has a rise so it doesn’t scrape. Maybe Kuat? Either that, or go with a 2 bike tray rack and a 2 bike roof rack. Way more expensive, but your bikes will remain intact and it won’t take you 30-40 minutes to load your bikes when it’s 35 degrees out at 4AM and you’re trying to get to a race.
I like the trailer idea as well. I’d just look into the legal restrictions etc. You probably also wouldn’t get away with speeding as easily.
You can also look into aftermarket rear springs. It’d harden the ride, cost a lot, and look weird - but you’re trying to fit a square block in a round hole anyway.
smashndash is offline
Old 12-11-19, 03:55 PM
autonomy
autonomy's Avatar
Quoted: 507 Post(s)
Liked 237 Times in 133 Posts
A roof rack or a hitch rack will both require something that's specific to the model of the car you own - either a hitch receiver or rack feet. Depending on your car, either will run you $100-$200 and will be a sunk cost. Though you can usually resell the fit kit for a decent price. The roof rack + bike carriers can be a much more expensive solution, but both the roof bars and the actual hitch rack can be reused on the new car.
If you want to do this the most economical way, get one of those racks with straps - they really aren't bad if you use them properly - then sell it when you get rid of the car. If you really don't like that idea, and you're OK with a roof rack on your future car, invest in the roof rack + carriers (you can usually get a good deal on those on CraigsList/FB marketplace) and then sell the fit kit - will be much easier than trying to sell a hitch receiver.
autonomy is offline
Old 12-11-19, 03:56 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
If you want a rack that carries 4 bikes and is not a strap-on trunk rack (which I would not want to do with 4 bikes anyway), then I don't see how you are going to get around getting either a receiver hitch or a roof rack.
You could get a roof rack with extra-long cross bars and 4 trays. When you get a new car you may only need new towers that hold the cross bars. But that is not going to be as easy to put on and take off (both the bikes and the rack itself) as a hitch-mounted rack. But really, in the larger scheme, the price difference between a new set of towers and a receiver hitch is not all that much, and 4 roof rack-mounted trays plus two cross bars are likely going to cost more than a 4-tray hitch rack of similar quality.
So I still think a hitch mounted rack is the best way to go.
Just curious, with a bike in the back seat you can only fit two or three people in the car, so why the need to carry 5 bikes?
Kapusta is offline
Old 12-11-19, 04:21 PM
Elvo
Quoted: 630 Post(s)
Liked 369 Times in 206 Posts
1upusa with roof rack for the other 2 bikes. Wouldn't recommend putting 4 bikes on a 1.25" receiver.
Elvo is offline
Likes For Elvo:
Old 12-11-19, 07:02 PM
Steve B.
Quoted: 3185 Post(s)
Liked 2,020 Times in 1,158 Posts
Same question. 4 bikes on hitch/roof, one in back seat. Where are the 5 cyclists sitting ?
Personally I would go with a roof rack. It’s a wash as to price between a hitch and rear rack or a roof system. The hitch system is marginal for 4 bike on a sedan, I wouldn’t do 5, I would do 4 on roof, which will fit on a 50” crossbar, but not 5. On a sedan, not as high a lift for the bikes as compared to an SUV. You also don’t have to remove the roof rack, it’s not in the way of anything usually, I leave mine on all season, only remove in winter so I can scrape snow off the roof.
Steve B. is offline
Old 12-11-19, 07:34 PM
honcho
Quoted: 76 Post(s)
Liked 41 Times in 30 Posts
I'll echo other respondents that 4 or more bikes on a typical sedan trailer hitch is too many. You'll be dragging the rack going up and down ramps. As for a trunk rack, I don't think anyone makes anything that they actually suggest carrying more than 3 bicycles. Even the Saris bones 3, which is, in my opinion, the best of breed in trunk racks, is pushing it with three bikes. I've done five bikes on a roof rack on a large SUV and it was unwieldy due to both the height of the vehicle and necessity for wide bars.
For 5 Bikes
Roof rack alone
Roof rack with one or more inside vehicle
Trunk rack plus Roof Rack
Hitch Rack alone
Trunk Rack with one or more inside vehicle.
honcho is offline
Old 12-11-19, 07:57 PM
DrIsotope
Non omnino gravis
DrIsotope's Avatar
Quoted: 4905 Post(s)
Liked 1,731 Times in 958 Posts
There is no inexpensive method for reliably transporting five bicycles with a sedan. It is genuinely that simple.
DrIsotope is offline
Likes For DrIsotope:
Old 12-11-19, 10:04 PM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Quoted: 889 Post(s)
Liked 906 Times in 534 Posts
Nothing particularly cost-friendly for hauling 5 bikes.Why the need to move so many at a time?
What sort of 'sedan' that covers everything from a Toyota Corolla to a Lincoln TownCar. Also, what kind of bikes? 18-lb carbon road racers? 50 lb. beach cruisers? 16" kids bikes? Fatbikes? Frankly, 5 bikes (and riders?) is going to be a big ask of most any passenger car from the last ten years (except maybe a P71 Crown Vic)
If you haul 1-2 bikes frequently, but sometimes have to haul 4-5 (races or big events) then you could have a 2-bike hitch/trunk rack that you use for the 'daily riders' and a 2-4 bike 'XL' roof rack that you slap on for big events. You could also do it the other way, Leave the 2-3 bike rails on the roof full-time and slap on a trunk rack like a Saris, when you gotta haul some extra bikes.
A lot of people balk at the idea of removing and re-installing a roof rack, but once you get the initial setup done, all you have to do is unhook the towers from the car, and take the thing off in one piece. You don't have to completely disassemble the thing every time.
Same goes for strap-mount trunk racks; once you get your rack set up for your specific car, just loosen the straps enough to unhook them, leave the 'arms' as they are, and it doesn't take much to hook it back on again.
Ironfish653 is offline
Likes For Ironfish653:
Old 10-17-21, 07:17 AM
chaadster
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times in 1,005 Posts
If that’s the case, and if easy on/off includes being able to do it single-handedly, then the SeaSucker Bomber 3-bike ($600) is worth a look.
I love my SeaSucker Talon single carrier for its ease of use and versatility, though it does require more thought than most other rack systems. What I mean, for example, is that I’ve got to remember to load the trunk before mounting the bike, because I mount the rear wheel on the trunk lid, preventing it opening when the bike is clamped down. Sure, I could loosen the fork mount and let the bike pivot when the trunk is opened, but the bike weight doesn’t allow the trunk to stay open without assistance, so it’s all rather fussy, and the best solution for me has been to stick to an order of operations.
Here’s a pic of the 3 Bomber using the same mounting I use:
chaadster is offline
Likes For chaadster:
Old 10-17-21, 12:03 PM
kahn
Quoted: 383 Post(s)
Liked 690 Times in 396 Posts
I actually setup a juryrigged pulley system in my garage. I positioned the car under the dangling roof rack and then lowered it onto the car. Or raised it to remove the rack. It was fiddly to setup but then flawless. I used that system for two different cars, modifying the arrangement and location when I replaced the first car.
kahn is offline
Old 10-18-21, 06:09 PM
thumpism
thumpism's Avatar
I recently learned that Saris makes a 5-bike rack to fit a receiver hitch, the Glide EX 5-bike.
https://www.saris.com/product/glide-5
thumpism is offline
Old 10-19-21, 12:07 AM
PaulRivers
Quoted: 539 Post(s)
Liked 44 Times in 38 Posts
With no hitch, you can easily carry 2 bikes with a rack. Carrying 3 is difficult - I've done it, but only after removing the front wheel, pedals, and taping cloth between points where the frames might rub.
4 - you need a hitch or a roof rack. It's difficult to do with a 1.25" hitch, I've used extra straps that decured the hitch rack to the trunk.
No one sells a non-hitch trunk rack that carries 4 bikes.
PaulRivers is offline
Old 10-19-21, 03:43 PM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 1541 Post(s)
Liked 1,702 Times in 956 Posts
5 bikes? no problem
icemilkcoffee is offline
Likes For icemilkcoffee:
